Team70R
42MS02 Deck Not cutting consistently
Team70R
I'm used to messing with the narrow, rear discharge decks. The deck on my newly acquired C165 doesn't seem to cut evenly with multiple passes. It cuts great with one pass but if I make a second pass the grass is super uneven! What do I need to adjust to make it cut consistently? Here are some pics after 2 passes, in the same direction
slammer302
are the deck wheels in good condition? Maybe a pic of the whole deck so we can see what ur working with.
Team70R
They are all there and seem to be sturdy. I'll have to get a pic when I get home
Team70R
Sorry pics are terrible. Best I can do tonight. Has a total of 7 wheels with 2 of those being the adjustable ones on the rear. Am i not using the adjustable wheels and the adjuster knob for the lift handle correctly?
AMC RULES
Edited by AMC RULES
Team70R
3 minutes ago, AMC RULES said:
I don't think it's a uneven blade issue. It cuts even if I make one pass. But if I make I second one it doesn't line up with the first pass. Maybe it's just more noticeable after 1 pass?
AMC RULES
It's definitely got an issue...
could be somethings up with it's mount.
Team70R
One of the spindles is squeaking too so I guess that gives me enough reasons to take it off for a full inspection
daveoman1966
Deck mounted correctly and LOCK IN ? ? ?  If one side isn't locked in, it will run lower than the other.  That is, the deck is TILTED ....
 Make sure it is locked in place ON BOTH SIDES.  Here is a pic or two....
My only other idea is that MAYBE the outside spindle itself is tilted, causing it to cut lower than the other(s).
Team70R
I got to thinking last night and looking at the pics of how it was cutting and I think this is problem! Seems like it is a tilt issue with the deck! I'll have to check the mounts tonight!
Team70R
Well I got the spindles greased up everything seems tight and straight. We got to looking at the deck wheels and I noticed the adjustment bracket is wayyy bent. Hopefully the pics are good enough to show. Now I have to figure out how to straighten it. The detent spring and pin fall out of the respectable retaining hole!
tunahead72
That could definitely be part of the problem.  It's hard to tell from the photos, but is the upper corner of the bracket (to the right in your photos) bent more than the rest of it, like somebody's been banging on it with a LARGE hammer?  And it looks like the bracket itself isn't mounted flush and tight to the deck -- are those two carriage bolts in good shape, or do they need to be tightened or replaced?  Is the deck basically straight where the bracket mounts, or is that area damaged also?
I would also check the large round cross bar that connects the two wheels -- is it basically straight and mounted securely to the deck?
This old thread might help:
An important note:  This thread I just linked was damaged a bit in one of the software conversions that RedSquare went through a bunch of years ago.  TT's first response in particular was cut off, but here's the complete text:
"If it isn't a broken spring on the handle, 80% of the time the selector quadrant gets pushed or bent away from the gauge wheel "channel"/handle.
Remove the quadrant and bend it back to 90 degrees so it fits tight against the channel, or loosen it and slide it tight against. (if it isn't bent)
The other 20% is the square (looks like keystock) stops welded to the gauge wheel cross bar getting worn enough to let the entire gauge wheel assembly push away from the quadrant."
Edited by tunahead72
Team70R
The quadrant is not even bolted on straight. It looks like the carriage bolts have started to pull/tear from the deck. So I'm gonna have to do some reinforcing I think
Racinbob
You nailed it there as far as that bracket goes. Get that sheetmetal straightened out so the bottom of that bracket is parallel with the cross rod, reinforce underneath and you'll be fine. I'm not sure it will fix your uneven mowing though. :)
Team70R
Haha I hope this fixes it!! Not really sure what else it could be :blink:  here's a few more pics I took after we messed with it a little last night. Hard to judge by the pics though
  • Similar Content
    • GeoC-120
      By GeoC-120
      The time has come for me to part with my trusty Wheel Horse and find it a new home. I am the second owner (since 2003) and it has always been stored in a garage.
