SPINJIM 1,997 #1 Posted November 22, 2017 (edited) Has anyone tried to use the Manual Lift or the Electric lift for the heavy 2-stage snow blower ? I have a 417-8 with electric lift, but the 2-stage blower is so heavy, I'm afraid of breaking the electric actuator, even when using the Lift Assist spring. I ran a single-stage blower using the electric lift last winter, but I just picked up a 2-stage. The beast weighs about 350 pounds. Can't imagine a manual lift would even be possible with that weight. Thanks, Jim Edited November 22, 2017 by SPINJIM Share this post Link to post Share on other sites
squonk 47,339 #2 Posted November 22, 2017 Can't imagine even trying it myself. I hurt my back trying to lift a 10"moldboard out of the ground. Another issue is the condition of the crank arm. winter is the season of stories of broken crank arms on our beloved horsies. 2 Share this post Link to post Share on other sites
Ed Kennell 46,529 #3 Posted November 22, 2017 Where's Eric @ericj ? I'm sure he must have at least one 2 stage on a manual lift. I never had one Jim, but I think they have a lever system that reduces the load on the lift arm. When I had my single on the manual lift C-120, I had 3 lift springs that balanced the blower so It actually floated. 5 Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #4 Posted November 23, 2017 The 2stage I have now PO ran on a 314-8 then 315-8 with manual lift, and the 1 I let get away was on a C160 manual lift and both guys said it wasn't that bad with the assist spring (biggest spring in pics), also if you search, there's a member on here with video of 2stage on a manual and he's not straining to lift it, it also has a compound lift linkage which I believe takes less effort than the single rod in the single stage thrower, Jeff. 6 Share this post Link to post Share on other sites
nylyon-(Admin) 9,035 #5 Posted November 23, 2017 Got my 2-stage over the summer, it was hooked up to a 310-8. I was actually surprised how light it felt with the manual lift. All the same, it's sitting on a hydro-lift horse now so it feels even lighter 2 Share this post Link to post Share on other sites
SPINJIM 1,997 #6 Posted November 23, 2017 1 hour ago, WVHillbilly520H said: The 2stage I have now PO ran on a 314-8 then 315-8 with manual lift, and the 1 I let get away was on a C160 manual lift and both guys said it wasn't that bad with the assist spring (biggest spring in pics), Thanks Jeff for the pics. That larger spring in your pictures is much heavier than the one that came with my blower. Maybe that's why the P O sold it. It doesn't look like the same length spring that would be used with the single-stage. Could you please measure the length of that heavy spring for me ? I can't seem to find a part number for it in the Manual. Thanks again, Jim Share this post Link to post Share on other sites
rjg854 13,169 #7 Posted November 23, 2017 Check out Glenn Petitt, a vendor here that sells the spring you're looking for. I've gotten them from him, that's what you want. Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #8 Posted November 23, 2017 10 hours ago, SPINJIM said: Thanks Jeff for the pics. That larger spring in your pictures is much heavier than the one that came with my blower. Maybe that's why the P O sold it. It doesn't look like the same length spring that would be used with the single-stage. Could you please measure the length of that heavy spring for me ? I can't seem to find a part number for it in the Manual. Thanks again, Jim OK Jim the longer spring is for the idler pulley, then the helper is the larger/wider spring that goes on the right side is the same as the tiller/single stage spring. 1 Share this post Link to post Share on other sites
fast88pu 3,393 #9 Posted November 25, 2017 My 2 stage lifts 100x easier then my tall chute did with the spring on it. Manual lift too 1 Share this post Link to post Share on other sites
SPINJIM 1,997 #10 Posted November 25, 2017 (edited) 55 minutes ago, fast88pu said: My 2 stage lifts 100x easier then my tall chute did with the spring on it. Manual lift too I recently realized that the 2-stage should have TWO lift assist springs instead of the single spring that the tall chute has. The P O of mine lost both springs, and tried to replace them with one light-duty spring. That's probably why he sold it. I think I need one heavy spring mounted mid-frame down to the lift rod, and the second one up front attached to the Attach-a-matic bracket. Is that how yours is rigged ??? Thanks, Jim P.S. - If yours has two springs, is the length of both springs the same ? Edited November 25, 2017 by SPINJIM Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #11 Posted November 25, 2017 (edited) The springs are different here's the exploded view, and NLA, the big one that goes up front can be had from @wheelhorseman, I'm sure if we had the measurements Toro part # 110614 ,#40 in the diagram, one could be procured from TSC for the lift arm, Jeff. Edited November 26, 2017 by WVHillbilly520H 1 Share this post Link to post Share on other sites
fast88pu 3,393 #12 Posted November 26, 2017 7 hours ago, SPINJIM said: I recently realized that the 2-stage should have TWO lift assist springs instead of the single spring that the tall chute has. The P O of mine lost both springs, and tried to replace them with one light-duty spring. That's probably why he sold it. I think I need one heavy spring mounted mid-frame down to the lift rod, and the second one up front attached to the Attach-a-matic bracket. Is that how yours is rigged ??? Thanks, Jim P.S. - If yours has two springs, is the length of both springs the same ? Mine only has one spring on the right side. 1 Share this post Link to post Share on other sites
