john7
I suppose I should have started this back when I began restoring this plow but better late than never right? It's pretty much completed now except for the decals that I am still looking for... so technically it's still a work in progress.
Anyhow, I picked up the HD-42 plow with an RJ mount back in mid January with great help from @OILUJ52
Here's what I started with:
It had all the essential parts; blade, front channel, rj mount, lift bar, and foot pedal (no chain, though). The only things missing were the 2 skids. Everything was in decent condition with some light to mild pitting vertically along the left edge of the blade face. The "front channel", as it's termed in the parts list, came mounted on an A-frame with 4 bolts, and the piece that attaches to the lift bar had been removed from it to accommodate the A-frame setup. All easy fixes!
First things first, I made a new piece for the lift bar to attach to on the front channel, welded that on, and welded the 4 bolt holes up on both sides.
Next, I made up some skids.
I didn't snap a picture of the pitting on the left edge of the blade but I ran side by side beads the entire height of the blade about 2 inches wide - must have blown through 10 rods to do it. I filled in any other digs and gouges with welds. Being a plow, I didn't want body filler anywhere close to the blade. I did, however, use a small amount to fill in a couple of scratches on the topside of the front channel.
I made one modification that was not original. There are 2 pieces of angle iron that are bent to fit the curvature of the blade and mounted to the backside of the blade on each outside edge. These were originally plug welded to the blade leaving a gap between the 2 on the outside edge - a perfect place for water to get trapped and promote corrosion. So I welded those up on both sides. It makes the edges look much better too!
And I just realized that I didn't snap any pics of everything down to bare metal or after body work either. But, here's everything after all my fixes and shot with a second coat of primer.
I'm having some trouble attaching the after paint pics. Will post when I figure it out.
Ed Kennell
You may have reached your limit of pictures John.
To eliminate the picture limit, you must become a supporting member.
Click on the  store(support RS) above.
john7
Here's some pics after paint (PPG AUE300 in IH50), color sanding, and buffing.
I'll snap a few pics of it mounted on my RJ when I find the time.
Thanks Ed, I'll have to do that in the near future.
  • Like 4
roadapples
Now it`s too "purdy" to use...
Ed Kennell
If we get another snowless winter like this one Jay,  We may as well put all our snow machines in the museum.
roadapples
That would suit me fine...
857 horse
I just watched the weather,,,,,,,,,,,,snow Friday and Sunday........jusss   shoot me !!     loloololol
Sarge
Yeah , tornadoes the other night here , 50mph winds now for two days in a row - and snow forecast for this weekend , go figure ...
Welcome to Illinois - I think not...
Sarge
  • Similar Content
    • David414
      By David414
      I don't have any prior knowledge or experience with this plow as I will be a first-time user. Need some help please.
      I brought this well used plow, which I believe is a Brinly PP-500 series as the exploded part view seems to match up with my plow.
      Completely disassembled the plow, removed all rust, primed, painted, (wheel horse red of course) and re-assembled with new fasteners.
      Having trouble with the coulter blade, as it doesn't seem to fit this plow? Please refer to the pictures below.
      It appears to mount only one way, but it seems too big for this plow.  Do I have the right size coulter blade?
      What am I am doing wrong? Also is the front yoke assembly mounted correctly?
      Thanks
    • DeltaNu1142
      By DeltaNu1142
      I bought a 5xi package yesterday including some attachments I'm not going to need:
      4' plow, model # 79355 - in great condition, very minor surface rust on crossmember and back side of blade. $250 48" mower deck with blower and bagger - in good condition, working when removed from tractor yesterday. Previous owner said it never clogged on him. Some surface rust on deck and one 2" hole near the center. $300.
      I'm open to offers and interested in trades! I'm looking for a 2-stage snow thrower, p/n 79366. Maybe tools, etc.
      Available for pickup--let me know if you have any questions. Thanks!
      Here's a photo of the deck that's included. It's got some rust holes, but functions perfectly. Most of the price here is wrapped up in the blower & bagger:
    • Bbo44
      By Bbo44
      SOLD SOLD 520xi with air cooled 20hp Kohler - tractor in great shape and solid. Everything works. Engine was removed a few years ago and cleaned of grass buildup. New head gaskets and PTO seal a few years ago. Engine showed a decent amount of wear but runs strong and fires right up. Didn’t like the wear and needed a zero turn for my property. Would not hesitate to mow with it right now. 1200 hours. Have original paperwork. New air filter, fuel filter, fresh oil & filter. It’s been mowing 3+ acres for 20 years.
      52” side discharge deck complete. Currently mounted on the 520xi- solid, welded/patched cracks and holes. Front roller broken and patched, newer belt. Was just removed and cleaned. Welded chips in blades, but never finished sharpening. Solid deck, decent life left.
      48” wheel horse complete plow for 520xi 79355. Was used for snow. In great shape.
      48” wheel horse plow incomplete for 300 series garden tractor. Was used for parts. Not sure what it is missing but what’s there is very solid.
      MUST TAKE ALL. WILL NOT SEPERATE. Won’t answer if you ask. $750 CASH for everything. Only thing I’d consider selling separate is the 48” incomplete plow for 300 series. Will not deliver.
    • RJcollector
      By RJcollector
      Ive been thinking about selling my 4 RJ-58s and all the attachments and parts I have. I have 4 tractors-2 have Kohler K91T , 1 has the Clinton and one has no engine. Only 1 is missing the serial number decal. Kohlers run. Clinton needs a carb. I have original exhaust shields AND belt guards for 3 of them. 3 mower decks, 2 plows, cart, 2 spare transmissions, parts breakdowns, original manuals and sale tags, seats, tires.  Not sure if I should sell it as 1 big collection or break it up. And also a good starting price?  I'll post pics when I get a chance. Thanks
    • Donavon
      By Donavon
      Need ideas to convert my 1054 A Frame plow into a snow blower
      Any idea's?
