Searcher60 209 #1 Posted April 19, 2017 How can one tell if a Kohler engine is really a K321 or K341? Is all the tin between the two interchangeable? Is checking the bore the only way? If the bore is 3.70, and the piston is stamped .020, then I would guess the engine is a K321 bored out .020? Thanks Share this post Link to post Share on other sites
953 nut 66,647 #2 Posted April 19, 2017 Check this out. Kohler Single Cylinder Engine Specs _ Torque Values and Sequences for Fasteners _ Identification & Torque Settings of Most Commonly Used Grades of Bolts (1).html 2 Share this post Link to post Share on other sites
Aldon 4,832 #3 Posted April 19, 2017 If you click the link on Torque on the page @953 nut provided it takes you to a page that shows the top of the head and bolt patterns. 2 Share this post Link to post Share on other sites
wildman 205 #4 Posted April 20, 2017 10,12 and 14hp have 9 head bolts and 16hp has 10 head bolts 1 Share this post Link to post Share on other sites
roadapples 6,987 #5 Posted April 20, 2017 The casting will have K321 or K341 behind the drive pulley... Share this post Link to post Share on other sites
