TN Dave
How Do I Remove & Replace Front Wheel on 310-8?
TN Dave
Hi all:  I am new to this forum and would appreciate any help you can give me on this.
I have a Wheel Horse 310-8 that runs well and mows well.  However, one of the front tires went flat the other day.
There are no lug nuts on the wheel.  It appears that it may be attached with some sort of pressure seal, but frankly, I really can't tell how it is attached so I can't figure out how to get it off so I can repair the tire.
The only things I can see on the wheel are the grease fitting, a cap which is filled with grease, and the tire valve stem.
Any thoughts or direction you can give me on this will be greatly appreciated.
Thank you.
Sarge
Pull the cap off the end of the spindle , start digging in all of that grease - should be a pin , bolt or whatever was used on these later models to hold the wheel and bearings onto the spindle , simple . Keep the dirt out while repairing the tire and replace it as you found it if the bearings are in good order - otherwise get replacements and reassemble .
Sarge
TN Dave
Thanks!
N3PUY
What Sarge said :text-yeahthat:
Ed Kennell
May be a snap ring ?
Tankman
That would be my thought. Exactly why I keep snap ring pliers in my tool box. :handgestures-thumbupright:
KC9KAS
@TN Dave :text-welcomeconfetti: to :rs:
Looks like there is a cotter pin holding the front wheels on.
953 nut
:WRS:             Cotter pins on mine!
TDF5G
:WRS:  Wishing you success with your tire repair.
Edited by TDF5G
tunahead72
Welcome aboard Dave! :WRS:
I believe my '86 310-8 has cotter pins also, but sorry, it's just too hot right now for me to go check.  My parts manual shows that pin as a 5/32" x 1-1/4", you'll probably want to replace it rather than reusing the old one.
Before you take the wheel off, check for end play (with that side of the front end jacked up) by pulling and pushing the wheel along the axle.  There are shims available if there's too much play.  Somebody correct me if I'm wrong, but I believe the axle is 3/4" diameter.  Basically, if you can fit a .015" shim in there, there's too much play.
Also check the rubber/plastic hub caps, and replace them if you need to.  Glen Pettit (one of our vendors here) has very nice hub caps and upper spindle caps for sale.  They're a little pricey, but I have them on both of my tractors and can tell you they're excellent quality and do a great job of keeping the axles and upper spindle areas clean.
And finally, look in our manuals section if you need manuals, there's a lot of information available here.
Back to your original problem, how bad are the tires?
  • Similar Content
    • OHLB
      By OHLB
      Newbie here. 310-8 won't start. Battery is dated 10/19. Did crank a couple times but started losing ummph. Should I replace it or attempt to charge it? Can't tell if the battery is frozen. Never knew until today that batteries could freeze and that it's dangerous to charge a frozen battery. It's been single digits with wind chill the last couple weeks here.
    • Big Rig
      By Big Rig
      ISO clutch neutral safety switch for 310-8
      or alternative
    • Rob R
      By Rob R
      Soo couple of years back did a pulley change on the tranny from 6 inch to 4.5 and used a 1/2 X 79 belt to make it work and it worked fairly well but wanted to get back to a 5/8 drive belt so went to a 5/8 x 81 inch belt and added a second flat Idler pulley. I simply cannot believe how smooth and sharp it shifts and drives now!  The added flat Idler was 2 3/4" with a 5/8ths bore used and existing hole on the side shroud and just opened it up a bit. I use to slip a bit on steep hill with the 79" slips no more, the belt drives and the clutch is  LOT smoother and in the right pedal area.... Will see how it holds up cut 3/4 of an acre of grass yesterday NO issues.
    • Ifixoldjunk
      By Ifixoldjunk
      So I was out mowing the other day with my 310-8 and somehow snagged my wheel in a hole in the yard. Anyways I pretty much destroyed my ball joints. I've since replaced the tie rod with junkyard parts but I was wondering if anyone's found a heavy duty aftermarket replacement for the tie rod assembly.
      Like would generic adjustable go-kart tie rods do the trick?
    • Ifixoldjunk
      By Ifixoldjunk
      so I spent a few hours today welding up a custom front weight bracket for my 310-8. It has two and a half inches of ground clearance with a generic 12 inch weight bolted on.
      so the question is, how well do y’all think the 300 series front axle will hold the weight? It’s only 50lbs so it’s lighter than the snowblower it has to hold up in winter so I don’t think I’ll have any problems. And I really don’t intend on using it constantly.
