MainelyWheelhorse 3,170 #23626 Posted May 22, 2025 @953 nut there was no wiring in the C141 except for the wires to the headlights. There was no engine either. I figured I could use the 312 harness and take out what I didn’t need. I’m not too worried about the safety switches as the my 312’s seat switch is bypassed and my 308 is missing some switches or they are bypassed and I’ve had no issues. I’d like to get it running and moving then maybe put some in. 3 Share this post Link to post Share on other sites
Pullstart 71,483 #23627 Posted May 22, 2025 21 hours ago, Damien Walker said: Involuntary Smart Steer delete on my 520LXI. Nice work! When I did mine, I turned that rod end on the smart steer 90 degrees, drilled a hole in the frame side and snugged it up. Share this post Link to post Share on other sites
Pullstart 71,483 #23628 Posted May 22, 2025 (edited) I learned how to not to unload Edited May 22, 2025 by Pullstart 12 Share this post Link to post Share on other sites
Ed Kennell 47,754 #23629 Posted May 22, 2025 2 minutes ago, Pullstart said: I learned how to not to unload The first half went pretty well. Waiting for "The Rest of the Story" 3 Share this post Link to post Share on other sites
953 nut 70,076 #23630 Posted May 22, 2025 29 minutes ago, MainelyWheelhorse said: no wiring in the C141 except for the wires to the headlights. T he new to you 312 wiring should work well. Some of the switches on 312s had three wires with one going to the idiot lights on the dashboard. If this is the case cut them out before you begin the installation and it will be much easier to understand. 1 Share this post Link to post Share on other sites
Pullstart 71,483 #23631 Posted May 22, 2025 8 minutes ago, Ed Kennell said: The first half went pretty well. Waiting for "The Rest of the Story" Well, since my truck was stuck axle deep, I pulled one ramp out from the tractor, then managed to pull the rear of the tractor off the remaining ramp. We then pulled the truck out of the yard, and waited for the yard to dry out to get the tractor recovered from the impromptu mud hole. 7 Share this post Link to post Share on other sites
nylyon-(Admin) 9,133 #23632 Posted May 22, 2025 ¾” bearings came in the mail yesterday so this morning I replaced the spindle bearings on the 36” RD deck. Pretty easy to do when that’s the only thing you’re changing. I had an idler pulley which I was going to use, but it was too big, so I will fine a new one just so it’s all replaced at the same time. It is much quieter now! 5 1 Share this post Link to post Share on other sites
Sparky-(Admin) 26,621 #23633 Posted May 22, 2025 2 minutes ago, nylyon said: ¾” bearings came in the mail yesterday so this morning I replaced the spindle bearings on the 36” RD deck. It is much quieter now! Glad to hear (no pun intended) that the deck is getting some love! 2 1 Share this post Link to post Share on other sites
MainelyWheelhorse 3,170 #23634 Posted May 22, 2025 @953 nut or anyone else who knows what size is the hydro drive pulley for the C141 Automatic? TIA, I figured I’d keep the momentum going as I’m so close to getting it going. Share this post Link to post Share on other sites
Handy Don 17,634 #23635 Posted May 22, 2025 On 5/18/2025 at 11:27 PM, 702854boy said: I'm kinda thinking it broke from the stress of plowing but my dad @Chevy_59 thinks that something gave way internal and tried to become external. Agreeing with your Dad unless the drain plug was partially out and caught something like a big rock. Share this post Link to post Share on other sites
mrc 1,122 #23636 Posted May 22, 2025 Mainely Wheelhorse, hydro wheelhorses have a 5.25 inch diameter engine pulley. 2 1 Share this post Link to post Share on other sites
PWL216 1,309 #23637 Posted May 22, 2025 My 314-8 has had problems starting which I diagnosed to be the fuel pump. Installed a new OEM Kohler fuel pump, same issue. I then installed an electric fp and it starts right up. I made a cover plate for where the old fp mounted. So far, no issues, although I will be upgrading the fp to a better one than the cheap one I have on there now. Did a quick oil change while I was at it. 3 1 Share this post Link to post Share on other sites
8ntruck 9,368 #23638 Posted May 22, 2025 10 hours ago, Pullstart said: I learned how to not to unload I've posted this here many times: We gain knowledge from our own mistakes. We gain wisdom from other's mistakes. Thanks, Kevin for the opportunity for the rest of us to gain some wisdom. 2 2 Share this post Link to post Share on other sites
ebinmaine 81,050 #23639 Posted May 22, 2025 31 minutes ago, 8ntruck said: I've posted this here many times: We gain knowledge from our own mistakes. We gain wisdom from other's mistakes. Thanks, Kevin for the opportunity for the rest of us to gain some wisdom. You wouldn't BELIEVE the wisdom I could spread!!!! 2 7 Share this post Link to post Share on other sites
