Team70R
Tecumseh sputter, worse under load!
formariz
Here is timing procedure for Tecumseh engines from Brian Millers site; Great simplified description on how to do it. I always follow this one.
First of all, on virtually any spark-ignition engine, advancing or retarding of the ignition timing is performed by widening (advancing) or narrowing (retarding) the ignition point gap, and on Tecumseh engines, it's also performed by rotating the ignition stator (the aluminum part the points, condenser/capacitor and coil are fastened to) one way or the other. On all aluminum block flathead Tecumseh engines, the entire ignition system is located under the flywheel. (There is no points lobe on the camshaft.)
Using a feeler gauge, set the ignition points at 020". NOTE: Be sure the end of the plastic lever arm is on the highest side of the rubbing block (points lobe) in alignment with the arrow (6). And make sure that the feeler gauge, points contacts and rubbing block are absolutely clean! Also, apply a small dab of automotive grease on the rubbing block to prevent the plastic lever from wearing.
With the cylinder head removed, for all Small Frame engines (up to the small block 5hp; including all walk-behind lawnmowers, some small snowblowers, garden tillers, etc.), rotate the crankshaft in normal rotation (clockwise when facing the flywheel) until the piston is positioned at .070" BTDC. For all Medium Frame 5hp [big block] and 6hp cast iron and aluminum block engines, position the piston at .050" BTDC. And for the Medium Frame 7hp, 8hp and 10hp aluminum block engines, position the piston at .090" BTDC. To position the piston at the correct height in the cylinder, use a dial indicator or a large flat washer of either .050", .070" or .090" thickness placed on top of the piston with the piston even with the cylinder deck height.
Slightly loosen the two stator retaining bolts, and rotate the stator by hand JUST when the points begin to open. It is at this point when spark occurs. Do not rotate the crankshaft to do this! You can visually see the points open. But for a more accurate setting, use an ohmmeter (d) (make sure the battery is fully charged) or a battery-powered test light in the points only (the points will act as a switch to turn the light off and on).
Tighten the stator bolts and the ignition timing is correctly set.
NOTE: If the ignition timing is set correct and the engine kicks back upon starting, sometimes, but not always, the compression release mechanism on the camshaft isn't releasing enough compression from the combustion chamber. When this happens, try setting the valve clearances to specs (.008" intake / .010" exhaust) and see if that makes a difference. If the timing is retarded to reduce the possibility of kickback, then the engine will be hard to start, run sluggish and not produce adequate power.
Here is link to actual site http://gardentractorpullingtips.com/ignition.htm
Lots to read and learn from in addition to great reference information on parts #s. I am on it all the time.
Here is also a good reference video for it. Nothing like watching someone do it.
Team70R
Awesome thank you! I got the new coil on, pulled the plug and grounded it on the head and it is still doing the same thing. Only sparks when it wants to. I can feel it if I grab the plug but it's very weak.. :think: help!! Haha
Does the condenser need to be in full contact with the mag here?
Team70R
Got the spark back by moving the condenser to contact the stator.. but it still won't rev. Just sputters and smokes
IMG_2434.MOV
formariz
I am not sure you got the correct condenser. Should be screwed down on stator so it is properly grounded otherwise it will not work right. There is a specific condenser for that one. Let me see if I can get you a # and photo of it.It is an h60 you got correct?
Team70R
Correct. It is screwed down underneath as well! The coil ground wire is also connected with the same screw. I bought the condenser for my old hh60 and never used it
formariz
Lets see. New condenser, points ok, new coil, new carburater. Still same condition ? Did you get to check timing on it yet?
6bg6ga
https://www.harborfreight.com/timing-light-with-advance-40963.html
It doesn't have to be a SUN or other high dollar light. Got one of the old unpowered timing lights? May have to run the machine into the garage to get out of sunlight to use it and those straight connections to the spark plug wire can zap you when you forget its not an inductive pickup but will still work. The harbor freight link will steer you to a cost effective light or you may possibly have a car parts store that will loan one out.
Team70R
Gonna try to check the timing tonight. May have to get a light if I can't get it set
Molon_Labe
Wes, have you checked the flywheel magnets to make sure they are firmly in place? The main reason the timing is so critical on these things is that the points must break at the exact same time the coil reaches peak voltage. If you have a spare flywheel you might try swapping them to see if it makes a difference.
