Shea Worden
Firestone Tri Ribs
Shea Worden
I am deciding whether i should get the firestone tri rib tires or the vredestein 5 rib tires.Got any suggestions?
953 nut
There are quite a few variables to consider. What tractor are they going on?  What will the tractor be used for? How wide are the rims you will mount them on?
Tell us more.
  • Like 5
cschannuth
I have both on different tractors and love them. Both make the tractors steer very easily. Some have said the tri ribs are hard on their yard but I have never had an issue with them.  The Vreds have a beefier look to them.
42F73E40-C1A8-4308-9959-78ED8526E909.jpeg.1ba3a5910267311e9cf4b7ee5dfba57e.jpeg08D18EF4-171F-47BB-A867-25A6B2AC9314.thumb.jpeg.40480cca030b1a084e1f7ce78fd744e6.jpeg
Adams94
Just put these on my c195 and I love the look,  I like the tri rib also but they are like 20$ a piece more
  • Like 5
Shea Worden
Tell us more.
These tires will be going on a wheel horse C81 restoration project. The tractor is used for light landscaping and a little offroading. I also want to do a few local garden tractor pulls-nothing serious though. The rims are sized at 16/6.5/8.
I am not too worried about prices though. I have been saving a pile of cash to spend on my tractor.
Edited by Shea Worden
MalMac
Tri-ribs were originally designed for farm field use in dirt. The center rib or ridge was there to provide bite when turning sharp when coming to the end of the field to be able flip around and head back the other direction. They provided bite so the tractor had less tendency to slide or skip. That’s the reason they are tough on turf. If you turn hard and fast like in a field, the rib will dig in and can cut like a knife peeling up turf. Now on a small garden tractor maybe not as bad.
With th the advent over the years in large field implements the need to be able to turn sharp in a field had drop dramatically. That’s why your seeing larger wider tires on two drive farm tractors. Plus the wider tires offer less soil compaction, and that’s a good thing.
Out in the garden I have yet to need tri-ribs on any of my garden tractors. I did put the V61’s 6 ply on my loader tractor. Made all the difference in the world. So I guess it’s up to you. Both are nice tires.
WHX??
I would go with the tri's based on what you said you will be using it for. They would pair up for a better look if you arte using ags on the back. I have a pair of Firestones  on the front of one of my tractors and the only complaint is they (one side anyway) kept losing air through the rim bead. Might have been due to rim issues though.  Couple of buddies tractors that have the Firestone reported cracking of the tire side wall after only a few years. May or may not be an issue with mine or yours if you get them but time will tell. I would also take a look at some Deestones and other brands, some have more of a flat appearance across the thread for a flatter look. The firestones do have a pronounced center rib for sure. Firestones are the pricier one of the bunch but I think we are paying for the name  more than anything else. My man @Rp.wh just put a set of really affordable Dee tris on the front of a tractor and they don't look half bad.
Keep in mind most V's are required to be tubed. Whatever you decide good luck and :wwp:
These are the Firestones
Edited by WHX12
gramma
fast88pu
I run the 5 ribs. I don't like the look of the tri rib firestones with the center rib that is higher. I do have deestone tri ribs on my pullers
littleredrider
I have the tri ribs on my 520. Both front and rears are loaded, rear has weights too. Turning sharp they don't dig that bad. Only time I really notice is in certain parts of the yard where there is dirt/mud, they leave a line. But it's not really noticeable. I have a 60" deck and steering reduction, there is some weight there and these tires make it steer like it has power steering. I need to get a spinner nob as I can't steer quick enough when going around trees n what not. I had the V's on a 520 years ago but didn't have it long enough and no real weight or use to get a fair opinion. One thing I do notice is the tri's will push when pulling small hill or in a low gear. Not a huge deal, but think any tire will do that.
RedRanger
Running 3 ribs on my 702, and also noted they pushed/floated climbing hills.  Front weights helped with that.
I'd also suggest looking at the Deestones.  Much less expensive, and they look about the same as Firestones.
These are the narrow version for skinny rims.
cschannuth
I also have the Deestones on my 606 rat rod and I do like the look better than the Firestone’s.  They are a smaller tire and on a narrower rim so I don’t know how they would compare visually2E6AFB11-99EE-4166-9EC9-90314B36F78A.jpeg.23f7402717c7124e4615b055450a664f.jpeg if they were the same larger size that I have on my 161.
Shea Worden
Thanks for the pictures. I think that I will go with the tri ribs. I will look at the deestones and compare the ratings and looks. Thanks. Also, I cant post pictures because I do not have a phone or camera.
  • Excellent 2
Forest Road
I have the TRI ribs on a 314. Absolutely love them. I find it's easier to steer w 2 stage blower. And they grip a little better in the soft spots while making a turn.
Have the Vreedsteins on 522xi loader. I wanted them for a wider heavier footprint w the loader. The Xi has power steering so I can't comment on what it takes to turn them. They hold up well w a full load.
  • Similar Content
    • DevonianHorse
      By DevonianHorse
      Hi all, on a 1977 Wheelhorse C-100 (Belgium made), I have a question
      My Wheelhorse hood opens really far- it does eventually stop but I don't think it is meant to go this far and that there's a piece missing.
      In this photo, there's a hole you can see (near the middle of the pic, 1/3 down) and the same on the other side of the hood mounting part of the frame- I assume some sort of bar is meant to go between them that the hood latches at the base will catch on and this stops the hood dropping further when opened? If this makes no sense sorry- I have simply always assumed that the hood is meant to open at a right angle from the front, but having seen videos, I can see most stop before that.
      Does anyone know the part I need, or would two bolts, one on each side, do the job? Mine has never had one, so I am unsure.
      Thanks!!
    • Donavon1
      By Donavon1
      Need some help deciding on a brand of engine to buy for my 1054. (Needs to be a diesel 10 hp+) I’m refining used motor oil/cooking oil for fuel for it. So it will have to have an option to run used oil and diesel
    • MainelyWheelhorse
      By MainelyWheelhorse
      Hi All, I’m a member of the RedSquare Facebook group, some of you may have seen My tractor there. I have a 1992 312-8 with a 37 inch deck. It came with a house my brother bought, and was given to me. It needed work but just minor things. I mow my lawn with it, and I just bought a plow to push snow/dirt so it’s a working restoration. It was relatively well taken care of by the previous owners so it really just needed a refresh. Anyway see you around the site!
    • Jon Paulsen
      By Jon Paulsen
      Inexpensive - Carlisle X Trac ATV Bias Tire - 16x6.50-8 Good quality (I expect) Should look nice with my large rear aggies
      I don't know how much these have been discounted, but I expect anything you find like this from a good brand will be 2X to 3X the price. $45 each at Amazon. This tire is discontinued.
      Rough measurement seems they are about 16" tall and the lugs are about 1/2" deep.
    • Monstrosity
      By Monstrosity
      Show off what your doing from the seat of your Horse!!! Fixed up a mowing deck for the 1277 and put the plow on the C1014. Getting ready to level a topsoil pile and going down the block to mow the small park to test the mowing deck out.
