		D-250 clutch won't disengage!!! Help!
					By
BigMan-TinyTractor,   in Transmissions and transaxles
Similar Content-
			 By cheesegrader By cheesegrader
 About a decade ago, I bought a conversion kit here to remove the column drive lever and convert to a foot pedal for a 520h.
 I would like to convert a second tractor, and I need to replace one of the linkage bars on the first one that has cracked, but I can't find the vendor any more.
 Does anyone remember who made this awesome mod, and where I can find them?
			 By giant_g2 By giant_g2
			 By tractorboy79 By tractorboy79
 I was looking around on ebay and noticed that hydraulic actuators from John Deere 312, 317, etc models appear to be Identical to a Gt14 or d series lift cylinder. My question is would a new cylinder from ebay be able to replace one that is on a gt14 or d series?
 Images below of cylinders to show similaritys.
			 By BuffaloD200 By BuffaloD200
 '74 D-180
 My friction disc in gone on my clutch. I saw the old post about making a new friction disc, so I'm not concerned about that.
 I managed to remove the front clutch plate and double v-belt pulley. But I can't separate the two. When I took the assembly off the spiraloc washer popped off on its own. I HAVE READ THE MANUALS.
 So I should be able to just remove the pulley from the front clutch and continue with step 4. The v-belt pulley is loose as all hell and flops around like a dead fish. It seems to be hung up on a ring or bearing race.
 So my thoughts are grab a BFH or sparky the blue tip wrench.
 Is there an unpublished step 3.5, or some trick?
 Hey all,
 My '74 D180 has a lot of trouble pushing snow. Weighted tires, but nothing else at this time. I've found it gets stuck frequently and only one wheel spins. Do these tractors not have a limited slip/locker arrangement? How does everyone manage with the infamous one wheel peel?
