Fin_
C-125 Won't Fire
Fin_
Alright will try again even though I did it very slowly for a long time and will recheck the point gaps.
pfrederi
It might be easier in the long run to remove the air shroud find the marks paint them and then put the shroud back on.
Fin_
Yeah will do that today.
Fin_
Took of the air shroud and tried looking for the markings. Would this be a T marking, it was the strongest marking I could see.
Tim.0
really hard to tell from the picture..... the T and the S are not far from each other on the fly wheel
gwest_ca
If I remember correctly the timing marks are on this part of the flywheel. I don't see a T.
Garry
Tim.0
Searcher60
Judging solely from the amount of rust in that pic on the flywheel, your timing marks are long gone. The timing was never the problem as it ran before you parked it. First I would have checked for spark. If I didn't have it, checked for 12 volts on the coil with the key on. If present, I would have filed and set points , and recheck for spark at the plug. More than likely there was a coating on the points, or a fuel problem. The timing doesn't get off sitting.
6bg6ga
Searcher60 has hit the nail on the head. The timing marks are gone not that you actually need them unless your using a dwell meter and timing light. Its a pretty simple procedure to set a simple set of points. Its not a set of dual points on your 406 Tri-power Ford after all. At .015-.020 it will start and run provided the points and condenser are good as well as the coil and your getting voltage to the coil under crank and run.
This is not rocket science. Anybody, heck my 9 year old grand daughter could set the points and get it running. Too much effort set forth trying to uncover the missing timing marks. Lets move on and devote the time to figuring out why it isn't running instead of crying over missing timing marks.
rmaynard
When an engine runs, then is shut off and sits for a year, and when you try to start it again it won't fire up, it's not a timing problem. It's either oxidized points or a fuel problem. Timing won't change, spark plugs don't go bad just sitting, nor do ignition wires. Condensers can break down, but it's not common. Oxidized points will cause you to not have a spark. If you have a spark but a wet plug, you are flooded. Check the float valve when you take the carburetor off to thoroughly clean it.
6bg6ga
Another LOGICAL post..  :techie-eureka:
pfrederi
Going back to original post He said he had fuel compression and spark
Wheel horse c-125 with kohler 301 engine wont fire but turns over. I have made sure there is fuel getting to the engine and there is a strong enough spark to start it. Also we have good enough compression.
So what is the problem?
rmaynard
Since there was a lot of talk about the timing marks, here is how to find the approximate location if your flywheel is rusted.
This is where the marks are located, and what they are supposed to look like. This is a K301 flywheel.
So, with the cover off, looking from the front, remove the nut and locate the keyway. Place it at the top (12 o'clock). Your TDC (T) mark will be at 9 o'clock with the (S) mark 5-1/2 to 6 teeth toward the top.
pfrederi
Interesting info Bob.  I was working on a 10 Hp K241 on a 1075 (has a S/G),  the timing hole is on the rear side of the shroud.  On My 310-8 it is on the front. Apparently when they started putting ring gears on for electric starters they moved the timing marks and the sight hole.  Having them up front near the points makes life a lot easier...
  • Like 5
rmaynard
This flywheel is typical of a K-series with Bendix-type starter. Since @Fin_ is working on a K301AS, this should help him locate the marks if they are still there.
Fin_
Thanks for the help will look later today! Seems like were a bit mislead at the start.
Edited by Fin_
Tim.0
If it was my engine just beside getting it going I would want to find the timing marks anyway. Never know might need them one day. Then I guess that's just me.
Fin_
Just filed down the points and we are getting a much stronger spark than before but still doesn't start so I'm going to look at the fuel again.
pfrederi
How are you testing the spark? Laying the plug on the block is not always a good test.   i assumed you had cleaned the points when you adjusted them.
Spray carb cleaner in as you crank does it fire???
Edited by pfrederi
Searcher60
Is the gas good? Compression good? If you squirt  a few drops into the carb, then put the choke on, does it start for a few seconds?
6bg6ga
Correct.  One needs to dress the points first followed by dragging a clean piece of newspaper thru the points to pull out any debris. Once the points are dressed ( free of pitting and level) and clean then and only then does one set the point gap. As pfrederi has suggested you can spray a little carb cleaner in or a little starting fluid/ether. In your situation I would suggest purchasing a spark tester. Remember knowledge comes from experience and maybe you might need to start at the beginning if you don't get results.
Good job on the flywheel pictures. Takes all the guess work out of re-marking the flywheel if someone desires to do so.
6bg6ga
Fin
With a clean feeler gauge re-set the points. Spray a little starting fluid down the carb, close the choke and hit the starter and see if it starts.
Fin_
We have cleaned and re-set the points with a feeler gauge and I will try spraying starter fluid down the carb once again, thanks.
Fin_
Yes it finally started.... Then it cut off again probably because I for some reason turned the choke off after I got it going. There was some fluid slowly seeping out of the spark plug hole so I tightened it and put some lock-tight on the thread, will update on how it goes tomorrow. Might be a fuel issue.
pfrederi
You should not need locktite on the spark plug ...Are the threads in the head OK???   Dod you plug have a metal gasket on it??? Did you torque it to spec??? 18-22 ft lbs
  • Similar Content
    • Gcw804
      By Gcw804
      I have a WH 300 series with a Kohler Magnum 10 engine and I cannot for the life of me figure out how to get the choke cable and linkage set so it will work. The numbers on the engine label  are worn off the, so I cannot give anyone that information. Does anyone have a picture or can you head me in the right direction.
      My arm for the linkage assembly is set at 3 o'clock and 9 o'clock if that helps. There seems to be several different linkage rods for this engine.
      Thanks
      Gary Williams
    • cJ_3D
      By cJ_3D
      Hey all!
      Replacing the drive belt on my 252-h. Anyone know the torque specification for the center screw when I put this pto clutch back on? I know it was on there tight it took a minute for the impact to break it loose. Thanks!
      CJ
    • bkarp@roadrunner.com
      By bkarp@roadrunner.com
      my magnum 12 kohler all of a sudden is blowing oil out of the carb. if rings are bad should oil be blowing out of the muffler.thanks for any help brent
    • Tinman1962
      By Tinman1962
      Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
    • Little Red Horse
      By Little Red Horse
      Hey all. I have a Electro 12 with a factory belly blade. It runs* and drives. I had used it to grade my driveway the last 6 yrs. Having moved I'm looking at my options on storing it or selling it. Frankly I have no idea what it is worth. I watched "ISaveTractors" video on 5 things to do with a new to you wheel horse/12hp kohler. (When i got it 6yrs ago) And went thru and did the adjustments and replaced the parts mentioned. It has been a good strong tractor for me until around July of this year. (2023)
      *Around July it started dying after running 20-30min. I replaced the carb (Chinese Amazon purchase) with one from isavetractors web site. That seemed to help it idle smoother(the old carbs jets wouldnt adjust), but it still dies at around 20-30min.
      So I've got 2 questions.
      1. What is it worth? (As-Is) and
      2. What do I need to do to fix it?
      Thanks yall!
