Keith
C-120 upper steering shaft
Keith
What other models can I use the upper steering shaft for my C-120?
Are there aftermarket steering wheels for this tractor?
Edited by Keith
add comment
rmaynard
What's the model number (ID tag), or what's the year?
953 nut
Your steering wheel has a 3/4" hole for the shaft  and is drilled across the shaft for a roll pin to attach it. most any wheel (except 953, 1054, GT-14 and "D") will work. Most upper steering shafts will work if the length is the same or close enough to get the job done.
Ed Kennell
Why are you replacing the shaft?
Keith
The previous owner couldn't get the steering wheel removed.   He attached a large nut and steered the tractor with a wrench - like a tiller lever.
Ed Kennell
Now that has to be a first.   :wwp:  .     How is the nut attached...to the wheel or the shaft?
tunahead72
It sits in the seat. :)
Ed Kennell
Now Ed,  don't judge.   Elmer Pond started  with tiller steering
tunahead72
All in good fun, other Ed.  My very first Wheel Horse had a custom-built half-a-spoke-no-outer-rim steering wheel, at least after I "fixed" it.
rmaynard
The Workhorse 700 that I sold at the big show this year had a 10" screw driver as the steering device when I picked it up.
By the way, I may have a steering shaft. Will check the shed later.
rmaynard
Sorry, no upper, only lower. Must have should the uppers at the big show.
Ed Kennell
I do have several upper and lower shafts, but I would like to see what he actually has.  The problem may be fixable with a piece of 3/4" CRS  and a connecting sleeve.
  • Similar Content
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
