AlexR
Got a "new" C120 Wheelhorse
AlexR
16 minutes ago, WHX?? said:
Now I know you know 'tis better to ask forgiveness ... :D
I just need to bring one back from the plow day haha easier to hide another one among the herd :ROTF:
  • Excellent 2
  • Haha 1
SylvanLakeWH
:text-yeahthat:
What's in the barn stays in the barn...  :ph34r:
  • Haha 2
ebinmaine
3 minutes ago, SylvanLakeWH said:
:text-yeahthat:
It's a well-known fact that these beasts seemingly multiply on their own.
  • Haha 1
SylvanLakeWH
Hhhmmm...
Me thinks you need a Black Hood in your herd... might know of one that could make a one-way trip... :ph34r:
kpinnc
They also have something in common with owning a cat: once you have one, others show up that you never saw before... :P
Of course I've never chased away a stray Wheel Horse. That would be cruel and inhumane.
Edited by kpinnc
  • Haha 1
AlexR
2 hours ago, SylvanLakeWH said:
Hhhmmm...
I don't think so, it takes a select few of you to love those ugly ducklings :text-lol:
  • Sad 1
kpinnc
I hope that later in the summer, I can change your mind on that thought... Mine certainly has been changed. :thumbs:
  • Heart 1
AlexR
Look forward to seeing what you got up your sleeve! Your work is always top notch, so it will be interesting.
kpinnc
Well thank you very much!
The engine choice is the only wildcard right now. I'm trying to decide if rebuilding a Kohler twin is worth it (to me) or if a repower is the way to go. Just not sure yet...
SylvanLakeWH
:angry-tappingfoot:
Reminds me of a quote:
Right is right even if no one is doing it; wrong is wrong even if everyone is doing it.
This applies even at @Pullstart's after one to many curds and some unsupervised wrenching by them Wisconsin Boys...
:lol:
  • Haha 1
kpinnc
Reminds me of one: Preacher tell the truth and it hurts! :lol:
AlexR
Got the hubs pulled off today and everything is in great shape keyways axle keys all of it.
Not even sure I will want to pull it apart when I get to this tractor as I don't think any of the bearings are bad either axle bearings still feel tight. The only reason for me to pull it apart is replace the limited slip spring and just to see the condition of the gears.
But I have a question on seals has anyone had experience using the napa seals on these tractors
NOS 11050 napa seal is called a manual steering pitman arm seal.
Specs are
Inside Diameter    1.125
Outside Diameter    1.379 in
Width    0.125
Specs on cr/skf 11050
Shaft diameter 1.125 in
Housing bore diameter 1.3752 in
Seal width 0.125 in
Is that .0038 of a difference in outside diameter enough to not work?
NOS 7410 napa seal
Inside Diameter 0.75
Outside Diameter 1.004 in
Width 0.125
Cr/skf  7410
Shaft diameter 0.75 in
Housing bore diameter 0.9988 in
Seal width 0.125 in
Same thing outer diameter is different
Is that because one is actual seal outside diameter and the other is the bore diameter?
NOS 6105 napa seal
Inside Diameter    0.625
Outside Diameter    0.816 in
Width    0.094
Cr/skf 6105
Shaft diameter 0.6252 in
Housing bore diameter 0.8118 in
Seal width 0.094
Edited by AlexR
pfrederi
I always use CR seals with with the number you show never a problem.  Since the NAPA number is the same as the CR number I assume it is the same seal.
AlexR
These are seals I ordered from napa.. it's literally just CR/SKF seals
And then I ruined both axle seals on one side. Got them on the axle just fine. I had the keyway taped up as well, but trying to seat it in the axle housing it just wouldn't go in. It's like there should be a chamfer on the housing and there isn't, so the metal edge of the seal catches on the housing and got all bent up.
I'm thinking I need to do what I can to clean up the housing edge.
ebinmaine
:bitch:
Often a struggle for me.
This'll help a bit ... the seals are just tough to center sometimes.
AlexR
4 minutes ago, ebinmaine said:
:bitch:
Thanks, glad to know it's not just me.
Waited 2 weeks for the last seals, looks like its gonna be another week to get the new ones.
Good thing we don't have any snow right now, as this is the tractor I use for that.
ebinmaine
That's excessive.
Zoro has em in stock for $10 each plus $5 shipping.
Another reason why I keep my own Parts Department.....
AlexR
That's excessive.
Last time I got them from Napa and they had a issue with shipping or something so it took a extra 5 days to get it, I paid $9 a seal.
These last seals I ordered on the jungle site SKF brand seals for $6 each free shipping it will just take about a week to get them.
