Similar Content
By rustyedge1
Old Horse still gettin her done today, weekly workout.
Photo on trailer 2014 the day I brought home.
Old Kohler still sounds sweet under a load. Somewhere in life it picked up a 16hp motor.
IMG_9609.mov IMG_9609.mov
By Joe Warren
A guy I know runs all his 4 cycle power equipment engines on 2 cycle fuel. He claimed it reduced engine wear. Aside from the added cost of the 2 cycle oil, are there other downsides. Just curious what you all think.
Joe
And now for the rest of the story: I spoke to the guy again. He was a mechanic at a place where they operate a lot of outdoor power equipment; with both 2 and 4 cycle engines. To prevent employees from putting straight gas into their 2 cycle machines, all their fuel got 2 cycle oil mix with it. For them, it was more economical to spend money on oil, than on blown engines and downtime.
Thank for all the great posts. I found some to be very entertaining.
By KC9KAS
I have a friend needing parts for his D-160. I do not know what year it is right now.
He is looking for the coupling between the engine & hydro pump.
He may need a pump as I think the pump splines are stripped. He does not have it apart yet so items needed at this time are not known.
Anyone have any leads on "D" parts?
Thanks in advance!
By JoeM
The Ethanol Monster strikes again!
Got out the pressure washer and went to start it, "no dice"
Opened the carb and found those typical ethanol pearls, as I call them.
I used an additive in my fuel last year, Ethanol Shield, did not seem to work very well.
Not wanting to drive 30 miles for fuel, and still skeptical about if it is true ethanol free.
Switched over to Lucas additive now.
Will see.
FYI
Joe
By RJ Hamner
Let me first say that it ran when I brought it home. Drove it around the guys yard, tried out the mower, drove it onto the trailer and drove it off the trailer and into the garage.
I've done a "ground up" restore on the tractor (70 Charger 12). Swapped out the breakerless for a battery ignition and swapped out the 10 amp for a 15 amp stator, flywheel and regulator.
Pulled the head, looked pretty good, new head gasket and head bolts.new fuel pump, fuel lines,new switches and wiring, new aftermarket carb, new coil, coil wire, new points, new throttle and choke cables.
Static timed (twice just to make sure) Have tried Autolite 216's and the hotter 437's. changed the condenser to the high dollar Kohler one.
It will idle but when I give it some throttle it stumbles or will rev up a little then quits.
I've gone thru the "trouble shooting " steps multiple time and to no avail
Anyone got any ideas?? I am willing to try most anything at this point
Bob
