Lee1977 7,709 #19951 Posted September 14, 2023 (edited) 2 hours ago, Handy Don said: Yeah, the newer, 3-bolt attach-a-matic mid hitches are a nice improvement over the 2-bolt flavor for operating. Are the dimensions different vis-a-vie how implements attach? I only used the later model decks and the three bolt holes in the Raider frame are at the same place as the C's and the 300, 400 and 500.. I would have had trouble with the 42" deck with the wide tires and the 8 1/2" wide rims, but these rims have a 3 1/4" back set so the rear width 34" . These wheels and tires would need wheel spacers to run on anything that has the gas tank under the rear fender Edited September 14, 2023 by Lee1977 1 Share this post Link to post Share on other sites
TonyToro Jr. 2,506 #19952 Posted September 14, 2023 Mowed the yard today with my 310 and then gave it a bath after. 10 1 Share this post Link to post Share on other sites
WHX?? 57,384 #19953 Posted September 15, 2023 (edited) Mounted up a pair of Dees for use on Aunt B. Part of the crazy eights project. Rims were ready painted spares from the parts shed. Bearings be here tamara @Pullstartfrom the jungle. Can't believe that @Achto didn't have a shelve set in the bearing drawer... what's that about not finding good help these days...... To make matters worst he ordered 4.00 - 8 tubes for them last May. Went to install them and one was some funky one for a 13" rim?!?! So much for checking orders! Guess the jungle can’t find good help either... Edited September 15, 2023 by WHX?? 8 3 Share this post Link to post Share on other sites
Pullstart 70,662 #19954 Posted September 15, 2023 1 hour ago, WHX?? said: tamara see how good that works!?!? 2 Share this post Link to post Share on other sites
Achto 32,095 #19955 Posted September 15, 2023 1 hour ago, WHX?? said: Can't believe that @Achto didn't have a shelve set in the bearing drawer.. You must have checked the wrong drawer. I just checked & there are 2 unopened sleeves of ten in there. 1 3 Share this post Link to post Share on other sites
WHGuy413 2,859 #19956 Posted September 15, 2023 9 hours ago, The Freightliner Guy said: ive mounted the tank and it seems like itll clear imma test run it today Can’t wait for the update! 1 Share this post Link to post Share on other sites
Colby G 248 #19957 Posted September 15, 2023 Just got a 211-4 and was wondering what year it was and any other info I could get. 3 Share this post Link to post Share on other sites
WHGuy413 2,859 #19958 Posted September 16, 2023 (edited) Well late night in the garage. It’s 12:07 am and I just came in. Today started out with me being best man at my best friends wedding. He got married on the other end of the state. So lots of driving. Tomorrow was supposed to be tractor day with my buddy Carey (different friend) to work on his c-100 that had a stuck engine. Plans changed so when I rolled back into town he was already in the garage working on it. The guy who works on ugly green tractors helped him out with taking the flywheel off while I was gone and lo and behold it freed up! The corrosion around the stator and the mouse nest pieces that were in there must have stuck it pretty good. When I rolled back into town I taught him how to clean a carburetor, installed new points since his were rusted shut, re wired all the wiring to the points and to the coil test spun it and saw great spark so we added a test gas tank bypassing the fuel pump which I haven’t checked yet and she fired up. The exhaust is definitely full of marvels mystery oil that didn’t make it down to the piston when he filled it so next step either tomorrow evening or Sunday morning is to get it out of my garage and run it and let it burn off some of the oil. I still need to do final tuning on the carb but we are both pretty happy that it came unstuck as easy as it did (but because it was stuck it only cost him 100 for the tractor) after dreading the worst. I do love bringing these things back to life after they have been sitting for who knows how many years. Edited September 16, 2023 by WHGuy413 1 10 Share this post Link to post Share on other sites
ML3 2,392 #19959 Posted September 16, 2023 On 9/13/2023 at 9:31 PM, WHGuy413 said: I personally haven’t put one in but my friend installed a Kohler engine of similar size in his old Rj-58 (mine now). Unfortunately I do not have any pictures of it in it but he took the gas tank off and used the original tank under the hood. He also modified the air filter assembly to get it to fit under the hood. I'm gonna find out probably over the winter depending on work schedule. Have a pretty rusty Suburban with no engine that I got really cheap. Going to do the rat rod theme & already bought the Predator 212. Did a few modifications to Predator as you can see. I know fuel tank will have to be removed to clear shifter. Plant to relocate existing fuel tank or purchase one that will be able to utilize the original fuel tank location. 2 4 Share this post Link to post Share on other sites
TonyToro 1,189 #19960 Posted September 16, 2023 1 hour ago, ML3 said: I'm gonna find out probably over the winter depending on work schedule. Have a pretty rusty Suburban with no engine that I got really cheap. Going to do the rat rod theme & already bought the Predator 212. Did a few modifications to Predator as you can see. I know fuel tank will have to be removed to clear shifter. Plant to relocate existing fuel tank or purchase one that will be able to utilize the original fuel tank location. That little predator are very capable engines. My suggestion is to remove the fuel tank and get a cylinder shaped one and mount it on the front or rear of the tractor. I’m thinking would follow the rat rod look. 3 Share this post Link to post Share on other sites
ML3 2,392 #19961 Posted September 16, 2023 1 hour ago, TonyToro said: That little predator are very capable engines. My suggestion is to remove the fuel tank and get a cylinder shaped one and mount it on the front or rear of the tractor. I’m thinking would follow the rat rod look. There's a company in California that sells performance parts for Predators. They also sell minibike, go cart parts too. They have a nice cylindrical fuel tank that will work under the hood & utilize the stock fill location. However, I do like your ideas of front or rear mounting it also 🤔 Got a few other projects that are priority before I get to the Suburban rat rod 2 Share this post Link to post Share on other sites
