AlexR 2,879 #176 Posted February 11 16 minutes ago, WHX?? said: Now I know you know 'tis better to ask forgiveness ... I just need to bring one back from the plow day haha easier to hide another one among the herd 2 1 Share this post Link to post Share on other sites
SylvanLakeWH 31,412 #177 Posted February 11 18 minutes ago, WHX?? said: Now I know you know 'tis better to ask forgiveness ... What's in the barn stays in the barn... 1 3 Share this post Link to post Share on other sites
ebinmaine 78,851 #178 Posted February 11 3 minutes ago, SylvanLakeWH said: What's in the barn stays in the barn... It's a well-known fact that these beasts seemingly multiply on their own. 2 2 Share this post Link to post Share on other sites
SylvanLakeWH 31,412 #179 Posted February 11 11 minutes ago, AlexR said: I just need to bring one back from the plow day haha easier to hide another one among the herd Hhhmmm... Me thinks you need a Black Hood in your herd... might know of one that could make a one-way trip... Share this post Link to post Share on other sites
kpinnc 18,243 #180 Posted February 11 (edited) 3 hours ago, ebinmaine said: It's a well-known fact that these beasts seemingly multiply on their own. They also have something in common with owning a cat: once you have one, others show up that you never saw before... Of course I've never chased away a stray Wheel Horse. That would be cruel and inhumane. Edited February 11 by kpinnc 1 1 Share this post Link to post Share on other sites
AlexR 2,879 #181 Posted February 11 2 hours ago, SylvanLakeWH said: Hhhmmm... Me thinks you need a Black Hood in your herd... might know of one that could make a one-way trip... I don't think so, it takes a select few of you to love those ugly ducklings 1 1 Share this post Link to post Share on other sites
kpinnc 18,243 #182 Posted February 11 1 minute ago, AlexR said: love those ugly ducklings I hope that later in the summer, I can change your mind on that thought... Mine certainly has been changed. 1 1 Share this post Link to post Share on other sites
AlexR 2,879 #183 Posted February 11 4 minutes ago, kpinnc said: I hope that later in the summer, I can change your mind on that thought... Mine certainly has been changed. Look forward to seeing what you got up your sleeve! Your work is always top notch, so it will be interesting. 1 Share this post Link to post Share on other sites
kpinnc 18,243 #184 Posted February 11 4 minutes ago, AlexR said: Look forward to seeing what you got up your sleeve! Your work is always top notch, so it will be interesting. Well thank you very much! The engine choice is the only wildcard right now. I'm trying to decide if rebuilding a Kohler twin is worth it (to me) or if a repower is the way to go. Just not sure yet... 1 Share this post Link to post Share on other sites
SylvanLakeWH 31,412 #185 Posted February 11 37 minutes ago, AlexR said: I don't think so, it takes a select few of you to love those ugly ducklings Reminds me of a quote: Right is right even if no one is doing it; wrong is wrong even if everyone is doing it. This applies even at @Pullstart's after one to many curds and some unsupervised wrenching by them Wisconsin Boys... 2 1 Share this post Link to post Share on other sites
kpinnc 18,243 #186 Posted February 11 11 minutes ago, SylvanLakeWH said: Right is right even if no one is doing it; wrong is wrong even if everyone is doing it. Reminds me of one: Preacher tell the truth and it hurts! 2 Share this post Link to post Share on other sites
AlexR 2,879 #187 Posted February 13 (edited) Got the hubs pulled off today and everything is in great shape keyways axle keys all of it. Not even sure I will want to pull it apart when I get to this tractor as I don't think any of the bearings are bad either axle bearings still feel tight. The only reason for me to pull it apart is replace the limited slip spring and just to see the condition of the gears. But I have a question on seals has anyone had experience using the napa seals on these tractors NOS 11050 napa seal is called a manual steering pitman arm seal. Specs are Inside Diameter 1.125 Outside Diameter 1.379 in Width 0.125 Specs on cr/skf 11050 Shaft diameter 1.125 in Housing bore diameter 1.3752 in Seal width 0.125 in Is that .0038 of a difference in outside diameter enough to not work? NOS 7410 napa seal Inside Diameter 0.75 Outside Diameter 1.004 in Width 0.125 Cr/skf 7410 Shaft diameter 0.75 in Housing bore diameter 0.9988 in Seal width 0.125 in Same thing outer diameter is different Is that because one is actual seal outside diameter and the other is the bore diameter? NOS 6105 napa seal Inside Diameter 0.625 Outside Diameter 0.816 in Width 0.094 Cr/skf 6105 Shaft diameter 0.6252 in Housing bore diameter 0.8118 in Seal width 0.094 Edited February 13 by AlexR 1 Share this post Link to post Share on other sites
