Rob R
Snow Plow Scrapper Blade
Rob R
Have  a C-81 with a 48" Snow Plow, the current Steel Bottom Scrapper  Blade  is on it's last season..... I have noticed as of late that quite a few folks are installing the POLY blades.....  I plow a 100' macadam driveway and my concern and/or question is how well and how DURABLE are these blade. I did install feet on my existing steel blade plow (see pics) to limit the normal wear.   Thanks for you input
  • Like 8
GlenPettit
Rob:
This will be the 3rd season I've had them on and there is very minimal wear (year #1 was only about 10 hours of use, year #2 about 25 hours and this year about 10 hours so far), the wear is just noticeable, I feel I should get 7-8 years of good use at this rate, and then I reverse the blade for 7-8 more years of use.  I have a 90% asphalt drive, 10% concrete -- the kind of drive you have will make a difference.  I think the asphalt is the least worst (less wear) and that a rough gravel drive may be the worst,  I have 5,000 square feet of drive and plow right down to the asphalt surface, -- but notice that you use skids which would cause almost no wear since you're only plowing snow and not riding on a hard surface.
Glen
  • Like 5
bigplow1
I use 3/4" rubber stall mat cut twice the width of my steel cutting edge holes that line up with the cutting edge drilled I. The center so about 1"hangs past on top and bottom sandwich that between your plow and cutting edge works great when you wear out 1 side you just flip it over I get a couple years out of one normally and I plow asphalt and gravel and the mats are 4ft by 6ft so you get a lot of them out of 1 and for about 30 bucks
  • Like 7
emdmat1981
I went with the poly blade this year as well and probably have about 5 hours on it so far.
Plow a few of the neighbors which is a mix of new and old (uneven and sometimes broken up) blacktop.
Very minimal wear ... would project I can get about 5 years or so out of it ...   and then I'll flip to the other edge for another 5.
  • Like 4
Rob R
Sounds good what is the best way to cut the material and cut it straight?  Thanks
bigplow1
I use a straight edge I have a 60" steel ruler and a sharp utility knife take your time usually takes about 3 to 4 cuts with a sharp blade I usually put in a new one
  • Like 4
JERSEYHAWG /  Glenn
Where do we get the poly blades again. I forgot about them, they might work as a snowblower scrapper bar to.
Thanks,    Glenn
  • Like 4
Rob R
Thank you bigplow1, will give this a try........
Tankman
Never used this blade but, interesting. :think:
Given to me, an old timer moving South to a "NO SNOW" zone.  :icecream:
Edited by Tankman
  • Like 5
P3x
I purchased a Poly Blade off eBay and installed last season - or maybe he year prior(?). Live in MA and have not had too much snow since it was installed and looks like it has worn quite a bit. Went with it to avoid damaging the asphalt and it has done a good job in that respect. It came pre-drilled with one edge (top as installed) not having enough meat between the bolts and edge to flip and use again.  Bought some 1/2" conveyor belt strips to try when its completely worn.
Discussed wear strips on another thread a couple of weeks ago and one member do not recall the name/handle (Old-timers disease kicking in...).  He cut strips from old tires to use on his blade.  Sounds like an excellent idea - very cheap and should not damage the D-Way surface..
  • Like 4
shallowwatersailor
I have used both rubber and UHMW. Originally I bought a rubber horse mat, then cut a strip to bolt onto the blade. Use the blade's wear strip to use as a template and then sandwich them to the blade. It worked pretty good and didn't leave marks. I use to call it my 48" squeegee. But then I sold that dozer blade so decided to try a UHMW edge for the other blade.
For that I ordered a 48" x 4"  x 1/2" black UHMW remnant on eBay less than half what are sold for snow blades. The white UHMW is virgin so the black must be recycled. Used the wear strip again as a template and sandwiched them too. I also cut about a 45 degree angle at the very ends to prevent a snag. Three seasons and it is showing some wear. But I find that it tends to "ride" on the snow so doesn't scrape as well. I think part of the problem is that the front edge is at a positive angle with the rear edge doing the scraping. It really needs to have the edge planed so that it bites at the front. After taking the photo, it appears that is how it is wearing.
