koalassquad
314-8 not charging
koalassquad
My wheelhorse 314-8 won't charge the battery while its running, it used to but now it doesnt. The wiring is stock as it came from factory. Runs good, just have to jump/charge It every time
953 nut
:twocents-02cents:   With the engine running near wide open throttle what is the voltage reading at the battery? The first step in solving any electrical problem is to have the battery load tested. Next, clean and tighten ALL electrical connections including grounds. The voltage regulator is bolted to the frame and if this connection is corroded it will prevent it from working properly. Take these steps and let us know what you find.
koalassquad
On the tractors voltometer, you can watch the battery drain while running, its aggravating, I go do work with it and turn it off to talk to my customer, and have to jump it. But will do the others
pfrederi
is this a 1985 314-8 with a K-Series?  Only year they used them on 314s.  1993-98 314-8 used magnums which draw no current while running.  If your 314 is a newer one and the battery voltage drops while it is running you have another issue as a short perhaps???
  • Similar Content
    • DevonianHorse
      By DevonianHorse
      Hi all, on a 1977 Wheelhorse C-100 (Belgium made), I have a question
      My Wheelhorse hood opens really far- it does eventually stop but I don't think it is meant to go this far and that there's a piece missing.
      In this photo, there's a hole you can see (near the middle of the pic, 1/3 down) and the same on the other side of the hood mounting part of the frame- I assume some sort of bar is meant to go between them that the hood latches at the base will catch on and this stops the hood dropping further when opened? If this makes no sense sorry- I have simply always assumed that the hood is meant to open at a right angle from the front, but having seen videos, I can see most stop before that.
      Does anyone know the part I need, or would two bolts, one on each side, do the job? Mine has never had one, so I am unsure.
      Thanks!!
    • crich8878
      By crich8878
      Its a 1969 GT-14
      Mower, snowblower, tire chains attachments
      Everything works.
      Always stored inside, just dusty.
      Model: 1 7441
      Serial: 555525
      $1500 OBO
      (*just took the hood off to get it running in the video, its there*)
      IMG_7731.mov
    • Donavon1
      By Donavon1
      Need some help deciding on a brand of engine to buy for my 1054. (Needs to be a diesel 10 hp+) I’m refining used motor oil/cooking oil for fuel for it. So it will have to have an option to run used oil and diesel
    • MainelyWheelhorse
      By MainelyWheelhorse
      Hi All, I’m a member of the RedSquare Facebook group, some of you may have seen My tractor there. I have a 1992 312-8 with a 37 inch deck. It came with a house my brother bought, and was given to me. It needed work but just minor things. I mow my lawn with it, and I just bought a plow to push snow/dirt so it’s a working restoration. It was relatively well taken care of by the previous owners so it really just needed a refresh. Anyway see you around the site!
    • Monstrosity
      By Monstrosity
      Show off what your doing from the seat of your Horse!!! Fixed up a mowing deck for the 1277 and put the plow on the C1014. Getting ready to level a topsoil pile and going down the block to mow the small park to test the mowing deck out.