      I am located about 20 minutes south of Rt 80 or 15 minutes north of Rt 78 near Rt 33.
      1975 C-120 Special, 8-speed (Model 1-0375, Ser. # 133357). Running (no smoke) 12 hp Tecumseh (Model HH120-120180E, rebuilt 1986). Rebuilt carb, new fuel pump, and new ignition module (in 2006). Good used replacement tank, original tank is included in the sale.  Brand-new battery, fuel filter, and shutoff valve installed 5/26.
      Solid 42” side discharge deck (Model 5-1010) bearings replaced in 2005. Extra set of Gator mulching blades and spare hi-lift blades included. Deck works as it should and is ready to cut.
      42” snow/dozer blade (Model 86-42BC01) with Rear weights, tire chains and hardware. Blade angles left and right and lifts correctly and is ready to plow.
      Parts: 4 NOS belts and 2 good used belts, NOS taillight lenses, used starter, used ignition module, more (see pic).
      1975 C Series Owner’s manual, 1975 WH accessory catalog, 5-1010 deck manual, original HH-120 manual, updated Tecumseh HH-120 technicians handbook.
      Selling entire package for $300 Or Best Offer.
      Will deliver within 50 miles of zip 18064. Delivery over 50 miles is negotiable.
      Please PM to contact
      HH120_running.mp4
    • morePEdal
      By morePEdal
      *16 HP Onan Engine, 665.4 Hours
      *8 Speed Transmission
      *48” Snow Plow- Works Great! Set up and READY TO GO BEFORE THE SNOW!
      *Nice 42” Mowing Deck, no rot or welds, smooth spindles
      *OEM Wheel Weights, 50 lbs. Each
      *Chains
      *Valves adjusted this summer, runs great!
      *Good battery
      *Tires All Hold Air
      *LED lights all the way around
      *Manuals included
      Bought a Honda tractor with 4WD and 4WS with deck, plow and snowblower so I don’t need this tractor.
      Cash Only!
      *WILL NOT RESPOND TO “IS THIS STILL AVAILABLE?”
      *COMING SOON:  Also selling a Wheel Horse 520H with a 2-Stage Snowblower. Check out that listing if you want a snowblower garden tractor!
    • cJ_3D
      By cJ_3D
      Hello helpful Wheel Horse enthusiasts!
      Maybe you all could help me figure something out. I don't think I am installing the mower deck properly on my 1989 252-H and I don't know if the PTO clutch is adjusted right.
      So referencing this image here from the service manual for the mower deck (37"):
      What exactly am I doing with this adjustment knob and how does it fit into this piece?
      Also for the PTO clutch where am I sticking the feeler gauge exactly and do I need to do all 3 springs? Or does adjusting the one in the manual adjust all three?
      Much obliged for the help!
      CJ
    • lsc1257
      By lsc1257
      I have a 1996 520H Wheel Horse for sale.  The tractor has just over 800 hours on it.  It comes with a 48 inch deck.  The deck is a 1995 and has over 1,500 hours on it, as it came brand new with my 312-8 that I sold several years ago.  This 520-H has the swept front axle so it can handle a 60 inch deck.  I just replaced the battery and the deck belt this summer.  The engine is a 20HP Onan and it starts right up but requires the full choke.  The transmission is an Eaton 1100-062, hydrostatic.  The deck is in rough shape but the spindles appear to be in good working order.  The right rear tire has some cracking.  The original operator's manual for the 520H is included, as is the original operating and maintenance instructions for the deck, plus the installation instructions for the deck.  Also included is a new PTO belt and several miscellaneous deck wheels and rollers.  Additional pictures available upon request.  Asking $500.
    • BrianKoch
      By BrianKoch
      Gentlemen,
      I’m having trouble with getting my deck to raise up and lock and I think it might have to do with the deck being incorrectly set up.
      Based on the picture, does my mower deck look incorrectly positioned? That is, should the pivoting support bar be positioned above or below the wheel support pin?
      Brian