Handy Don 16,939 #19962 Posted September 16, 2023 Finished fabricating a front weight for the 854 out of some ½” steel plate I picked up at Logan Steel’s bargain barn off the cutoffs and scrap pile for cheap. I think this will be enough for my purposes but, if not, I can add some more plate to the front. Should I offer to rent out that nice flat front for advertising space? 1 6 1 Share this post Link to post Share on other sites
Ed Kennell 46,556 #19963 Posted September 16, 2023 34 minutes ago, Handy Don said: Should I offer to rent out that nice flat front for advertising space? 3 2 1 Share this post Link to post Share on other sites
ebinmaine 79,639 #19964 Posted September 16, 2023 2 hours ago, Ed Kennell said: Share this post Link to post Share on other sites
peter lena 9,939 #19965 Posted September 16, 2023 @WHGuy413 your like to bring these back to life , statement and your marvel mystery oil , instantly makes me think , of a vital part of a recovery for me , run it in with a treated gallon of gas , heat it up , drop carb bowl , after getting hot , do an oil change like rotella 30 wt. also use https://www.amazon.com/Rislone-4405-Supplement-Concentrate- in my recovery , and then , add it to every oil change , easy directions on bottle , 2oz per QT of oil. the hot running time , will start to reduce oil burn and you will notice , oil coloring change , engine running easier / quieter . been doing this for years now , no engine smoke at all , engines runs easier , smoother . realize this is a you can't do that to many , my oils stay more stable , and do a better cleaning job . do it at every oil change / service , on my 3 horses , always trying something , this works , only a suggestion , also use lucas synthetic gear lube , smooth / very quiet . pete 1 Share this post Link to post Share on other sites
Handy Don 16,939 #19966 Posted September 16, 2023 (edited) 6 hours ago, Handy Don said: Should I offer to rent out that nice flat front for advertising space? 5 hours ago, Ed Kennell said: After testing today, I can feel the improvement, but it’s clear that I will need more weight there -- so another two ½” layers will get it up to 45 lbs, I think. Then I’ll have to add a handle to the top, as well! Meantime...Hey Karl @admin, would you be ok with having the Red Square logo on there? My grandchildren are also pushing for the tractor to have a name and to put that on there as well. Edited September 16, 2023 by Handy Don 1 Share this post Link to post Share on other sites
ebinmaine 79,639 #19967 Posted September 17, 2023 13 hours ago, Handy Don said: 45 lbs You'll be happier with that but may even desire more. Trina's 867 has a 40 lb weight on a couple pieces of angle iron. It certainly could be heavier. 1 Share this post Link to post Share on other sites
kpinnc 18,740 #19968 Posted September 17, 2023 On 9/16/2023 at 12:00 AM, WHGuy413 said: I do love bringing these things back to life after they have been sitting for who knows how many years. I think this is true for most of us! Well done! 2 Share this post Link to post Share on other sites
TonyToro 1,189 #19969 Posted September 17, 2023 On 9/16/2023 at 11:28 AM, Handy Don said: Finished fabricating a front weight for the 854 out of some ½” steel plate I picked up at Logan Steel’s bargain barn off the cutoffs and scrap pile for cheap. I think this will be enough for my purposes but, if not, I can add some more plate to the front. Should I offer to rent out that nice flat front for advertising space? Nice work! We love going to Logan steel. Always come back with more than we need. Most of the custom made parts on our pulling tractors come from there. 2 1 Share this post Link to post Share on other sites
peter lena 9,939 #19970 Posted September 17, 2023 @ tony Toro thanks for the lead on LOGAN STEEL , have to make the trip , looks like home to me , pete 2 Share this post Link to post Share on other sites
Handy Don 16,939 #19971 Posted September 17, 2023 5 hours ago, ebinmaine said: Trina's 867 has a 40 lb weight on a couple pieces of angle iron. It certainly could be heavier. Yeah, I’m thinking since I can easily remove it when doing mowing or other tasks where the weight isn’t helpful, I’ll aim for 50 lbs. I’ll be checking at Logan again on my next trip in that direction. 2 Share this post Link to post Share on other sites
Ed Kennell 46,556 #19972 Posted September 17, 2023 6 hours ago, ebinmaine said: You'll be happier with that but may even desire more. Trina's 867 has a 40 lb weight on a couple pieces of angle iron. It certainly could be heavier. I have 50# + the bracket on the front of my plow machines. 6 1 Share this post Link to post Share on other sites
Handy Don 16,939 #19973 Posted September 17, 2023 1 hour ago, Ed Kennell said: I have 50# I've been scanning for weights similar to that one. Astonishing what cast iron is going for these days. I have a set of 75 lb. concrete-in-plastic rear wheel weights in pristine condition but it doesn’t make sense to put one of those on the front. 🙃 2 Share this post Link to post Share on other sites
Ed Kennell 46,556 #19974 Posted September 17, 2023 41 minutes ago, Handy Don said: I've been scanning for weights similar to that one. These were part of a calibration system on a dynamometer that I replaced. The weights were calibrated and certified by the Pa div of weights and measures. You can see the round lead seal in the end of the handle. The handle holds lead shot that was used to fine tune the weight. Too nice to go to the scrap yard. 3 Share this post Link to post Share on other sites
Handy Don 16,939 #19975 Posted September 18, 2023 3 hours ago, Ed Kennell said: part of a calibration system on a dynamometer that I replaced If you come across anything similar, please drop me a PM! 1 Share this post Link to post Share on other sites
