carlosking450 162 #1 Posted February 20, 2017 Good afternoon my name is Carlos and I write from Spain, I have been asking some doubts and it is time to go putting the restoration. 9 Share this post Link to post Share on other sites
953 nut 68,688 #3 Posted February 20, 2017 Please ask any questions as you begin the restoration. You should take lots of pictures of the as you begin the disassembly process, as you begin putting it back together you can look at them to see what parts fit where. 7 Share this post Link to post Share on other sites
carlosking450 162 #4 Posted February 20, 2017 The condition of the 702 is good in general, the engine works but I have to check the carburetor, seals and paint. When I dismounted I saw that the frame was cracked and I decided to buy one used in the USA. The cylinder head gasket must be replaced with leaks. After cleaning the engine, remove the petrol pump and notice that it lacks the pin that drives the pump, you will have to replace it. 1 Share this post Link to post Share on other sites
C-121uk 183 #5 Posted February 20, 2017 Nice, good to see some WH made their way out to Spain, I wish more of the round hoods made their way to the UK Share this post Link to post Share on other sites
carlosking450 162 #6 Posted February 20, 2017 It is a slow restoration since I do not have the tractor in my place of residence The petrol pump is broken, right? You must have a lever for your actuation, right? 8 2 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #7 Posted February 20, 2017 I like your helper. He looks like he knows which tool to use on your tractor. 3 Share this post Link to post Share on other sites
WHX?? 57,866 #8 Posted February 20, 2017 44 minutes ago, carlosking450 said: You must have a lever for your actuation, right? You are correct sir, you should take the base pan off to look for it. in case it fell into it. 1 Share this post Link to post Share on other sites
ACman 7,741 #9 Posted February 20, 2017 (edited) No rod on those pumps , they're a vacuum pump . Check out @buffaloman thread http:// Home Wheel Horse Engines 1962 702 fuel pump diagram ?? @rmaynard has some really good photos of his pump . Sorry can't figure out how to make the link work . Edited February 20, 2017 by ACman 5 Share this post Link to post Share on other sites
953 nut 68,688 #10 Posted February 20, 2017 3 hours ago, carlosking450 said: The petrol pump is broken, right? You must have a lever for your actuation, right? Several of the early Kohler 6 and 7 HP engines used a vacuum operated fuel pump, the up and down movement of the piston creates alternating pressure and vacuum which pulses the pump diaphragm. This type of pump must have a good gasket where it bolts to the block to work. If there is no hole in the sides pf the pump that would serve as a pivot point for the arm then you have the vacuum pump and all is well. 4 Share this post Link to post Share on other sites
prondzy 3,890 #11 Posted February 21, 2017 4 hours ago, WHX9 said: You are correct sir, you should take the base pan off to look for it. in case it fell into it. No jim, on a 702 its a vacuum operated pulse pump. You can get a new diaphragm from buckrancher. Later years ran a lever to the camshaft that you are thinking of. 4 Share this post Link to post Share on other sites
953 nut 68,688 #12 Posted February 21, 2017 Your fuel pump has two check valves (one in and one out) and a diaphragm, no real moving parts. The valve body will should look like the one on the left in the photo. If you remove the screw and remove the valves one at a time and invert (turn over) the rubber washers under the valve then reassemble it you will give it a new lease on life. If your diaphragm is good you can reuse it, if not send a personal message to @buckrancher, he is a member here and produces new ones. 3 Share this post Link to post Share on other sites
ACman 7,741 #13 Posted February 21, 2017 Bob I hope you don't mind but these are some really good detailed photos of this pump. I tried making a link to your post but couldn't figure it out . @rmaynard I'll hide post if you disapprove or have mods remove it . Don't want to break no rules. rmaynard The Brake Lining Guy Joined: November 25, 2009 Supporter 5,802 9,769 posts Member No:2221 Military Member: Coast_Guard Location: New Windsor, Maryland ID: 3 Posted April 27, 2016 (edited) Raining here today, so I have plenty of downtime. Took some pictures for you. Here is the vacuum operated (pulse) pump assembled Notice the IN and OUT markings on the top With the screws removed, the pump splits open revealing the diaphragm. With the diaphragm removed, the one-way valve assembly is seen. One screw is removed and the valve cover is removed. Notice the INLET side (left) has a fine coil spring, and the OUTLET side (right) has a flat disc. There is also a gasket to seal the cover. On the left we see the INLET disc, and on the right we see the OUTLET spring. That is how it supposed to be assembled. I hope this helps. Edited April 27, 2016 by rmaynard 9 people like this 7 Share this post Link to post Share on other sites
