EB-80/8inPA 2,115 #20201 Posted November 5, 2023 9 minutes ago, Colby G said: Now I have a few more questions. 1: where is the tow valve located? 2: how do I close it? 3: would closing it make the shifter easier to move? Your unit doesn’t resemble mine, so I couldn’t say. I’m not sure who the resident Sunstrand expert around here is, but @stevasaurus knows a thing or two and seems always willing to help. Good luck! Share this post Link to post Share on other sites
stevasaurus 23,811 #20202 Posted November 5, 2023 I really know nothing about hydros. I would determine what horse your trans came out of and PM (Davoman)...he is the go to guy on Sundstrands. Share this post Link to post Share on other sites
Ed Kennell 47,091 #20203 Posted November 5, 2023 1 hour ago, EB-80/8inPA said: 1: where is the tow valve located? The tow valve is located at different places on the three different models of Sundstrands. Yours is the TEE handled petcock in the center of your last picture. Opening or closing the valve should not affect the friction on the motion control lever. Share this post Link to post Share on other sites
Colby G 248 #20204 Posted November 5, 2023 3 minutes ago, Ed Kennell said: The tow valve is located at different places on the three different models of Sundstrands. Yours is the TEE handled petcock in the center of your last picture. Opening or closing the valve should not affect the friction on the motion control lever. How would I make the motion control lever move? It moves a little bit then doesn't move any further. Share this post Link to post Share on other sites
Pullstart 71,144 #20205 Posted November 5, 2023 Found my tiller tensioner today. It’s only been MIA for 6 years! 1 6 Share this post Link to post Share on other sites
Ed Kennell 47,091 #20206 Posted November 5, 2023 51 minutes ago, Colby G said: How would I make the motion control lever move? It moves a little bit then doesn't move any further. Did it move OK before you installed the new transmission? Share this post Link to post Share on other sites
Handy Don 17,370 #20207 Posted November 5, 2023 12 minutes ago, Pullstart said: Found my tiller tensioner today. It’s only been MIA for 6 years! BARN FIND! 1 5 Share this post Link to post Share on other sites
Colby G 248 #20208 Posted November 5, 2023 (edited) 26 minutes ago, Ed Kennell said: Did it move OK before you installed the new transmission? The lever moved, but It doesn't move with the gearbox on. Edited November 5, 2023 by Colby G Share this post Link to post Share on other sites
Colby G 248 #20209 Posted November 5, 2023 Did I even put the motion control lever in the right spot? There's 2 holes in it and I put it in the top hole. Share this post Link to post Share on other sites
ebinmaine 80,445 #20210 Posted November 5, 2023 @Colby G Lots of folks are happy to help when able but you'd be better serving yourself if you started a thread with your own tractor and your own information. That way you can have quicker reference to finding the answers without all the information getting buried in several hundred pages of a general thread. 4 Share this post Link to post Share on other sites
TJ5208 1,841 #20211 Posted November 5, 2023 New seat installed 4 3 Share this post Link to post Share on other sites
Andy N. 2,806 #20212 Posted November 6, 2023 Hooked up the Agri-Fab lawn sweeper to the 418-8 and got to work! 6 loads in all ran through the chipper/vac and spread a cover mulch over the garden for winter. 6 Share this post Link to post Share on other sites
953 nut 68,736 #20213 Posted November 6, 2023 5 hours ago, Colby G said: Now I have a few more questions. 1: where is the tow valve located? Tow valve is the thing with a roll pin going through it near the bottom of your photo. 2: how do I close it? A pair of Channellock pliers should do the trick 3: would closing it make the shifter easier to move? NO 1 Share this post Link to post Share on other sites
Colby G 248 #20214 Posted November 6, 2023 I figured out the shifter finally! I had a dumb mistake, I put the motion control lever in the wrong spot. 3 3 Share this post Link to post Share on other sites
Desko 686 #20215 Posted November 6, 2023 Got the blower on the 520 hopefully it's enough to keep the snow away lol 6 1 1 Share this post Link to post Share on other sites
ohiofarmer 3,475 #20216 Posted November 6, 2023 I marked ( mow- raked) the leaves today. We had nice weather and the post surgery pain was tolerable so the leaves pretty much went to powder. Is there anything more beautiful than the green in the fall of the year when the bluegrass is charging up the root system for next spring? I kept at it until late sunset and the sky was a bright red fire 🔥. 3 Share this post Link to post Share on other sites
AMC RULES 37,259 #20217 Posted November 6, 2023 The beast got a carb to tank fuel line replacement today. 20231105_133038.mp4 1 6 Share this post Link to post Share on other sites
rjg854 13,329 #20218 Posted November 6, 2023 Good job Craig, had to do the same thing to my 16 Auto, Saturday. Opened the overhead door and the stable reeked of gasoline. Found that the gas filter had a crack in it. The original hoses were quite brittle. So as long as I was at it, might as well start at the tank and change it all. 2 Share this post Link to post Share on other sites
cafoose 3,820 #20219 Posted November 6, 2023 I fixed the return spring on the pedal today Like @ebinmaine says, "Use what you have!". 2 6 1 Share this post Link to post Share on other sites
ebinmaine 80,445 #20220 Posted November 6, 2023 4 minutes ago, cafoose said: I fixed the return spring on the pedal today Like @ebinmaine says, "Use what you have!". Niiiiice 1 1 Share this post Link to post Share on other sites
cafoose 3,820 #20221 Posted November 6, 2023 51 minutes ago, ebinmaine said: Niiiiice Took about 5 minutes 2 Share this post Link to post Share on other sites
ML3 2,485 #20222 Posted November 7, 2023 Bought my 654 in January. Used it all summer w/sloppy steering. Wheel turned almost 1/2turn before actually steering! Lol! Pulled roll pin out of fan gear w/my fingers. Definitely egged out. Drilled it all out & installed larger roll pin. Much better. Ordered plow scraper blade so I gotta get plow installed this week. 4 2 Share this post Link to post Share on other sites
Colby G 248 #20223 Posted November 7, 2023 I was wondering wether a 10hp diesel or a 13hp gas would be better in a charger 12 hydro sunstrand. I plan on building this tractor as a towing tractor and was wondering which would be better and if the 10hp diesel could power the hydro. 1 Share this post Link to post Share on other sites
kpinnc 18,916 #20224 Posted November 7, 2023 (edited) 1 hour ago, Colby G said: wondering which would be better and if the 10hp diesel could power the hydro. Hydros require continual higher revs to operate and to run cooler. The manuals call for a minimum of above half throttle minimum. So the answer to you question depends on whether the diesel can maintain 2000-ish RPMs or not. Running a hydro slower can damage them. Edited November 7, 2023 by kpinnc 3 Share this post Link to post Share on other sites
Handy Don 17,370 #20225 Posted November 7, 2023 11 hours ago, kpinnc said: Hydros require continual higher revs to operate and to run cooler. The manuals call for a minimum of above half throttle minimum. So the answer to you question depends on whether the diesel can maintain 2000-ish RPMs or not. Running a hydro slower can damage them. Seems like with careful pulley selection, either engine could keep the hydro input turning a good speed. Lotsa heavy machines use diesel-hydraulic drive (yeah, I know, hydraulic and hydrostatic are not the same but they work on similar principles). I’d think it’d be an advantage for diesels paired with hydro that the hydro can happily accommodate the narrow RPM power band of the diesel and still give full range of motion speed. @Achto runs a small diesel. Care to comment? 3 Share this post Link to post Share on other sites
