Dhodge 530 #1 Posted August 3, 2017 (edited) Just used my wireless tachometer to set the RPM's on one of my tractors, unfortunately it was not a red tractor, but a good performer and worker non the less. I know it says for single cylinders, but it works on twins too. Edited August 3, 2017 by Dhodge 2 1 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #2 Posted August 4, 2017 @Dhodge Where did you purchase the wireless tach ? Share this post Link to post Share on other sites
cafoose 3,738 #3 Posted August 4, 2017 (edited) @elcamino/wheelhorse Just a quick 30 second search and got these results: https://www.amazon.com/Wireless-Tachometer-Replaces-OREGON-42-423/dp/B00281RI0E https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2386202.m570.l1313.TR0.TRC0.H0.XStrandix+WIRELESS+TACHOMETER.TRS0&_nkw=Strandix+WIRELESS+TACHOMETER&_sacat=0 Edited August 4, 2017 by cafoose Share this post Link to post Share on other sites
Dhodge 530 #4 Posted August 4, 2017 8 hours ago, elcamino/wheelhorse said: @Dhodge Where did you purchase the wireless tach ? To be honest I have had it so long I really don't remember. Share this post Link to post Share on other sites
Sarge 3,471 #5 Posted August 6, 2017 Just fyi - I have an electronic Equus hand held timing light/tach I've used for years in dialing in distributors on older engines and setting the timing curve springs/weights . It's ability to read/figure out firing and rpm is amazing - the dumb thing will read 1,2,3-8 cylinder engines with no problem and seems to be a bit more attenuated in it's tach reading ability - doesn't bounce around so much on the display as others . Seems to be pretty robust as well - it's been bashed by fan blades more than once and recently took a solid knock off my K341 hard enough to break the hinge section at the head - but still works flawlessly . Nice part is this one has a defeat button to turn off the strobe light when using it just as a tachometer - just a simple magnetic pickup that goes to the plug wire and the regular positive/negative battery clamps - simple enough for nearly anything . Sarge 1 Share this post Link to post Share on other sites
lynnmor 8,853 #6 Posted August 15, 2017 I use this one for most anything: Non-Contact Share this post Link to post Share on other sites
