Ed Kennell
What have you done to your Wheel Horse today?
pfrederi
18 hours ago, Bar Nuthin said:
Finally got the ass end put back together on old Johnny Cash. Only one tiny drip that I think may be coming from the input shaft. But the transaxle case is looking good. And it moves, so there's still some hope!
One thing that has me puzzled is this parking brake lever. I may need to take the belt guard off of my C-120 and have a look at it. It's no wonder the parking pawl on all these early hydros are destroyed.
Check the bottom of the pin that rubs on the parking pawl lever.  I have had some that had a groove worn in them.
Edited by pfrederi
  • Like 4
  • Confused 1
Bar Nuthin
Thanks for the clear picture for reference!  :text-thankyouyellow:
Yes, there is a wear groove that I can address - but I need to lift the tractor and make a closer examination. My brake lever only appears to reach horizontal at its highest point. Perhaps I didn't have the pawl fully engaged with the gear.
My other thought is that the replacement pawl came from a D series - but on initial inspection, the geometry looks the same. The D-pawI is fatter, but it looked to all be on the top side not the gear side. I'll compare the two side by side on the same shaft and do a closer inspection. I guess it wouldn't take much to equal a few degrees.
IMG_4351.jpg.50f81c8e4149ce587438033936a63dcc.jpgIMG_4354.jpg.a12dd1141f9e8d52adf15a1b267edcfe.jpg
Edited by Bar Nuthin
Bar Nuthin
@pfrederi - BINGO!!! Turns out, when you align the holes for the roll pin, the D series pawl (bottom) is deeper at the gear side. It ends up being a little over an inch of travel difference at the end of the brake lever.
I'm not splitting this case again, so I'll try my hand at modifying an old brake lever to compensate for the difference.
IMG_4481.thumb.jpg.a71a56b471e5fcc25bbf7a28f8e82b68.jpg  IMG_4483.jpg.9ddb4bcc9d9cf3c1c515a8683fc5d6c5.jpg
  • Like 4
Bar Nuthin
I had brake lever that was badly worn, so I used it as a guinea pig and drilled an offset hole to change the angle. I put it as close to the old hole as I felt comfortable with. turns out that was too much adjustment. For now, I just ground down the face and it's working properly. I still don't know if this tractor salvageable or will become a part donor. If it turns out to be a driver, I'll fabricate a proper brake lever.
IMG_4484.thumb.jpg.d18ba246fa569271d941d0b5f6c34646.jpg IMG_4485.thumb.jpg.587e40ff2ec69d5407676c69abc93d5a.jpg
  • Excellent 8
Bar Nuthin
33 minutes ago, kpinnc said:
Where might a fellow search for that same muffler? I was contemplating a stack, but I like the looks of that more better!
kpinnc
It's just off a 300 series. I took it from a 312-H if I remember correctly...
Any 310/ 312/ 314 with a Magnum engine should be the same. Just be sure to get the elbow that goes with it.
Edited by kpinnc
  • Like 4
ebinmaine
Did you have to extend the pipe at all?
I've seen a couple of that newer style muffler on older tractors that were too close to the hood and affected the paint.
ebinmaine
5 hours ago, kpinnc said:
Time to make a new mess now I guess! :thumbs:
:ROTF:
Best part of the process!
kpinnc
You made me go look... and you are correct. I do not have to original adapter but rather a short nipple then 45 degree NPT elbow and a short pipe to clamp the muffler to. Also made an adapter to bolt the brace to.
It's probably an inch or two too far out, but I wanted to make sure I didn't cook the decals.
  • Like 5
ebinmaine
IMHO you're better off being there than  1/32 too close.
I remember blabbing with a people or two and deciding that the "safe" distance to a muffler from a properly running Kohler single cylinder was about an inch.
kpinnc
I'd go along with that.
These canister mufflers tied to a Kohler get mighty warm. Reminds me that one needs a guard... :rolleyes:
  • Like 4
MainelyWheelhorse
Today I had the C-141 out for a bit. the battery is still pretty strong but I’m going to keep an eye on that though.
ebinmaine
Got this Super Scooper  plow all set up!
  • Excellent 3
Bar Nuthin
Got the C-120 ready for the impending storm they're forecasting.  Since it's Thanksgiving weekend, I'm thankful that the hydraulic lift I installed is working great!
And I got the last of the leaves picked up, which frees up the C-141 in the unlikely event we get enough snow to hook up the snowblower.
  • Excellent 4
ebinmaine
C-120
Great to see the safety lights!
Ed Kennell
11 hours ago, WHGuy413 said:
fixed it with a stick
Great farmer repair... duck tape, binder twine, baler wire, and a stick.     :handgestures-thumbupright:
  • Like 4
Blue Chips
And that's the deluxe model tool kit. The basic kit is just a stick. :lol:
  • Haha 2
Bar Nuthin
Not going to plow snow until it slows down - 5+ inches so far. So I decided to engage in the official act of fiddle-farting.
When I pulled the lift cylinder off of "Johnny Cash" I decided to send it to @wheelhorseman and have it rebuilt. Today, I decided I might as well put it on my C-120 since the one I bush-fixed still leaves a few drips wherever I park it. May just send it in for rebuild also, since Lowell does such a nice job! :thumbs2:
While I was in the general vicinity, I remembered that I scored a "small" battery tray (wish I could find another) that needed a back-strap. So I did a little brazing and a shot of paint.
IMG_4496.thumb.jpg.8ffd52bb04e746e56d561b090ff9b827.jpg IMG_4497.thumb.jpg.6210fbe73cd012afdd7cd37f8e64e377.jpg IMG_4499.jpg.ceb7316107e51bd957795c06a037a796.jpg
  • Like 4
  • Excellent 2
ebinmaine
Maybe next time don't use bushes.
Get me some measurements.  Likely I've got one or 3.
  • Haha 3
