Duramax7man7
Onan P-Series Ignition Module Replacement [Photos]
BMW Phil
20 hours ago, lynnmor said:
I believe that the insulator under the module is to lessen the heat transfer from the block, earlier models didn't have it but you should add one.  You can make one from gasket material.  You can download the Operators Manual and the Onan Service Manual here.  The troubleshooting methods will be in there.  The module is indeed grounded thru the mounting screws.  You can add a temporary line to to insure that 12 volts are getting to the coil.  Coils fail from heat much the same way as the module.  The trigger ring may be faulty, early black ones had more failures than the newer gray ones.  Be sure that you installed the flywheel key correctly.
That was my conclusion as well. I wondered how thick the insulator was, in case the sensors height in relation to the trigger ring was critical.
lynnmor
I think the material is between .02” and .03 thick, it isn’t critical.
  • Thanks 1
davem1111
Thanks to everyone who contributed to this thread. I'm going to be replacing one of these on a 416-H P216g this weekend.  The engine has been dying after 5-15 minutes when it gets hot (running time has gotten shorter and shorter).  Very frustrating problem. I'm hoping that this solves it. Also, I didn't spring for the OEM part at around $200 or more (almost as much as the tractor is worth at this point) - hoping that an aftermarket part will do the trick. The insulator tip is a good one also, @lynnmor.
The part and an appropriate puller will be here Saturday.  I tried rigging up a custom puller but it didn't work. I'm getting a steering wheel puller like @Duramax7man7 had suggested and shown in pictures.
Just to be clear, the flywheel bolt should be loosened but left in, but turned out just a little so the flywheel can pop loose when applying the puller?  Any tips if it doesn't want to pop loose?  Somewhat gentle tapping on the backside of the flywheel?  (I know hammering hard could damage it....)
I had replaced the coil, regulator, condensor, and wires, and thought the problem was solved but it wasn't. Had the tractor sold to a neighbor but it came back after the problem kept happening and got worse. Unfortunately he no longer wants the tractor even if this fixes the problem - says he wouldn't trust it.
Will let you all know how it goes.
wh315-8
I done this with my 520H a few years ago and haven’t had anymore issues. Replacing the 9 pin wire connector was a big issue because pins and wires were corroded which could be what caused the ign module to go bad. I was able to get a module and ring for around 140$. I also replaced the coil, plugs, condenser also.
the flywheel can be temperamental. A good solid hammer blow on the end of the bolt and spray lubricant on the crank helps. Figure a whole day to do the job, it takes so much just to get the flywheel cover off, nothing like on a Kohler K engine. And while you have so much off the engine, good time to check the valve adjustments.. Onan Service Manual in downloads if you don’t have it yet.
12 minutes ago, davem1111 said:
Thanks to everyone who contributed to this thread. I'm going to be replacing one of these on a 416-H P216g…
  • Thanks 1
davem1111
Ah yes, thanks for mentioning the 9-pin.  I'll check that out also.  Valves are a good suggestion too.
I already have the flywheel shroud off. I'm more worried about getting all that back together properly.
wh315-8
It can get tricky, I have 3 Onans, if you get in a bind and need pictures of where things go, don’t hesitate to ask. I will be happy to help as I can.
Bill D
Having done a couple of these modules myself you can save a step if you're patient.   You can get a 5/16" box end wrench under the stator to remove the screws holding the ignition module.  This will save you from having to remove the stator.  Clean everything well with electric motor cleaner and compressed air before reassembly.  Changing the module should fix your issues.
  • Similar Content
    • lsc1257
      By lsc1257
      I have a 1996 520H Wheel Horse for sale.  The tractor has just over 800 hours on it.  It comes with a 48 inch deck.  The deck is a 1995 and has over 1,500 hours on it, as it came brand new with my 312-8 that I sold several years ago.  This 520-H has the swept front axle so it can handle a 60 inch deck.  I just replaced the battery and the deck belt this summer.  The engine is a 20HP Onan and it starts right up but requires the full choke.  The transmission is an Eaton 1100-062, hydrostatic.  The deck is in rough shape but the spindles appear to be in good working order.  The right rear tire has some cracking.  The original operator's manual for the 520H is included, as is the original operating and maintenance instructions for the deck, plus the installation instructions for the deck.  Also included is a new PTO belt and several miscellaneous deck wheels and rollers.  Additional pictures available upon request.  Asking $500.
