12 hp Kohler
Wheel horse c81
12 hp Kohler
Hi, I have a wheel horse c81 1978 and I was woundeding if any one could give ma an idea on the value, and yes it runs and it's an 8 speed 6 forward 2 reverse
  • Heart 1
PSully
With no attachments, and needing paint etc., I'm thinking $300 tops.
WHX??
7 minutes ago, PSully said:
and needing paint
That tractor needs paint?? No way that's choice patina!
Still no attachments 3-350 but it really does depend on location, eastern US :handgestures-thumbdown:, far southern and western states might be a tad more :thumbs2:
BTW :WRS: 12 hp
Ed Kennell
:text-welcomeconfetti: from another York Countian.
Sorry, I have to agree with  Sully and Jim,    $300 would be a sellers price.    $200-250 for a buyer.
The K-181s are great little engines and coupled to the 8 speed, they are unstoppable.
Although, I am not a fan of the rocker plate engine mounts  and the under the seat fuel tanks.
Not much can be learned from one picture, but there are some visible issues... grill damage, electrical wiring, battery clamp,  tie rod?
Rob R
My 2 cents on this is not the difference between 2 or 3 hundred $ what IS the price differential is the working condition and operation of the following: Engine, Starter, Transmission, Charging circuit, Tires and Battery..... give me the status of those 6 items and the value will appear as if out of the heavens........
P.s. the C-81 is a fantastic machine and you will love it once you get the six above items where they need be.......
12 hp Kohler
thanks for the info, i still want to fix the grill but I will never rempaint it because I love the putina. I am also looking for a mower deck because I know that would lift the value a little and it would be nice to start mowing with it, I am just waiting for the right price on one.
  • Similar Content
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • davidfindlay
      By davidfindlay
      Looking to find a new home for my 84 (I think) C-145. It has a dump trailer with the enclosure for leaves, the PTO impeller to get the leafs into the trailer, the hoses for deck-to-impeller, impeller-to-trailer.
      I haven’t run it in over a year.
      The battery and the cable to the battery probably need to be replaced.
      Comes with a new head gasket still in the bag.
      Seat is cracked but still comfortable.
      Happy to answer questions or take other pictures.
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
