Countdown To Christmas!
Fun Engineer
D-series mid grader blade compatibility
Fun Engineer
Has anyone been successful mating a D series mid grader blade to a c-series?
Sarge
Not sure if that could be done , but I do have the older 40" mid-mount blade that would fit if you'd be interested in trading , perhaps ?
That D series mid-blade is pretty big but would probably work one way or another...
Sarge
Fun Engineer
Thanks Sarge. Just thinking of what my c-160 can handle. I’ve got a 40” on my Commando.
Sarge
I think the only real difference would be how much down pressure you can generate - the larger the blade , the more it will lift the rear tires enough to lose traction ability . Unless , of course - you weight the rear a bunch .
Doubt there's any real issue with pulling power , even a little 8hp short frame will move a lot of weight in pulling .
Sarge
DennisThornton
I just bought one for a "D" hoping it would fit a classic.  Or an XI.
I'm all ears!
  • Similar Content
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
