Ed Kennell
What have you done to your Wheel Horse today?
ebinmaine
59 minutes ago, squonk said:
I wonder if the "Soft Touch was an option. The wheel I have was original to my 76 C 160.
19 minutes ago, Racinbob said:
Besides not liking the feel it certainly is ugly too.
I don't think the 76 wheel was an option. I would guess that they had some 75 wheels left over and you know how they were. :)
I've read that one of the differences in 1974 and 75 between the B and C Series was the steering wheel.
Can't speak for 1976 and 77.
squonk
Posted (edited)
Mine has the flip fender and hood ornament it's not supposed to have also
Edited by squonk
Racinbob
The 74 & 75 B's were 4 speeds. The 76 & 77 B's were 8 speeds and basically a C series. That was the only two years like that. It was 76/77 that the steering wheels differed. Who really knows what was swapped over the decades. I can only be certain of my 76 since I purchased it new. :)
MainelyWheelhorse
Posted (edited)
Today I made a bit of progress on the Franken Horse. I had the pulley bored to 1 1/8 by my father and attempted to test fit. Still very tight so a little sanding may be necessary. Some parts are coming tomorrow and later in the week so more progress (hopefully) after work tomorrow and later in the week.
Edited by MainelyWheelhorse
  • Like 5
HyperPete
Got a comparison photo of the 1-0440 and the Mahindra.
  • Like 7
  • Confused 1
Lee1977
Form what my dealer said when I bought my new C-120 was, "this one has the soft steering wheel". From that and what we have seen here on Redsquare I think it was what ever was in stock at the time of the build.
pfrederi
Fished the rehab of some old cast iron Double D spindles.  New needle bearings, seals and cleaned repacked the ball bearings  (Used Petes favorite green Lucas grease :))
  • Excellent 8
Ed Kennell
18 minutes ago, OldWorkHorse said:
Well it's be a long time since I have posted here
:text-welcomeconfetti:back                 That's an impressive return.     :greetings-clappingyellow:
pfrederi
Looking very good
Glad you areback
Are you planning on using a PTO ??  If so what is the engine Spec number so we can see if she has a thrust bearing
OldWorkHorse
8 minutes ago, pfrederi said:
Looking very good
Glad you areback
Pto most likely electric got the engine out of a toro groundsmaster 117. Had a electric clutch on it at the time. Going to see about getting it back onto the c170. Just need to find it 1st :eusa-think:. As for numbers I'll get back to you with those shortly.
  • Haha 1
OldWorkHorse
ebinmaine
@OldWorkHorse
Love those full custom welded stacks bruh.
ebinmaine
3 hours ago, OldWorkHorse said:
always wanted a C-160 but I think @ebinmaine bought all the ones on the east coast 😂.
Cute.
:lol:
For the record.   All you clowns.....
I HAVE  a C160 Automatic here for him....
  • Haha 6
Wayne0
Well it's be a long time since I have posted here. Life got pretty busy and hectic last couple years but Im still into and working on wheelhorses in my spare time. I have recently started building what I call a C-170 always wanted a C-160 but I think @ebinmaine bought all the ones on the east coast 😂. Anyways here's where im at with this one. Acquired a KT17 and then went though it and bench tested it make sure would run. It did so now it's been mounted to a 73 chassis and the rear of the chassis has been modified to accept a rear wheel horse fuel tank. I also stacked it. I have to wire it all up make a battery box and then body work it paint it and new tires and go through the transmission, but for most part the entire tractor is there not just sorting it out and paint. Hopfuly will be done with this one soon because I have a 417-A for my next project. Never had a hydro wheelhorse so it will be a big learning curve! Hope everyone is doing well!
Love the stacks!!
ebinmaine
@Wayne0 and @OldWorkHorse
You guys gotta get to @JCM 's this Sept!
ebinmaine
Just in case anybody wanted to know. This damn thing is heavy. Approximately 115 lb.
Perfect front counterweight for a heavy towing tractor.
  • Like 5
Wayne0
WTF IS that??
  • Haha 2
ebinmaine
2 minutes ago, Wayne0 said:
WTF IS that??
Several years ago I went to pick up a counterweight for one of Trina's tractors. I wanted to add 40 or 80 lb or whatever to the front of it. We ended up doing a 45 lb belly weight on angle iron brackets. The belly weight was originally on a Kubota tractor.
We got to shooting the breeze as folks do and the guy said, what about this one?
The skinniest cylinder is about 3.25x12 long. The other skinny one is about 3.5 wide by 11.75 long. The short fat one is about 6.25 wide by 5.75 tall.
All steel.
Just some scrap steel that some person in the past had welded together.
At some point I should probably throw a more ambitious bead of weld on each side.
  • Like 4
OldWorkHorse
Posted (edited)
Ok i cant lie you do have that. And i appreciate that. I ment all the C-160 manuals on the east coast :lol: @ebinmaine
Edited by OldWorkHorse
  • Haha 3
OldWorkHorse
Already in the works to make it happen 🤞
  • Heart 1
OldWorkHorse
They must have welded that with thermite!
ebinmaine
I have a few.......
  • Haha 2
D_Mac
EB, my Simplicity had an original rear weight very similar to that. Mounted between the rear wheels. Weighed about 80 lbs.
