c-series don 10,717 #25026 Posted 22 hours ago @SylvanLakeWH I recently heard they are not going to make yard sticks any longer……………………they are going to continue to make them 36” 🤣🤣🤣🤣 4 Share this post Link to post Share on other sites
Blue Chips 304 #25027 Posted 20 hours ago 4 hours ago, Bar Nuthin said: When I pulled the lift cylinder off of "Johnny Cash" I decided to send it to @wheelhorseman and have it rebuilt. Today, I decided I might as well put it on my C-120 since the one I bush-fixed still leaves a few drips wherever I park it. May just send it in for rebuild also, since Lowell does such a nice job! I thought I'd have to overhaul the lift cylinder on my 522xi, but after cleaning off the muck that was hiding the leak, it turned out to be a slightly loose fitting, which was fine with me, since I have other projects that I'd rather work on than hydraulic cylinders. Considering the time I've spent rebuilding various hydraulic cylinders over the years, I'd seriously consider sending them out as well. However, stubborn as I am, I recently rebuilt the two steering cylinders on my old Case loader/backhoe myself. There were a couple of %&!*$#! moments, but they're both back together again and working perfectly. One of the cylinders after cleaning and painting, and ready to reassemble with some new internal parts and ball joints. Back together again: Back on Mr. Case: 6 Share this post Link to post Share on other sites
kpinnc 16,031 #25028 Posted 15 hours ago Started on a new guard for the Bronco muffler. Still gotta trim the edges and repaint the muffler itself, but the hard part is done. Used my last piece of stainless grid, but it's all good. Welding on a muffler is a pain. Only had to repair one blowout about 1/8 inch, but still frustrating. 2 6 Share this post Link to post Share on other sites
Dan 312-8 298 #25029 Posted 10 hours ago 5 hours ago, kpinnc said: Welding on a muffler is a pain. Definitely takes finesse. I have replaced more than one heat shield support in my time. Patience is key to the successful completion. Thankful for my Tig welder. 4 Share this post Link to post Share on other sites
Handy Don 14,910 #25030 Posted 6 hours ago 9 hours ago, kpinnc said: Welding on a muffler is a pain. Only had to repair one blowout about 1/8 inch, but still frustrating. When used to working with thicker gauges, it is so easy to burn through already-rusted-thin sheet metal! 2 Share this post Link to post Share on other sites
Bar Nuthin 1,674 #25031 Posted 4 hours ago 1 hour ago, Handy Don said: When used to working with thicker gauges, it is so easy to burn through already-rusted-thin sheet metal! I think people overlook the usefulness of brazing when working with fragile metal. 3 Share this post Link to post Share on other sites
Handy Don 14,910 #25032 Posted 4 hours ago (edited) 23 minutes ago, Bar Nuthin said: I think people overlook the usefulness of brazing when working with fragile metal. I did enjoy brazing (I learned when my Dad had access to a friend’s nicely-equipped shop) but since I have little occasion to “glue up” brass, copper, or stainless, I’ve simply not obtained the needed equipment and materials. Instead I’ve tried to get better at MIG welding. I still do solder occasionally for plumbing and small parts. On the rare occasions when brazing was the perfect solution for disparate metals and stronger joints, I’ve paid a friend to do the work. Edited 4 hours ago by Handy Don 2 Share this post Link to post Share on other sites
Dan 312-8 298 #25033 Posted 4 hours ago Wrapped up the deck for the season, cleaned, blades sharpened, greased and stowed away for next April. Snow plow, weights, and chains installed on the 312-8. Put on the spindle grease cups that a member here hooked me up with the Amazon link. They will get tucked back in after the exhaust cools down. And decorated outside for the season. Now, I am reclining… 3 3 Share this post Link to post Share on other sites
Blue Chips 304 #25034 Posted 2 hours ago (edited) Now that I've got my New Holland GT18/20 back together and the mowing deck attached (which worked great), I've started taking care of some deferred maintenance and repairs on my 522xi. The new PTO clutch that I ordered arrived a couple of days ago, and I plan to install that sometime later in the week. In the meantime, I'm doing a few cosmetic improvements. I just sanded and applied the first coat of primer to the hood, as shown below. BTW, don't throw away your old shower curtains; they work great as drop cloths and masks when painting. I used an old shower curtain to cover the area under the hood, so that I could paint it in place. I think I'll order a few cans of Toro red paint this afternoon. Edited 2 hours ago by Blue Chips 3 Share this post Link to post Share on other sites
ebinmaine 75,105 #25035 Posted 1 hour ago @Bar Nuthin Here's a copy of the lost post with your measurements. Here's a plethora of pics of the ones I have. Not perfect. Usable. Savable. Yours for the freight. 1 1 Share this post Link to post Share on other sites
MainelyWheelhorse 2,170 #25036 Posted 1 hour ago Today, I had this out for a bit to tow a newly acquired used side by side about 10 feet into my fathers garage to charge the battery and look it over. That was after I had to put the right rear tire back on the bead on the tractor and pump it up because of a slow leak. Once it was ready it worked like a charm. 1 Share this post Link to post Share on other sites
Bar Nuthin 1,674 #25037 Posted 45 minutes ago 38 minutes ago, ebinmaine said: @Bar Nuthin Here's a copy of the lost post with your measurements. Here's a plethora of pics of the ones I have. Not perfect. Usable. Savable. Yours for the freight. If you want to ship whatever this one is in the last two pictures. You still have my address? 1 Share this post Link to post Share on other sites
