Maxwell-8 4,371 #15151 Posted April 1, 2022 8 hours ago, Handy Don said: I can see a dent in the big axle bearing inner race and outer housing. Not sure what would cause it but please make sure it isn't affecting the bearing's rotation. Thanks for the comment, but it's shine from the oil The bearing looks fine in person 4 hours ago, WHX?? said: Gives me a thought @Maxwell-8.. ever run into it again just grind one side off. Then you can disassemble the diff. Still in the case half to get it out and chuck the axle in a lathe and take the weld off. How bad were the axles messed up a PO had to weld them on? Pretty bad, but I can save them. 9 hours ago, sjoemie himself said: If it bothers you that they're a little boogered-up you can send them my way and i'll skim them on the lathe for you. If you take care of shipping costs i'll do it for Thanks a lot for the offer! I have access to a lathe myself, I may try it. 5 1 Share this post Link to post Share on other sites
squonk 47,367 #15152 Posted April 2, 2022 Loaded ags and weights off. Summer dog muffin collectors on! 3 1 5 Share this post Link to post Share on other sites
kpinnc 18,740 #15153 Posted April 2, 2022 (edited) I have two teens (17 and 18) that still aren't driving. Covid was partially to blame, as NC requires driver's Ed completion before issuing a permit. Lockdowns meant no classes for almost 18 months. With that in mind, I'm gonna make sure my son WANTS to drive, and knows how to before we get there... Edited April 2, 2022 by kpinnc 5 9 Share this post Link to post Share on other sites
Handy Don 16,938 #15154 Posted April 2, 2022 1 hour ago, kpinnc said: I have two teens (17 and 18) that still aren't driving. Covid was partially to blame, as NC requires driver's Ed completion before issuing a permit. Lockdowns meant no classes for almost 18 months. With that in mind, I'm gonna make sure my son WANTS to drive, and knows how to before we get there... I applaud the driver's ed completion requirement for teens while recognizing the hit a lot of them took due to COVID restrictions. Our family rule was no driver test before age 17 and 1,000 miles of real supervised driving experience. Two of the three also did driver's ed. Worked for us. 3 2 Share this post Link to post Share on other sites
JoeM 10,086 #15155 Posted April 2, 2022 Worked on a set of rims to make up some duals. Welded the inside valve stem hole shut and drilled the outside. Some fresh paint today. 8 5 Share this post Link to post Share on other sites
Lagersolut 802 #15156 Posted April 3, 2022 Had some spring repairs on the 416-8 - went to get it out last weekend throttle cable was completely seized after that was repaired then noticed an exhaust leak - I don't like the Toro gaskets so I bought exhaust gasket material and Permatex exhaust gasket sealer . Gasket is in - new throttle cable cut to size in - side note this hanger 9 Z bend pliers is the cats meow for 19 dollars on amazon to do throttle and choke work ......just picked it up for this repair 8 2 Share this post Link to post Share on other sites
ebinmaine 79,637 #15157 Posted April 3, 2022 The BBT and I started clearing the new garden site of roots rocks and sticks. We hooked up the Ripper Spike on her 8(10)56 Military Tribute Tractor Millie and she dragged it around the area for awhile. We uprooted the roots. Dug up the rocks. Pulled out the sticks. After that she continued with the process by hand. We also took the plow and weighted rear tires off the 75 C160 Automatic. 7 1 Share this post Link to post Share on other sites
SylvanLakeWH 31,708 #15158 Posted April 3, 2022 @ebinmaine that ripper do hickey works pretty good!!! Go BBT!!! 1 1 Share this post Link to post Share on other sites
Andy N. 2,803 #15159 Posted April 3, 2022 Used the sleeve hitch and tiller lift chain on the 418-A to move th 60" deck from storage to the garage to get ready to install on the 520-H. IMG_1254.mp4 7 Share this post Link to post Share on other sites
ebinmaine 79,637 #15160 Posted April 3, 2022 6 minutes ago, SylvanLakeWH said: @ebinmaine that ripper do hickey works pretty good!!! Go BBT!!! It really does. I'd absolutely recommend one to folks clearing or maintaining an area. It hangs pretty loose so I'll be fabbing up some sort of way to tighten it up. 1 Share this post Link to post Share on other sites