  • Like 4
Eric Friedrichsen
I used a 1/2" x 4" poly edge on a 48" blade that I installed before last season began on my 414/8.  I have a 450' asphalt drive
with parking area and turn around.  I plowed all last winter and 7 times this winter (so far) and the blade edge shows NO perceptible
wear (just a little rounding on the outside corners).  Before installing the edge I chamfered the the cutting edge with my wood
plane so that it mated at the correct angle with the driveway surface.
I am very pleased with the poly edge. It doesn't wear and it doesn't scratch.  The only negative is that it looks a little klutzy being
1/2" thick.  For me that is OK as performance trumps looks.
I also use the rubber tire chains modified to 2 link spacing.  I have also found them to work well. as they don't scratch the drive.
I have found the traction to be a little less than steel chains when pushing up the hill on the drive.  The slipping of the rubber chains
does not mark the drive and the straps show little evidence of wear.  I used to use steel chains and they really marked the drive
when slipping.
Conclusion: I am very satisfied with the poly blade edge and the rubber tire chains.
Eric
  • Like 6
GREYGHOST
Thanks John, that gave me an idea for my Gator. Oops, wrong color.
emdmat1981
When I did order mine on eBay I ordered "UHMW Polyethylene Plastic Sheet BLACK 1/2" x 4" x 48".
If you order two of them the charge to ship the second is only a few bucks.
I think the pair will last me a decade or two given the light wear to date.
Tankman
Of course you know, "Red is for the blood we shed."  ;)
GlenPettit
I used large washers on the front, but putting the worn original wear bar in front would be a smarter idea like you did, more holding power and a great recycling idea.
Edited by GlenPettit
Rob R
Thank you Glen, it was suggested but the other reasons I planned on doing this was support and I can tell at a glance how much the Blade is wearing and when it is time to reverse it.... also you do NOT have square the holes on the Poly since the old wear edge already has this done.
Edited by Rob R
Tankman
I always go to Lowes for hardware.
Stainless steel and Never-Seez on the threads.
When done plowing snow, blade down on a block of wood.
I often spray WD-40 (water displacement) along the top edge of the scraper edge. Allergic to rust. :handgestures-thumbupright:
Sarge
Setting that blade down on a block of wood is a good habit - I had one of mine freeze onto the shed floor. The hydraulic lift didn't care - it just grunted a bit and ripped out a section of the plywood like nothing, lesson learned. If not a heated space they can freeze down to concrete as well - that's even worse and you'd be surprised at how tough it is to break it loose.
Sarge
GREYGHOST
The other benefit to lowering your blade down on a wooden block. If you have a floor that you don't want a Rust Stripe on, this will prevent that..I put an Epoxy floor coating down, and its really tough. But I haven't found anything that will take up that gust. I even tried Muratic Acid. Didn't hurt the coating, and had no effect on the rust stain.
Sarge
Tried Lime Away ? It will usually remove stains - but on epoxy if it soaked in below the hard top surface, it's probably permanent. Once drawback to those coatings , some things can penetrate them although I wasn't aware steel rust could do that - I'll remember that one as a buddy is about to coat a large shop floor this spring.
Sarge
edgro
I have been just leaving my blade up. Is that not a good idea? I put old newspaper underneath for when it melts
Sarge
On a manual lift - no problem other than stress to the lock parts on the handle. On hydro cylinder lifts - it's recommended not to leave implements hanging and holding that weight against the check valves, hoses and seals.
Sarge
Alrashid2
Old discussion but wanted to add that this is what I just did!
My driveway is old asphalt, with lots of uneven, crumbling spots and cold patches galore. Wanted to plow it but don't want to wreck it either. Installed a Dial a Height kit which definitely helped but because of the unevenness and incline, I was still scraping spots.