Team70R
 I checked be magnets and they are still firmly attached and have good strength. I thought about trying a different flywheel wheel. I've got a spare I'll put on if the timing doesn't fix it.
Team70R
Well I feel like an idiot for not checking it sooner but the timing was way off!!! Points were opening after TDC:o advanced the timing as far as possible and it runs great!! Just need to adjust the Rpm now!
  • Like 5
Molon_Labe
Wes, glad you got the old girl going. As you have learned, there is not much room for error on these old Tecumseh's! When they are dialed in, there is nothing better. Congratulations!
Team70R
Thank you, Major! It's definitely a good feeling! And another lesson learned!
Molon_Labe
Forgot to mention, when they are not dialed in... well you know the answer to that. Tecumseh made great engines, however, the ignition systems and carburetors were "marginal". When everything was set to specs they were (are) as good as anything offered today. :thumbs:
Team70R
I agree!!! Just takes time and patience!
  • Similar Content
    • GeoC-120
      By GeoC-120
      The time has come for me to part with my trusty Wheel Horse and find it a new home. I am the second owner (since 2003) and it has always been stored in a garage.
      I am located about 20 minutes south of Rt 80 or 15 minutes north of Rt 78 near Rt 33.
      1975 C-120 Special, 8-speed (Model 1-0375, Ser. # 133357). Running (no smoke) 12 hp Tecumseh (Model HH120-120180E, rebuilt 1986). Rebuilt carb, new fuel pump, and new ignition module (in 2006). Good used replacement tank, original tank is included in the sale.  Brand-new battery, fuel filter, and shutoff valve installed 5/26. The transaxle case broke a small piece off (about 1” long by 1/4” wide) on one side of the center flange and was repaired with JB Weld.
      Solid 42” side discharge deck (Model 5-1010) bearings replaced in 2005. Extra set of Gator mulching blades and spare hi-lift blades included. Deck works as it should and is ready to cut.
      42” snow/dozer blade (Model 86-42bc010),  with Rear weights, tire chains and hardware. Blade angles left and right and lifts correctly and is ready to plow.
      Parts: 4 NOS belts and 2 good used belts, NOS taillight lenses, used starter, used ignition module, more (see pic).
      1975 C Series Owner’s manual, 1975 WH accessory catalog, 5-1010 deck manual, original HH-120 manual, updated Tecumseh HH-120 technicians handbook.
      Selling entire package for $325 Or Best Offer - Deck/Blade/Weights/Parts alone are worth that!
      Will deliver within 50 miles of zip 18064. Delivery over 50 miles is negotiable.
      Please PM to contact
      HH120_running.mp4
    • ebinmaine
      By ebinmaine
      A HUGE thank you to Tony @Docwheelhorse for settin' me up here.
      The generosity of some of our members never ceases to amaze me.
      This here is another 1974 C160, but with the rare Tecumseh HH/OH160 OHV engine. Made one year only.
      It's rough. Very much in need of a full disassembly and restoration.
      When it came here it was missing one tie rod and the other was broken off one end.
      Today I popped used tie rods on and Trina used her 867 to drag it from the drive to the shed.
      The engine wouldn't move.
      Tin was near chock full of skeletal mouseseses and their house.
      Cleaned that out and the engine spins freely now.
      So progress has been made.
      It'll be a good long while before we get to this one but I just couldn't turn it down considering the rarity.
    • Nathan
      By Nathan
      Can anyone help finding year of this tecumseh motor off a 603. I need a carburetor.
    • ebinmaine
      By ebinmaine
      We're going to take apart the Tecumseh from my Honey's 657 so I can replace the crankshaft.
      Any little tricks or tips I need to know about?
    • ohiostate454
      By ohiostate454
      So I have been working on a 656 I picked up at the end of last year and I did my first ever motor rebuild by my self on it. However it seems that I have lots of play in the piston and some slop at TDC more then I should have. So to finish the year mowing I am thinking of doing a predator swap while I go over the engine again. I am sure several people have done this before and I have a spare mounting plat to make it work. I am wondering if anyone has any pictures of ones they have done for help along the way. I know I will need a adapter to use the factory pulley and I don't want to destroy any of the sheetmetal since it is in good shape. I will keep you posted as I go along and eventually when I get the hh60 back together correctly to re install.