Andy N. 2,803 #15161 Posted April 3, 2022 Also added new LED tail lights to the 520-H. 10 1 Share this post Link to post Share on other sites
Wheelhorse#1 1,956 #15162 Posted April 5, 2022 Got the deck sorted out out for the B80.Installed the Mule drive and deck.Ready to try it out on the back 40. Just waiting for the grass to grow now. Deck doesn’t match but that’s all the paint I had for now. 8 1 Share this post Link to post Share on other sites
WHX?? 57,384 #15163 Posted April 5, 2022 On 4/3/2022 at 6:53 PM, Andy N. said: Used the sleeve hitch and tiller lift chain on the 418-A to move th 60" deck from storage to the garage Now that there is working smart not hard. Not man enough to pick it up and carry it Andy? How's yer back theses days! 2 Share this post Link to post Share on other sites
sjoemie himself 3,117 #15164 Posted April 5, 2022 7 hours ago, Wheelhorse#1 said: Deck doesn’t match Matches the wheels though 5 Share this post Link to post Share on other sites
squonk 47,367 #15165 Posted April 5, 2022 (edited) Hauled and plowed brush with the 857 then took the blower off the C-160 and put the recycler deck on. It officially spring here at the Fake Chicken and Tweety Bird Ranch until I turn the water on to the garage. Edited April 5, 2022 by squonk 4 3 Share this post Link to post Share on other sites
rjg854 13,179 #15166 Posted April 5, 2022 Kinda did the same here, took the snow plow, chains, and weights off. Changed the front wheels with the roller chains over to regular turf tires. Changed oil and greased the tractor for a new season. Will mount the mowing deck tomorrow. Then the C160 will be ready for mowing duties. 3 1 Share this post Link to post Share on other sites
Andy N. 2,803 #15167 Posted April 6, 2022 12 hours ago, WHX?? said: Now that there is working smart not hard. Not man enough to pick it up and carry it Andy? How's yer back theses days! Not all of us are lucky enough to have a FEL in our arsenal. At least not yet 😉. Back is bad enough as it is without manhandling that thing. Plus my backyard is a muddy mess right now thanks to all the rain we've been getting lately in IL and the front of the deck just kept digging in. 1 1 Share this post Link to post Share on other sites
kpinnc 18,740 #15168 Posted April 6, 2022 13 hours ago, WHX?? said: Not man enough to pick it up and carry it Andy? At 300+ lbs, I don't know two who are man enough. It's all I can do to move mine with handtrucks. 4 1 Share this post Link to post Share on other sites
rjg854 13,179 #15169 Posted April 6, 2022 Hung the mowing deck on the C160 today and adjusted it so it's ready for the season. Before After Then changed the oil and greased the Commando 8, and hung it's deck. 4 4 1 Share this post Link to post Share on other sites
ebinmaine 79,637 #15170 Posted April 6, 2022 @rjg854 Hey what's all that green stuff ?? 1 Share this post Link to post Share on other sites
rjg854 13,179 #15171 Posted April 6, 2022 It's called grass Problem was it looked like that most the winter too 1 Share this post Link to post Share on other sites
ebinmaine 79,637 #15172 Posted April 6, 2022 4 minutes ago, rjg854 said: It's called grass Problem was it looked like that most the winter too We have a coating of brown stuff. 😀 1 1 Share this post Link to post Share on other sites
kpinnc 18,740 #15173 Posted April 7, 2022 2 hours ago, ebinmaine said: We have a coating of brown stuff. 😀 I'll trade ya! I can't complain really. This year, I actually got a break from December to February. Usually I mow year round. 2 Share this post Link to post Share on other sites
TJ5208 1,841 #15174 Posted April 8, 2022 Got some cleaning done today. 6 1 Share this post Link to post Share on other sites
Chestnut 315 #15175 Posted April 8, 2022 A couple of days. Getting ready for the spring change. Worked on the 520H snowblower and posted on another thread. Gathered parts and fluids for oil changes and other maintenance on all the tractors and other small engines. Got 10 gallons of fresh 90 octane alcohol free. Batteries back in the "summer tractors" Gassed and started two of them. But the most productive thing all week was to tell my wife that spreading out the "roof snow" in front of the winter storage shed would help it melt faster so I could get tractors out and help clean out the gardens and turn over the compost. After rain tomorrow should be clear sailing. 3 2 Share this post Link to post Share on other sites
