ebinmaine 80,087 #13476 Posted November 10, 2021 19 minutes ago, WHX?? said: food Jim Budd. It's... Food. 1 Share this post Link to post Share on other sites
ebinmaine 80,087 #13477 Posted November 10, 2021 The Paint Department is at it again. I have 4 of these 25ish lb weights and 4 of the 65 lb bolens weights to be made WH red. First weight, first coat. 6 2 Share this post Link to post Share on other sites
WHX?? 57,644 #13478 Posted November 10, 2021 12 minutes ago, ebinmaine said: Jim Budd. It's... Food. Yep ... And I can hear you canaries in a restaurant .... I'll take the eggfoo Yung with a side of 80/90 drain oil... 6 Share this post Link to post Share on other sites
ebinmaine 80,087 #13479 Posted November 10, 2021 Just now, WHX?? said: Yep ... And I can hear you canaries in a restaurant .... I'll take the eggfoo Yung with a side of 80/90 drain oil... @JCM You in? I'm in... 1 1 Share this post Link to post Share on other sites
WHX?? 57,644 #13480 Posted November 10, 2021 15 minutes ago, ebinmaine said: to be made WH red. Nice to see you got yer color blindness issue fixed ... told you a good optometrist could fix you up! The 25 lb weights ain't much but I think you might be able to stack them on the inside? Never tried it. Them Bolens weights do fit a nice. 4 Share this post Link to post Share on other sites
ebinmaine 80,087 #13481 Posted November 10, 2021 30 minutes ago, WHX?? said: The 25 lb weights ain't much but I think you might be able to stack them on the inside? Never tried it. Them Bolens weights do fit a nice. Definitely agree on the Bolens weights. I've used them on the outside of our Wheels before. Good fit. The holes in the middle of these 25-pound weights are large enough to put a hub through so they will bolt to the inside of a wheel okay. What I'm not sure about yet is whether they will clear the 2 inch thick aluminum spacers I have to use on my heavy weight rims and tires. 2 Share this post Link to post Share on other sites
Lane Ranger 12,071 #13482 Posted November 10, 2021 (edited) Began working on gas tank install, hood install and steering set up yesterday on my long delayed RJ build for my brother David. It is coming along pretty well! Motor is a good 4 hp Kohler I bought three years ago. This RJ was $60 when I bought -however in need of some love. It was a very rusty mess. I was originally going to use a hood that had been cut at the back for a bigger motor - but I just could not bring myself to do that after looking at it. I had two RJ hoods melded to make one good one. Transmission still a lit RJ le tight and I think it just needs to be run. The honing of the brass bushings in the rj transmission rebuild process is very important to smooth operation of the axles. I did not rebuild this one but I know it had all new brass bushings , bearings and seals when I bought it last year. This makes about the fourth RJ I have redone to full operation. One more still stored for rebuild awaits. The last picture is what I started with last April. At $60 I just could not say no. Edited November 10, 2021 by Lane Ranger 4 14 2 Share this post Link to post Share on other sites
AMC RULES 37,259 #13483 Posted November 10, 2021 Looks great! What color red Lane? 3 Share this post Link to post Share on other sites
Lane Ranger 12,071 #13484 Posted November 10, 2021 26 minutes ago, AMC RULES said: Looks great! What color red Lane? Regal Red but a professional job with painthardner applied over grey primer. 4 1 1 Share this post Link to post Share on other sites
AHS 1,698 #13485 Posted November 10, 2021 12 hours ago, JCM said: Looks like hot mustard at the Chinese restaurant @AHS Goes good with the pork fried rice. Ok, that is stamped in my mind right now!! Yuck! However I do like Chinese food! 2 1 Share this post Link to post Share on other sites
Lane Ranger 12,071 #13486 Posted November 10, 2021 This is what I started with in April 2020. At $60 I could still not pass it up! The last photo was where I was last June. I could not get over the half hood . I think it was Craig that got me motivated to get a better hood. So I bought two to make one good one. 7 4 Share this post Link to post Share on other sites
WHX?? 57,644 #13487 Posted November 10, 2021 (edited) 13 hours ago, ebinmaine said: whether they will clear the 2 inch thick aluminum spacers They should ... all my spacers are real close to the diameter of a hub... maybe just a hair bigger. Edited November 10, 2021 by WHX?? 6 1 Share this post Link to post Share on other sites
ebinmaine 80,087 #13488 Posted November 10, 2021 Just now, WHX?? said: They should ... all my spacers are real close to the diameter of a hub. Excellent. Seems to me that's about what mine look like too. Share this post Link to post Share on other sites