Bought a 3 ft x 4 ft x 1/2 inch horse stall mat at TSC for 40 bucks and cut a strip. My steel wear bar is 2.5" wide so I cut my stall mat to 4.5" so I had an inch hanging off either side. Used steel wear bar as a template to drill holes through mat.
Installed and we'll see if it works! One word of caution: don't over tighten! I bought new, longer carriage bolts and decided id grab Nylock stop nuts too just in case. Well, all it took was me hand tightening with a normal sized ratchet for the wear bar and plow to start warping! Couldn't believe steel would bend so easily. This happened because the stall mat isn't solid like plastic and was compresssing. Took it all apart and hammered the plow and bar back into shape.
Used the Nylock nuts and just barely tightened instead of torquing them down hard. No warping this time. Hopefully the nuts hold! If not I'll use some loctite next time.
  • Similar Content
    • rustyedge1
      By rustyedge1
      Need a condenser for engine shown in photos 8 hp Kohler. Any venders carry them on this site ?
      All help appreciated..Have PayPal or can send check..
    • WheelPuke
      By WheelPuke
      I have my 25A fuse blowing every time I put a new one in the slot. The old one was burnt up when I got the tractor put this year. It sat for a year with a dead battery. I stopped using it as much because the transmission is clattering pretty bad when taking off on second or higher. I had to replace the clutch belt a few years ago and couldn't get an OEM. Not sure what is the problem there that's another issue though.
      I have checked the wiring and patched the worn spots where it could be grounding out. The fuse blows as soon as there is power to the system with the ignition off. I'm at a loss of what to check for at this point. Any input from someone who has had this issue would be appreciated. I'm not sure what these units are in the photos but do not know how to test them for a failure. They are directly in loop with the battery and the ignition loom looks to run into that 25A fuse.
    • Redtickuleez
      By Redtickuleez
      Hello gentlemen!!! I recently bought a d180 with loader and backhoe. Im looking for serial number.. there is a plate under the steering wheel but its been pajnted over and i can make it out. Can y'all tell me another location and was this tractor pruchased originally with these attachments and any info would be greatly appreciated... Thanks fellow Wheel Horse enthusiasts !!! !! !!!
    • Aaron Coffman
      By Aaron Coffman
      Hi Red Square Community,
      I am looking into purchasing the below pictured "POND" Walk Away. The unit itself has the cast in “POND” on the chain reduction housing. The two main things I am looking to learn are what value is typical for these to sell for. This one has a Briggs & Stratton model “N” engine. It runs and drives, but the throttle linkage needs some adjusting. It comes with a cultivator and plow implement.
      Secondly, I was wondering if there is any way to determine what year specifically this Pond is from. The seller believes late 1940s and not 1950s. I am new to these machines, so I am looking for some guidance. Thank you in advance!
    • ohiofarmer
      By ohiofarmer
      i know that there is ebb and flow with market conditions, but I have been seeing bargain 520 and c-160 prices more common. I recently saw a c-160 like model on a place other than here that was close by, but i did not get a chance to see it as I was still on a medical tether getting care. i say c-i60 like model because it was a series of numbers like 4455 or somesuch .Tractor had the k series engine clearly a sixteen HP and came with a decent looking deck and pusher blade. i called my buddy Jay and told him for the $250 ask , he better hustle after it. i really do not know if he did.
        I also have been seeing 520s and such lower than I can remember as well as the D series..My theory is that people experiencing paycheck to paycheck living are increasing in number.
      You even are seeing a lot more older trucks like square bodies and especially big blocks than you did before. we used to see this a lot in new trucks when fuel prices hit records.
      i am not claiming expert status on this, but it seems to be trending this way one county next to indiana and 90 miles North of the Ohio River.
       Tell me what you are seeing out there and what you think.
           Edit:  Jay and I ran up to buy Bob Ellison's tractor in MI.  Bob was very nice to deal with and included his "last seat"   I got super lucky buying my first C-160 that did not start and another one shortly dropped in to keep it company. The tractor described above was listed for only two days and was gone
