squonk 48,209 #21701 Posted July 8, 2024 Worked on getting that tiny brake shaft seal out of the 551 trans. Poor eyesight and the heat didn't help. Decided to check out the new HEP Sales showroom and got a new sharp cobalt 1/16" drill bit. A couple of precision holes and then used the smallest wood screw I had. Grabbed it with my vise grip pliers and out it came. 7 5 Share this post Link to post Share on other sites
ebinmaine 80,893 #21702 Posted July 8, 2024 59 minutes ago, squonk said: out it came Well done Mike. What's HEP? Share this post Link to post Share on other sites
squonk 48,209 #21703 Posted July 8, 2024 8 minutes ago, ebinmaine said: Well done Mike. What's HEP? Local to NY Heating Electrical & Plumbing supply. H. E. P 1 1 Share this post Link to post Share on other sites
Sparky-(Admin) 26,489 #21704 Posted July 9, 2024 What have I done to my Wheel Horse today??? Nuttin!! It’s 98 degrees in the garage 4 1 10 Share this post Link to post Share on other sites
rjg854 13,400 #21705 Posted July 9, 2024 Lots cooler here, its 92 1 9 Share this post Link to post Share on other sites
squonk 48,209 #21706 Posted July 9, 2024 112° in the boiler room with both Cleaver Brooks boilers running non stop to maintain 65 PSI. Steam valve at 75% And my chiller was struggling. Another service call on the horizon for tomorrow. So 99° will feel like a cool breeze! 4 Share this post Link to post Share on other sites
formariz 12,381 #21707 Posted July 9, 2024 On 7/6/2024 at 7:03 PM, wallfish said: I don't remember if they put a plate under the H55 Teccys to raise the shaft for those tractors or not, but don't think so. Maybe Cas @formariz could shed some light about changing from a H55 to K91 and fitting the guard. There is a 1” difference in height from the base to the center of exhaust between the two engines, the h55 being taller. 6 Share this post Link to post Share on other sites
Monstrosity 1,153 #21708 Posted July 9, 2024 Well it was still hot in the sun but a slight breeze rolled through, I got the seat I picked up from big show 2023, finally mounted on the diesel. I used FASS diesel fuel pump brackets the rest of the GT14 tins and whatever hardware i had laying around.. Seat is not completely centered but itll work for the LIAPA show and pulls 4 5 Share this post Link to post Share on other sites
76c12091520h 4,290 #21710 Posted July 10, 2024 5 hours ago, Sparky said: What have I done to my Wheel Horse today??? Nuttin!! It’s 98 degrees in the garage Wow, as far as weather goes we're not that far apart and my garage thermometer said 68 degrees. .....probably because it's mounted on the same wall as the ac unit. 🤣 1 8 Share this post Link to post Share on other sites
76c12091520h 4,290 #21711 Posted July 10, 2024 Removed the Lawn-Boy push mower wheels from the deck on the 401 and installed a set of correct new old stock replacements: 10 5 Share this post Link to post Share on other sites
ebinmaine 80,893 #21712 Posted July 10, 2024 12 hours ago, Sparky said: What have I done to my Wheel Horse today??? Nuttin!! It’s 98 degrees in the garage 1 1 4 Share this post Link to post Share on other sites
Tractorhead 9,217 #21713 Posted July 10, 2024 12 hours ago, cafoose said: We can change if you wish... @Sparky wanna change???? here last week mostly 60-64F and a lot of Rain 🤬 today the first „warm Day“ with 79F. 😇 Missing the Time in the States with some more Summer 🤪😎 3 3 Share this post Link to post Share on other sites
lynnmor 9,050 #21714 Posted July 10, 2024 2 hours ago, Tractorhead said: here last week mostly 60-64F and a lot of Rain 🤬 today the first „warm Day“ with 79F. 😇 Missing the Time in the States with some more Summer 🤪😎 Nothing but hot and dry in the Big Show area. Grass is brown and crops are not doing well. I'm sure you would be ready for some cool and rainy weather after weeks of this. 1 Share this post Link to post Share on other sites
cleat 9,380 #21715 Posted July 10, 2024 Quite warm here as well but it rains every couple of days. It's like a tropical rain forest. Grass loves it, I have to Mow every few days. Mosquitoes also love it. We have a bumper crop right now. 4 Share this post Link to post Share on other sites