rjg854 13,269 #13489 Posted November 10, 2021 Today was pretty much the same as yesterday this time I got the 16 auto out, which is my dedicated snow blowing tractor. Changed the transmission oil and filter and engine oil, greased everything and she's ready for the inevitable. 11 5 1 Share this post Link to post Share on other sites
pfrederi 20,994 #13490 Posted November 10, 2021 (edited) 23 minutes ago, rjg854 said: Today was pretty much the same as yesterday this time I got the 16 auto out, which is my dedicated snow blowing tractor. Changed the transmission oil and filter and engine oil, greased everything and she's ready for the inevitable. Like the wheels Most of your blowing on gravel/dirt??? Are the adjustable for height Edited November 10, 2021 by pfrederi 1 Share this post Link to post Share on other sites
rjg854 13,269 #13491 Posted November 10, 2021 (edited) 47 minutes ago, pfrederi said: Like the wheels Most of your blowing on gravel/dirt??? Are the adjustable for height Yes I have a 1/4 mile gravel driveway, and I can adjust the height of the blower with the wheels. They mount to the blower just like the skids would. Edited November 10, 2021 by rjg854 Add picture 8 1 1 Share this post Link to post Share on other sites
peter lena 9,993 #13492 Posted November 10, 2021 @AMC RULES that honda set up looks awesome ! think its the way to go , for a repower , solid performance, did a total clear vinyl fuel rated hose change out today , on a 91 ,c12 . hose was getting hard , ran it thru a spiral wrap , wire protector , with hanger mounts , for a no chafing fit. have an ignition switch wire harness coming in , to cover erratic charging. found a split and somewhat fried connector . just staying after what ever , that honda looks like it was made or it , pete 3 1 Share this post Link to post Share on other sites
ebinmaine 80,087 #13493 Posted November 10, 2021 Busy day today for the BBT, her mom and me. I did a dump run earlier in the day. Then I got the 1975 C160 Automatic back up and running after fixing some PO things and replacing the carb with a rebuilt Kohler #30 I had on hand. Them 2 chicks were on the go all day as usual. Trina J. B. Welded and painted the belt guard and engine pulley on Millie and got that going too. It now shifts properly and has a much more user friendly speed. They also pulled some logs in to be cut up. They moved a good amount of leaves using the mid mount grader blade on her 867 Pigpen tractor. All 3 of us spent some time blowing leaves with either the new Craftsman B215 gas blower or the Ridgid shop vac/blower gifted us by the excellent @wallfish a few years ago. Yeah buddy we're still using that! After that Trina graded the driveway. 7 4 1 Share this post Link to post Share on other sites
adsm08 4,903 #13494 Posted November 10, 2021 I fed mine some peanut butter Sunday. Worked out pretty well. 1 1 Share this post Link to post Share on other sites
wallfish 20,384 #13495 Posted November 10, 2021 29 minutes ago, ebinmaine said: Yeah buddy we're still using that! 1 Share this post Link to post Share on other sites
ebinmaine 80,087 #13496 Posted November 11, 2021 2 hours ago, adsm08 said: I fed mine some peanut butter Sunday. Worked out pretty well. Yours burn peanut 🥜🥜 butter ???? Share this post Link to post Share on other sites
nyquil junkie 333 #13497 Posted November 11, 2021 (edited) It takes a beating and keeps in ticking... 3 days of moving tons of sand and 25 RR ties to make a solid cow walkway so they can get to their feeding station. No more muddy entryway. I couldnt have done it without this thing. We have 2 skid steers and a backhoe, but the skidders rip up everything under them and they are heavy. This thing is light and you can do work faster with a lighter footprint. I should put duals on it just for a bit of floatation/traction but it does fine the way it is. What did I do with my wheelhorse today.... um, got it really dirty. lol Edited November 11, 2021 by nyquil junkie 9 8 Share this post Link to post Share on other sites
AMC RULES 37,259 #13498 Posted November 11, 2021 If that thing was picking two railroad ties at once, that's pretty impressive in and of itself. 4 Share this post Link to post Share on other sites
ebinmaine 80,087 #13499 Posted November 11, 2021 4 minutes ago, AMC RULES said: If that thing was picking two railroad ties at once, that's pretty impressive in and of itself. Agreed. I can't even do that.... 4 Share this post Link to post Share on other sites
JoeM 10,121 #13500 Posted November 11, 2021 @Lane Ranger Front tire mfg? Front wheel color? looks good! 1 1 Share this post Link to post Share on other sites
