Tgtack 779 #1 Posted August 1, 2017 I am trying to locate some parts for a model 551 that I recently picked up. It is missing the drive belt cover, does not have the correct engine, part of the headstand was cut away. If you have a model 551, I really really need some detail pictures. Pictures of the correct belt guard (and dimensions if possible), also the Z shaped rod under the cover, dimension of the belt guard spacers. Pictures of the engine mount (H55/HH55 engine), dimension from frame to top of cylinder head (not spark plug). Pictures of the battery mount from both sides (part of mine was cut off on the left side of the frame). Your help would be much appreciated. I have searched the archives, and unfortunately, many of the past pictures that might have helped, are not available as they were on off forum storage, and many simply no longer exist. Share this post Link to post Share on other sites
stevasaurus 23,485 #2 Posted August 1, 2017 I know this does not answer all your questions, but did you see this? 2 Share this post Link to post Share on other sites
Aldon 4,828 #3 Posted August 1, 2017 You need to hook up with @formariz I have 2 but dont have ability to get the photos you have asked for expeditiously. Maybe in a week or two. But Formariz likely has already posted what you need in one of the threads of his 551. 3 Share this post Link to post Share on other sites
formariz 12,315 #4 Posted August 1, 2017 Give me a day or so and I will get it for you. 4 Share this post Link to post Share on other sites
Tgtack 779 #5 Posted August 1, 2017 2 hours ago, formariz said: Give me a day or so and I will get it for you. Thanks, I specifically need details on the engine mounting, as I found a HH55 engine, but it has the mounting plate on the bottom, not sure if it will work as I thought the 551 HH55 engine used a cast oil pan with mounting lugs cast into it. Height measurement will help determine if it will fit. Thanks a lot for the help. 4 hours ago, stevasaurus said: I know this does not answer all your questions, but did you see this? Yep, saw those, not close enough for the detail needed. 2 Share this post Link to post Share on other sites
formariz 12,315 #6 Posted August 5, 2017 Lets see if these help you. I may have to remove heat shield for better access to battery area if they don't. Sorry that she is a little grimy but she is a working girl. 4 Share this post Link to post Share on other sites
formariz 12,315 #7 Posted August 5, 2017 On 8/1/2017 at 3:45 PM, Tgtack said: Thanks, I specifically need details on the engine mounting, as I found a HH55 engine, but it has the mounting plate on the bottom, not sure if it will work as I thought the 551 HH55 engine used a cast oil pan with mounting lugs cast into it. Height measurement will help determine if it will fit. Check other post in engines section for engine information. 1 Share this post Link to post Share on other sites
Tgtack 779 #8 Posted August 6, 2017 On 8/5/2017 at 1:23 AM, formariz said: Check other post in engines section for engine information. Thanks for all the info, it will help a lot. Share this post Link to post Share on other sites