    • Joe Warren
      By Joe Warren
      Wheel Horse
      Service Tool Kit
      Onan Industrial Engines
      ON-420-0556
      Kit is missing oil filter tool, otherwise complete. Tools in excellent condition. Small crack in plastic case, bottom, middle.
      $129 plus shipping cost.
      Message me if you are interested in purchasing. Thank you. Joe
    • Tenday
      By Tenday
      Experts - help please. I’m new to Wheel Horse Tractor life!
      So - I’ve pulled out an inherited tractor and have decided to resurrect her. Unfortunately, no spark :/
      I’m looking for help on diagnosing no spark.
      model - 417-8
      engine - Kohler KT17
      Done thus far:  (aware that some have no implication on spark.)
      - new ignition switch
      - new battery
      - new starter
      - new ignition coil and wires w/ plugs
      - new condenser
      - new points
      - new starter solenoid
      - bypassed all switches except oil and seat.
      notes:
      idiot lights removed.
      All fuses tested with Ohms as well as visual inspection  ..
      coil tested w/ ohms as well
      all switches bypassed except:
      -oil switch  ( don’t think it has any implications other than a visual indication for idiot lights. )
      -seat switch
      ran a pos from batt direct to pos of coil - nothing; no spark.
      Electric is as follows:
      - Starter switch wired to solenoid
      - - solenoid to starter
      - - solenoid to batt
      - one wire from starter switch goes to engine ( I think this is for batt charge / flywheel)
      - I have two yellow wires, which are married up, that go to engine which have constant power; They power coil.  Comes from switch and seat.
      Help - what the heck am I missing ?
    • Rollo416H
      By Rollo416H
      I'm new here, but I have years and miles of dealing with electrical issues with my 1997 416H, engine Onan P216G (I am the only owner) . Problem description: the start circuit turns the starter over fine, but no spark at the plugs or the coil sockets by spark tester.  The ignition trigger tests good by connecting a test light to the coil positive and and the ignition trigger negative lead, plenty of light flash from the test light in unison with the engine turning over. So, I conclude the ignition trigger, replaced 3/18/2021 along with the coil is good.  I have followed the "Demystification" wiring diagram in detail and there is 12V at the coil positive terminal, wiriing is solid (for now), all those damn safety switches, key switch,  and relays work too. I conclude that the coil is bad since the primary side tests 3.1 OHM and the secondary tests infinite OHMS (1. displayed on multimeter).  Two coils (Onan part# 166-0820) have NEW dates of 3/2021 and 8/2021, and yes both have the same test results mentioned. Infinite OHMs to me means the coil windings are broken. The most recent coil came from Onanparts.com and tested as mentioned above when it arrived.  Onanparts won't take anything back!  There are a lot of coils on ebay and various suppliers from China.  Maybe good, maybe bad, who can tell? And most suppliers won't accept returned electrical parts. Please help: What are good test readings for a GOOD coil (primary and secondary). Who do you recommend as a reliable supplier for a new coil?
      Thanks for any help!
      Rollo416H
    • SPINJIM
      By SPINJIM
      1992, Wheel Horse 520-H.   Onan overhauled: New rings, cylinders honed, valves lapped, new carb., new seals and filters, new fuel lines and primer bulb for easy starts.  Seat is like new.  Front tires are new.  All tires hold air.  Some repainting, but didn't need much; was stored indoors.  New decals.  Other new parts.
      Has swept front axle and Variable Ratio Steering.  Belt cover ventilated to cool back cylinder.  Rear wheel weights are 55 lbs. each.