Tractorhead 9,217 #21716 Posted July 10, 2024 3 hours ago, lynnmor said: Nothing but hot and dry in the Big Show area. Grass is brown and crops are not doing well. I'm sure you would be ready for some cool and rainy weather after weeks of this. That‘s true Weeks with close to 100 Fahrenheit be also not too funny. I think both is worse the same way. Too much rain here on our site, the farmers can not mow because all the fields look like ponds. The fields can not carry a Tracta except of the mass of Moskito‘s we have here. I was today at a Farmer one valley ahead to buy some potatoes, they give me little from the first harvest this year. Not too much but so far good quality. But while harvest sunk the Tractor in the Field. Now they hope for a few day‘s with better weather. Share this post Link to post Share on other sites
pfrederi 21,216 #21717 Posted July 10, 2024 85.5 out in the shop area (putting an old blade on a snow horse have to push some crushed stone and small rocks don't want to mess up a nice blade. 73.9 in the work room which is where the K341 is slowly going back together 6 1 Share this post Link to post Share on other sites
Handy Don 17,554 #21718 Posted July 10, 2024 1 hour ago, pfrederi said: 73.9 in the work room Your energy budget sure is bigger than mine! 78 is the setting around here and we are glad to have it with a peak of 98 today. 2 Share this post Link to post Share on other sites
peter lena 10,082 #21719 Posted July 10, 2024 @KW88 refer to the original type / style of rear idler pulley on drive belt , changed out / removed /replaced same type size , with a bigger bearing , also cleaned out and re greased , hi temp 550 flash point grease . seen so much ROTATIONAL MOVEMENT EASE , over original tiny bearings , don't even think about not improving on it . any pulley I had with original tiny bearing has been replaced . actually a simple change out , same type / size , with a larger bearing , wide rubber side shields , clean out , regrease , get some steel tubing for a press in 3/8 " ID bolt on , solid smooth , makes for seamless engagement , TRACTOR SUPPLY often has similar pulleys with 5 / 8 " ID BEARINGS , you can also spray them red , pete 1 Share this post Link to post Share on other sites
ebinmaine 80,893 #21720 Posted July 10, 2024 1 hour ago, Handy Don said: Your energy budget sure is bigger than mine! 78 is the setting around here and we are glad to have it with a peak of 98 today. Our daily in the house temp is anywhere from 68⁰ (not often) to mid 70s over the summer. It's the dry air that's counts more though. We have a sleep setting for 60⁰.. I've learned in no uncertain terms over the last few years that temperature comfort is everything.... and non negotiable... 5 1 Share this post Link to post Share on other sites
8ntruck 9,330 #21721 Posted July 10, 2024 Mowed with Morgan the 14-8 yesterday. Today, nuthen. Got about an inch of rain last night and drizzled most of today as the remnants of Beryl passed over. 1 Share this post Link to post Share on other sites
Pullstart 71,356 #21723 Posted July 11, 2024 Lotsa horses in that picture… 1 1 Share this post Link to post Share on other sites
peter lena 10,082 #21724 Posted July 11, 2024 @TonyToro more often than not have found rotational / movement points , just do not move / function as they should . that freeing up detailing has made me a regular search / repair follower . rarely amazed to see a mechanical anything , that is not totally neglected for function , no oil on the stick , barely runs , every cable frozen in rust , PTO LEVER ENGAGEMENT is a screaming , binding effort , to get the , neglected bearings to move. marvel at the clutch replacements , what could possibly be resisting the movement attempt ? maybe the 12 related bearings , starved for the right lube ? also like the frozen cables , very basic stuff , 3/1 penetrating oil , does a very simple , recovery , also like a spring assist pull , makes for effortless function . also like the rusty / milky trans fluid , all basics for operation , yet remain hiding in plane site . perfer , oiled patina over rust , pete Share this post Link to post Share on other sites
Handy Don 17,554 #21725 Posted July 12, 2024 Finally had some minutes (the grandchildren were playing yard games) to replace the glass bowl on the fuel strainer, mount the mower deck on the 854, and get after the two week growth of grass. After 40 minutes mowing and the amp gauge hovering at zero, the new-to-me regulator I got at the show was holding at 13.3v. Adjusted it to 14.1v (righty tighty on the screw) and the amps jumped to positive as the battery was.taking more charge. I’ll leave it at this setting for a while and observe the amps and volts while I’m using it. 3 1 Share this post Link to post Share on other sites
