Red144runner
Wheelhorse Dozer
EricF
So far this year I've used the blade with mine to smooth over the edge of the front yard that serves as the shoulder of the street where the kids still living with us park their cars -- cleaned up the ruts made during the winter. Then moved some decorative day lilies away from the edge of the driveway and skimmed off the old mulch and soil that had piled up too high and re-graded the strip.
That's so far. Coming up, now that I've taken  down an above-ground pool, I've got to scrape up the sand and some of the compacted soil that was underneath it. That gets moved as fill in a sink hole where a tree used to be and the roots decayed and caved in, then I can put down some loam and grade it over, then re-grade where the pool was too. And the flower beds around the house need to be re-done, and there's a bunch of scrub brush and sumac in the back yard that's actually growing on top of some fill left behind when the house was built that can be pulled out and the fill re-used in a couple of spots...  The blade is really coming in handy and I'm just using it for earth work. (For snow in winter, I've got the 2-stage snowthrower.) So far, I haven't had to put the wheel weights on for the light work. I expect I'll need them when I deal with the more compacted stuff that was under the pool, although the soil here is sandy and breaks up pretty easily. The 520 will definitely earn its keep as a work Horse!
The nice part about using the tractor is that it's got the muscle to move material, but it won't tear up the lawn around the project like a skid steer or anything with crawler tracks will. Might not be as fast, but slow and careful gets the work done without making another mess... and another project. :thumbs2:
  • Like 3
Blasterdad
Used the C-141 for grading my carport project this spring. :wh:'s move dirt well.
  • Like 6
BaySide1
I moved three yards of trap rock for my new shed back in April.
Not even a challenge. About 7 minutes of work.
(Worcester, MA)
My new workshop
  • Like 4
Red144runner
Nice work with the tractors! The next project for mine is dragging a chain cultivator across the "lawn". I'm a grounds guy and my new house is great, the land is terrible. The development was done in a former sand pit. Houses are beautiful, good sized lots but 2" of top soil on native sand makes growing difficult and the fact that the seed was a annual blend. Comes up beautiful the first year. I couldn't believe how easy it moved the stone
Digger 66
:D
Tankman
Moved three dump loads of blacktop millings. Was easy enough, 48" dozers, 416-8 Horse.
Then pulled a 4-ft water filled roller, Horses loved the wo...wo...WORK!
The Stallions think work is playtime! :ROTF:
Edited by Tankman
Red144runner
1 hour ago, Digger 66 said:
:D
My shed came!
JPWH
4 minutes ago, Red144runner said:
My shed came!
Looks like you.have been evicted before you got moved on. lol You may as well order more gravel.
Red144runner
At least it's cheap. Cost me $37 for just over 2 yards picked up
  • Similar Content
    • Red144runner
      By Red144runner
      Every winter I go through all my spring/summer equipment, I sneak it in with the equideerpment at work. First on my list is the deck off the tractor. It is in very good shape, luckily the previous owner did do minimum maintenance. First things first pull those blades off. Last year they put up a good fight, the nuts were way too tight but they came off with some heat. When I put the nuts on last year I know I didn't crank them down but it was even worse.
      Try 1: 1 1/8" impact gun. Wouldn't budge. Kroil over night
      Try 2: impact again, no luck
      Try 3: 3/4" socket wrench with 1 1/8" socket and heating up nuts with acetolyne torch and 2 guys holding deck, 1 1/8" wrench underneath. Success.
      The threads were good, but dry and rusty. I'm gonna never-seize them this time. Next scrape and wash the deck ready for prime
      Ill also add these decks are super tough. Not only are the spindle bolts huge (industry standard usually 15/16" nuts these are 2 sizes up at 1 1/8") the deck never deflected being pulled in separate directions. I've broken lesser machines using much less force
    • Red144runner
      By Red144runner
      Today was the day to start redoing my yard. It's been embarrassing me since we moved in May. The sub-development we live in was a sand pit in its former life. They contractors layed down 2" of topsoil down, sprayed some hydro seed down and called it a day.
      I borrowed half of an old drag harrow from work. Missing the front bar so didn't work perfectly but good enough for my purpose.
      Hooked up my 2" receiver on, a shackle and chain hooked up to another chain on the drag. I pulled it along but it wasn't digging in like I wanted. I a spare set of rear wheels with 100lbs of cast iron on them, chained them to the drag. All said it was over 200lbs. Worked great 👍. I ran it 2 low only because 1 high pulled a little fast. Pulled all that weight with 2" spikes angled into the ground up hill with ease. Still have to rake the back then spread 16 yards of loam
