Similar Content
By DeltaNu1142
I bought a 5xi package yesterday including some attachments I'm not going to need:
4' plow, model # 79355 - in great condition, very minor surface rust on crossmember and back side of blade. $250 48" mower deck with blower and bagger - in good condition, working when removed from tractor yesterday. Previous owner said it never clogged on him. Some surface rust on deck and one 2" hole near the center. $300.
I'm open to offers and interested in trades! I'm looking for a 2-stage snow thrower, p/n 79366. Maybe tools, etc.
Available for pickup--let me know if you have any questions. Thanks!
Here's a photo of the deck that's included. It's got some rust holes, but functions perfectly. Most of the price here is wrapped up in the blower & bagger:
By Bbo44
SOLD SOLD 520xi with air cooled 20hp Kohler - tractor in great shape and solid. Everything works. Engine was removed a few years ago and cleaned of grass buildup. New head gaskets and PTO seal a few years ago. Engine showed a decent amount of wear but runs strong and fires right up. Didn’t like the wear and needed a zero turn for my property. Would not hesitate to mow with it right now. 1200 hours. Have original paperwork. New air filter, fuel filter, fresh oil & filter. It’s been mowing 3+ acres for 20 years.
52” side discharge deck complete. Currently mounted on the 520xi- solid, welded/patched cracks and holes. Front roller broken and patched, newer belt. Was just removed and cleaned. Welded chips in blades, but never finished sharpening. Solid deck, decent life left.
48” wheel horse complete plow for 520xi 79355. Was used for snow. In great shape.
48” wheel horse plow incomplete for 300 series garden tractor. Was used for parts. Not sure what it is missing but what’s there is very solid.
MUST TAKE ALL. WILL NOT SEPERATE. Won’t answer if you ask. $750 CASH for everything. Only thing I’d consider selling separate is the 48” incomplete plow for 300 series. Will not deliver.
By Donavon
Need ideas to convert my 1054 A Frame plow into a snow blower
Any idea's?
By RJ Hamner
Will the plow I am using on my C121 and C160 work on a 876?
or is the plow frame different?
Thanks
Bob
By Nuzmuz
Just wanted to show a modification I did to my 1990 310-8. I recently picked up a 36” tiller for my horse and I tried it out on my new garden area. After hitting a rock, it knocked one of the axle brackets open dropping the right side of the tiller. On a manual I viewed, it had clevis pins to hold the lever in, but my bracket did not have them. I drilled a 1/4” hole through on each lever and mounted a 1/4” clevis pin and hairpin cotter to reinforce the lever. I read on another post to just tighten the bolts on the levers, but I think this will work a little better. Hope this helps someone!
