tsmall07
My mule drive fell apart - 520H
tsmall07
My mule drive fell apart when I was plowing this winter and I grabbed all the parts I saw, but I'm not sure I got everything.  Seems like there should be some spacers or washers to separate the pulleys.  When it goes back together, I'll put a cotter pin through the nut.
groundhog47
Yes a spacer goes between the two pulleys and outer pulley and guard, outer pn 101757 and middle (inner) 101734. The hex nut looks wrong type, parts just calls a hex nut but it has a serrated pattern on back to sorta lock in place Pn 3219-7 (old # 915007)
Edited by groundhog47
tsmall07
Thanks!
Edited by tsmall07
gwest_ca
1/2" long spacer part number 101757 is on the outside between the pulley and cover.
5/8" long spacer part number 101734 is between the pulleys.
Spacer ID needs to slip over 3/4" shaft.
Garry
tsmall07
I think I'm going to try to cut some out of some 3/4" pipe.
Sarge
Actually , those spacers are thin wall tubing - they must fit against the race of the bearing and not interfere with the pulley facing , or it will destroy the pulley . You'll have to measure the largest diameter that will fit the center portion of the bearing race and order the appropriate bushing material or source the spacers from McMaster or similar . Some hardware stores like Ace carry thin walled spacers that could be cut to fit it . I've had to make new ones for the older mules on several of my units due to bearings seizing up and tearing up the bushings ....it's a time consuming project but not all that hard .
Sarge
tsmall07
Yeah, I thought about that later. Maybe I'll try copper pipe. I've got a lathe, so I could always turn down whatever I use. I see people listed part numbers above. Where would I look for those if I wanted to buy them?
groundhog47
Electrical conduit might work, but if have to by a piece dealer would prob be about that price and your spacing is important. If I get to my spares will get ya a measurement, we know ID a slip over/ loose fit 3/4", length is culprit for now!
tsmall07
Someone posted the length above.  They're cheap enough I'll just order some
Mushrush
What the size of the nut? I just lost mine.
8ntruck
I'm thinking that the nut that holds the pulleys on my mule drive is a Nylok nut - another McMaster Carr part.
Lee1977
It's a 3/4" fine thread nut. None of my mule drives have a lock nut.
Wayne0
On mine, the nut holds the belt guard on. Not a locking nut.
Guards seem to go missing on older units.
Edited by Wayne0
  • Similar Content
    • Chaz54
      By Chaz54
      Full set of NOS Wheel Horse Chrome Embossed Hubcaps for a 520H.
      Let me know if you have questions, need more information, pictures, etc.
      Buyer pays shipping. Located in Washington, MO 63090
    • rustyedge1
      By rustyedge1
      The local place I’ve bought parts from for years has changed owners, now they can’t even spell Wheel Horse let alone be if any help.
      Doing my spring tune up I noticed my drive belt is getting pretty ratty. Due to all I’ve read thought I’d ask for some advise on getting it right the first time on a new belt.
      Is there still dealers on this site selling OME stuff ? I know there are tons of aftermarket crap but not looking for that.
      Thank in advance.
    • Gettysburg Axel
      By Gettysburg Axel
      In search of a mule drive for a 60 inch deck for my 520. Located near central Pa or able to ship if possible. Also would be interested in trading parts for the mule drive if wanted.
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor!
      Newer Agro Tires on Rear and Solid Front Turf Tires. Wheel Weights on rear. Fully Swapped Forward Swept axle off of 520h. I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      $1175 OBO   -POOS
      (248) 9for3-8six3four Text or Call. I do not visit this site enough. God Bless.
      NEW SEAT INSTALLED ON THIS TRACTOR! Started it up and ran it for a while yesterday... Forgot how nice this thing is. Tempting to keep it but it's time to send her one her way. GREAT TRACTOR!
    • gwood
      By gwood
      Question: I'm looking at the seat and decal drawing and could use an answer! Does the the seat spring or the adjusters go under the seat? It looks like the adjusters go directly under the seat and then the springs under the adjuster. If so, where does the spacer (110932) go?   The reason I ask is the seat is quit low and the back sets low making it hard for me to reach the brake/ return to neutral pedal.