pfrederi 20,537 #188 Posted February 13 I always use CR seals with with the number you show never a problem. Since the NAPA number is the same as the CR number I assume it is the same seal. 1 Share this post Link to post Share on other sites
AlexR 2,879 #189 Posted February 26 These are seals I ordered from napa.. it's literally just CR/SKF seals And then I ruined both axle seals on one side. Got them on the axle just fine. I had the keyway taped up as well, but trying to seat it in the axle housing it just wouldn't go in. It's like there should be a chamfer on the housing and there isn't, so the metal edge of the seal catches on the housing and got all bent up. I'm thinking I need to do what I can to clean up the housing edge. 3 Share this post Link to post Share on other sites
ebinmaine 78,851 #190 Posted February 26 20 minutes ago, AlexR said: the metal edge of the seal catches on the housing Often a struggle for me. 21 minutes ago, AlexR said: need to do what I can to clean up the housing edge. This'll help a bit ... the seals are just tough to center sometimes. 1 Share this post Link to post Share on other sites
AlexR 2,879 #191 Posted February 26 4 minutes ago, ebinmaine said: Often a struggle for me. the seals are just tough to center sometimes. Thanks, glad to know it's not just me. Waited 2 weeks for the last seals, looks like its gonna be another week to get the new ones. Good thing we don't have any snow right now, as this is the tractor I use for that. Share this post Link to post Share on other sites
ebinmaine 78,851 #192 Posted February 26 11 minutes ago, AlexR said: Waited 2 weeks for the last seals, looks like its gonna be another week to get the new ones. That's excessive. Zoro has em in stock for $10 each plus $5 shipping. Another reason why I keep my own Parts Department..... Share this post Link to post Share on other sites
AlexR 2,879 #193 Posted February 26 4 minutes ago, ebinmaine said: That's excessive. Zoro has em in stock for $10 each plus $5 shipping. Last time I got them from Napa and they had a issue with shipping or something so it took a extra 5 days to get it, I paid $9 a seal. These last seals I ordered on the jungle site SKF brand seals for $6 each free shipping it will just take about a week to get them. 2 1 Share this post Link to post Share on other sites
702854boy 776 #194 Posted February 27 When we were going through our 6 speed tranny, we were able to find the seals on Rock Auto for cheaper than the jungle site or Napa, and they come with a magnet from there. 3 Share this post Link to post Share on other sites
AlexR 2,879 #195 Posted February 28 11 hours ago, 702854boy said: When we were going through our 6 speed tranny, we were able to find the seals on Rock Auto for cheaper than the jungle site or Napa, and they come with a magnet from there. I didn't even think to check there, $3.04 a seal with $6 shipping would be a great deal for ordering a bunch of seals. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,234 #196 Posted February 28 The outside diameter of the seal will always be larger than the housing bore. That .003"-.005" difference is what holds the seal in the bore once it is installed. Also known as interference fit. 2 Share this post Link to post Share on other sites
702854boy 776 #197 Posted February 28 3 hours ago, AlexR said: I didn't even think to check there, $3.04 a seal with $6 shipping would be a great deal for ordering a bunch of seals. And don't forget the cool car magnets you get too 2 Share this post Link to post Share on other sites
WHX?? 56,595 #198 Posted February 28 On 2/27/2026 at 6:50 AM, 702854boy said: able to find the seals on Rock Auto for cheaper than the jungle site or Napa, Good to know. I enjoy building transmissions & motors just for "the shelf" and finding parts for short money makes it more enjoyable and affordable. 1 Share this post Link to post Share on other sites
AlexR 2,879 #199 Posted Thursday at 10:23 PM I haven't posted much in a while, I have been busy working on spring stuff and a lot of vehicle work. Did get all three of my Wheelhorse's running I think it's the first time they have all been running together. This tractor is going to get a new build thread in the restorations, modifications, and customizations at some point, and it's going to be getting hydraulics. It will still be a little while before that happens, but its in the works. 5 Share this post Link to post Share on other sites
ebinmaine 78,851 #200 Posted Thursday at 10:58 PM I've subscribed to your YT channel. Remember that if you choose "for kids" YT does NOT allow notifications. For that reason ZERO of my videos are Age Restricted. 1 Share this post Link to post Share on other sites