Pullstart 71,483 #23640 Posted May 23, 2025 1 hour ago, 8ntruck said: I've posted this here many times: We gain knowledge from our own mistakes. We gain wisdom from other's mistakes. Thanks, Kevin for the opportunity for the rest of us to gain some wisdom. One thing I excel at, is failing. And I make sure it’s known! 1 5 Share this post Link to post Share on other sites
SylvanLakeWH 32,783 #23641 Posted May 23, 2025 15 minutes ago, Pullstart said: One thing I excel at, is failing. And I make sure it’s known! Only if you consider "failure" like Thomas Edison did... a positive thing... Will I agree with your statement... Every failure adds knowledge and improves future outcomes... 3 6 Share this post Link to post Share on other sites
8ntruck 9,368 #23642 Posted May 23, 2025 While reading through the string on 520-8's, I had an interesting (Dangerous? Dumb?) thought - we've got a lever steer registry. Would there be any value of building a registry for 520-8's and another for C-195's? Both of these are low volume models. Comments? 2 1 Share this post Link to post Share on other sites
MainelyWheelhorse 3,170 #23643 Posted May 23, 2025 (edited) In the vein of gaining knowledge by mistakes have you ever loaded a tractor on a trailer not attached to a truck…..I did and I rode it a across a low spot in the driveway for about 8 feet …. No damage to me or the tractor but thats not ever happening again. 😬 Edited May 23, 2025 by MainelyWheelhorse 6 Share this post Link to post Share on other sites
Pullstart 71,483 #23644 Posted May 23, 2025 19 minutes ago, MainelyWheelhorse said: In the vein of gaining knowledge by mistakes have you ever loaded a tractor on a trailer not attached to a truck…..I did and I rode it a across a low spot in the driveway for about 8 feet …. No damage to me or the tractor but thats not ever happening again. 😬 My old house, the driveway was ever so sloped to the road. We had a 16’ trailer on my truck. Grandpa’s? I don’t recall. We borrowed a Tecuchi track loader from the farm he worked at for the weekend to do some digging for a retaining wall project. My brother was the equipment operator, so he was driving it the most. When it came time to load, he inched his way onto the trailer, and it lifted my truck’s rear axle off the ground. They started zooming towards the street. It was not a state highway, but for all intents and purposes might just ad we’ll be. He froze. I screamed at him to drive forward, and fast! Tongue weight matters. 8 Share this post Link to post Share on other sites
MainelyWheelhorse 3,170 #23645 Posted May 23, 2025 (edited) 8 minutes ago, Pullstart said: My old house, the driveway was ever so sloped to the road. We had a 16’ trailer on my truck. Grandpa’s? I don’t recall. We borrowed a Tecuchi track loader from the farm he worked at for the weekend to do some digging for a retaining wall project. My brother was the equipment operator, so he was driving it the most. When it came time to load, he inched his way onto the trailer, and it lifted my truck’s rear axle off the ground. They started zooming towards the street. It was not a state highway, but for all intents and purposes might just ad we’ll be. He froze. I screamed at him to drive forward, and fast! Tongue weight matters. @Pullstart Definitely, I was loading my 312 for JCM’s get together last year on a landscaping trailer. I didn’t think the weight of the tractor would affect the trailer that much. my father had to use his truck. Yeah, I was wrong, I got to about the end of the gate onto the deck. Then, the tongue picked up and off I went. Edited May 23, 2025 by MainelyWheelhorse 3 Share this post Link to post Share on other sites
WHX?? 58,330 #23646 Posted May 23, 2025 Practiced a rite of passage ... 3 6 2 Share this post Link to post Share on other sites
ineedanother 2,885 #23647 Posted May 23, 2025 10 minutes ago, WHX?? said: Practiced a rite of passage ... The koozie is a nice touch too. Gotta have'm if you wanna keep the red straw for next time. 3 1 1 Share this post Link to post Share on other sites
ranger 1,862 #23648 Posted May 23, 2025 10 hours ago, ebinmaine said: You wouldn't BELIEVE the wisdom I could spread!!!! What’s the old saying? “A man who has never made a mistake, has never made anything!”. 4 Share this post Link to post Share on other sites
ebinmaine 81,050 #23649 Posted May 23, 2025 8 hours ago, WHX?? said: Practiced a rite of passage ... You think that would work for driving out the pin of balance gears ⚙️ ? Share this post Link to post Share on other sites
ebinmaine 81,050 #23650 Posted May 23, 2025 9 hours ago, 8ntruck said: While reading through the string on 520-8's, I had an interesting (Dangerous? Dumb?) thought - we've got a lever steer registry. Would there be any value of building a registry for 520-8's and another for C-195's? Both of these are low volume models. Comments? Might be interesting. Also 1045 or the 1974 C160-8 Tecumseh engine tractors. Share this post Link to post Share on other sites
