bob54 12 #1 Posted October 3, 2017 Anyone know the size of the snap ring on the crankshaft Part number 518–0014 1 Ring, Retaining. It's number 2 on the parts diagram . So far I know it's smaller than 1 1/2 and bigger than 1 1/4. I need one ASAP and hoping if I can find out the correct size I can go pick one up. Thanks all Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,853 #2 Posted October 4, 2017 I can't find the 518-0014 retaining ring anywhere but they are usually sized by the diameter of the shaft they are used on - not the diameter of the ring. Garry Share this post Link to post Share on other sites
WHX?? 53,374 #3 Posted October 4, 2017 Try @boomers_influence or other other Onan parts guys in the vendors section Bob... perhaps @daveoman1966??? 1 Share this post Link to post Share on other sites
cleat 8,118 #4 Posted October 4, 2017 If it is metric then 1.25" is around 32mm and 1.5" is around 38mm. So measure the diameter of the inside of the snap ring groove and see if you come up with a number between 32 and 38 mm. Share this post Link to post Share on other sites
Searcher60 209 #5 Posted October 4, 2017 Something that important? Just get it from your local Cummins Truck parts department. Why would you take somebody's guess on a part like that? Share this post Link to post Share on other sites
bob54 12 #6 Posted October 4, 2017 Thanks to Boomer, I am all set 1 Share this post Link to post Share on other sites
