Fungus221
What the proper way to align mower blades
Fungus221
Hi everyone I have a 312-8 wheel horse over here in the UK. and I have just repaired the mower deck I beleve it is Model: A5-42MS02, as it had become rether ventilated.  hole were there should not be holes.
On putting back to gether I can ont find if there is a proper way to align the blades.
has anyone got an idea how they align or does it not matter?  can i just bolt them back on any old how?
heres a photo of my wheel horse.
Edited by Fungus221
misspelt words
WHX??
No they do not need to be aligned or anything just bolt them up flat side down.
BTW :WRS:
  • Like 4
pfrederi
Alignment was only an issue with the older gear drive decks...they would hit each other.
Fungus221
Brilliant! I thought I would get an answer on here. thanks for the help, and so quikly.
It was a bit dark, time I got it back together but here are some pic's of work in progress.
turned out to have been some previus patching done! so I cut that out also.
just a little patch was needed to the left and a big chunk cut out on the right!WP_20170312_002.jpg.60aab0273c2cb450fad490d63dc6038b.jpg
shaped up some replacement patches. then welded them in.
dress down the welds! treated the rest with Fertan rust converter (brilliant stuff) WP_20170314_007.jpg.717c991f327433b376f95e63aa9adf9a.jpg
Ready for painting. I am going to use a two pack epoxy paint (another brilliant product) on the under side. and a red metal coat on top. the suppliers recon they can match the wheel horse colour... if they can match it ok I may restore the whole thing next winter.
underside with the fertan treatment.
  • Like 4
Fungus221
first test today!
colour did not turn out quite as they said but they are going to try again.
and I think I have put the front cradle mounting bracets on the wrong way round
under side with epoxy coating
on the body
pfrederi
Beautiful job.  yes your front mounts are reversed.  How did you make the neat cut outs in the deck.  My attempts look like i used an axe
pgiro
Good job on the repair. That was not trivial to repair that deck.
Fungus221
Thanks for the diagram. I searched everywhere for mine on the PC but couldn't find it.  It would have been so much easier if I photographed it in the first place.
To make the patch, I make a paper template of the shape of the rotten metal on the deck, so I can cut out the metal needed from a flat sheet. (Always cut it a bit bigger then I need) then use a flat and ball head hammer and a bag of sand to shape it to the curves as best I can. ( I would usually use a panel beating hammer but couldn't find them. packed away when we moved and still there I think) cut out the bad metal from the deck with  angle grinder and air saw to the shape of the paper template, then when the shape is right I'll trim it down to fit the cut out. tack it in, check the line-up and weld all round.
And no I haven't done this for years. It just seemed the best way to do it. There is nothing better them hitting some metal with a big hammer to reduce the stress, and if you make something in the process, all the better!
  • Similar Content
    • rustyedge1
      By rustyedge1
      Need a condenser for engine shown in photos 8 hp Kohler. Any venders carry them on this site ?
      All help appreciated..Have PayPal or can send check..
    • Fordiesel69
      By Fordiesel69
      Looking for the OEM nelson muffler that fits the Kohler Magnum M10 thru M16 engines found on the following tractor list:
      310-8
      310-H
      312-8
      312-H
      314-8
      314-H
      410-8
      410-H
      412-H
      412-8
      414-8
      414-H
      416-8
      416-H
      and also and "A" models that had the kohler magnum.
      I dropped mine off to be welded and it came up missing.  It was not good to begin with so im sure they accidentally tossed it out with the way it looked.
    • WheelPuke
      By WheelPuke
      I have my 25A fuse blowing every time I put a new one in the slot. The old one was burnt up when I got the tractor put this year. It sat for a year with a dead battery. I stopped using it as much because the transmission is clattering pretty bad when taking off on second or higher. I had to replace the clutch belt a few years ago and couldn't get an OEM. Not sure what is the problem there that's another issue though.
      I have checked the wiring and patched the worn spots where it could be grounding out. The fuse blows as soon as there is power to the system with the ignition off. I'm at a loss of what to check for at this point. Any input from someone who has had this issue would be appreciated. I'm not sure what these units are in the photos but do not know how to test them for a failure. They are directly in loop with the battery and the ignition loom looks to run into that 25A fuse.
    • Redtickuleez
      By Redtickuleez
      Hello gentlemen!!! I recently bought a d180 with loader and backhoe. Im looking for serial number.. there is a plate under the steering wheel but its been pajnted over and i can make it out. Can y'all tell me another location and was this tractor pruchased originally with these attachments and any info would be greatly appreciated... Thanks fellow Wheel Horse enthusiasts !!! !! !!!
    • Aaron Coffman
      By Aaron Coffman
      Hi Red Square Community,
      I am looking into purchasing the below pictured "POND" Walk Away. The unit itself has the cast in “POND” on the chain reduction housing. The two main things I am looking to learn are what value is typical for these to sell for. This one has a Briggs & Stratton model “N” engine. It runs and drives, but the throttle linkage needs some adjusting. It comes with a cultivator and plow implement.
      Secondly, I was wondering if there is any way to determine what year specifically this Pond is from. The seller believes late 1940s and not 1950s. I am new to these machines, so I am looking for some guidance. Thank you in advance!
