Shea Worden
My C81
Shea Worden
I cant find any stacks with mufflers that fit on my c81, can anyone tell me where to find some good ones?
rjg854
PM   Jim Kemp he makes them.
MalMac
I second that, Jim makes a very nice stack. Just perfect for that C81.
Retired Wrencher
Shea Worden  :WRS: As you can see already good help and folks here. Enjoy the site.
SylvanLakeWH
:text-welcomeconfetti: and :text-yeahthat:!!!
Shea Worden
thanks guys. like the warm welcome. Jim Kemp-hes on this site? Do his stacks curve 90 degrees to reach the exhaust port?
I have one more thing to ask, irrelevant to this discussion but do you guys have one go to ag tire? I`ve been looking at carlisle and deestone? Got any feedback?
Shea
Sarge
Carlisle seems to be a better tire , although some of the bigger rear sizes have moved to offshore manufacturing . The Deestone is known to run short in height . I run the Carlisle Tru Power ags on nearly all my Horses - very well made and great traction/wear rate .
The true King of ag tires is the Firestone 23 degree agricultural tire - the tried and true original with the price tag to match .
Sarge
Racinbob
@Bud Andrews made mine. I used iron pipe fittings. I believe your C-81 has the shaker mount motor so you'll want to support it off the engine. :)
WHX??
:WRS: Shea
Sarge nailed it on the ags, the Dees are the most affordable and work fine in most ag tires needs.
Browse here http://www.wheelhorseforum.com/topic/56577-4-tire-suppliers/ and see if anything jumps out at ya.
Sarge
Also , don't completely discount some of the off brands - I put a set of BKT ags on the front of the D , they were dead true to size and haven't worn one bit yet with excellent traction so far .
Sarge
cafoose
Here is what I got from Jim Kemp
20170608_124227.jpg.215aaff985ba11d652b1487108cd50af.jpg20170608_124504.jpg.f8a9a85f05f6cdc02e00e51ca482f9fd.jpg20170608_122633.jpg.008c7d0ef3b8f14eb02daedee6fd5280.jpg20170608_122550.jpg.98fdbdd305bc10314324c3f8be51f482.jpg
  • Similar Content
    • 87 416-8 horse
      By 87 416-8 horse
      I’m looking for wheel horse tractors for sale or for parts in the Eastern Nebraska or western Iowa area. Preferably 8 speed manuals. Pm me or comment with what you have. The worst I could say is it’s out of my price or distance range. Edit: engine is not important, it’s going to get a big diesel swap.
      Thanks,
      John
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
      1984 C-105 8-Speed model 11-10K802
      1984 C-125 8-Speed model 11-12K802
      1984 C-145 Automatic model 11-14KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-165 8-Speed model 11-16K801
      1984 C-175 Twin Automatic model 11-17KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-195 Twin Automatic model 01-19KE02
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
      92DB561C-FF95-4868-A52B-5725D4D3B9DE.mp4
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