rmaynard 17,547 #14 Posted February 21, 2017 No problem. 1 Share this post Link to post Share on other sites
carlosking450 162 #15 Posted February 21, 2017 Good evening first thanks to everyone for your help, I have two questions. -There are repair kits for sale? - Can a lever pump be mounted? Or does the camshaft not have the cam to drive the pump? Share this post Link to post Share on other sites
953 nut 68,688 #16 Posted February 21, 2017 36 minutes ago, carlosking450 said: Good evening first thanks to everyone for your help, I have two questions. -There are repair kits for sale? The diaphragm is probably the only part that would need replacement; send a PM to buckrancher on this site if you need one. - Can a lever pump be mounted? Or does the camshaft not have the cam to drive the pump? I doubt that your cam shaft will have a lobe on it to operate the mechanical pump. If you don't want to use the old pump you could use an electric pump; it will cost less than rebuilding the old one. Share this post Link to post Share on other sites
stevasaurus 23,808 #17 Posted February 21, 2017 Hi Carlos...your fuel pump is probably OK. @buckrancher sells the gasket that fits that pump if you need it. You do not need a kit, usually a little Carburetor cleaner will free up the little balls in there if they are stuck. Also, you do not need to, nor do you want to get a pump that has a lever. Your pump is just fine. 1 Share this post Link to post Share on other sites
carlosking450 162 #18 Posted February 22, 2017 Good night again, thanks for your answers, I will clean the pump outside and when the mountain will review its operation, a greeting! 2 Share this post Link to post Share on other sites
carlosking450 162 #19 Posted March 4, 2017 Good evening, colleagues, today I have been involved with the kholer, I have not been able to devote much time but good something has been done. I've taken the valves off their docks to clean them and make them seat. Another doubt I have is the exhaust I want to place one that the thread is female and the measurement of the exhaust outlet is more or less 32mm, can someone tell me what step or American measurement should I buy for that tailpipe measurement? I have another doubt and it is that I have observed that the lever of the governor when moving it manually stays in the position that leaves it is correct this or must return to some position by the force of some spring? Thanks¡¡¡¡¡¡¡ 1 Share this post Link to post Share on other sites
carlosking450 162 #20 Posted April 2, 2017 Good evening this weekend I followed with the renovation of my 702 wheel horse I could not do much but good. I have cleaned the cylinder head and it is in perfect condition and has already been rectified because it has engraved 0.10. The valves are definitely going to change because they are very chopped their seat. 2 Share this post Link to post Share on other sites
carlosking450 162 #21 Posted April 2, 2017 I have a doubt about the lever of the governor when moving it with the hand stays in the position that leaves, and I do not know if this is correct or if it should return to its position by the action of the spring that carries in the lever 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,477 #22 Posted April 6, 2017 1 inch National Pipe has an OD of 1.315" or 33.4mm. The wall thickness determines the Schedule number for the pipe with Schedule 40 being the most common having an inside diameter of 1.049" or 26.6mm. The thread diameter is smaller at the end of the pipe than where the threads stop. Commonly called a tapered National pipe thread. (NPT) Usually an electrical conduit nut is threaded on the pipe first. Install the pipe so it almost tight in the hole. Then back it out 1/4 of a turn and using a hammer and punch tap the conduit nut tight to lock the threads. A never-seize product added to the threads will help stop rusting of the threads so it is easier to remove next time. Garry 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,477 #23 Posted April 6, 2017 The throttle cable needs to turn the disc with the holes in it when the speed is increased. That adds tension to the spring. The other end of the spring is connected to the governor arm. Governors try to slow the engine down. The higher the rpm the more pressure the governor develops. The throttle cable tries to increase engine rpm by increasing the pressure on the spring. Those 2 pressures will be equal and give you the rpm selected. Good manual on the governors Garry Share this post Link to post Share on other sites
carlosking450 162 #24 Posted June 5, 2017 Hi friends, we continue with the restoration of my wheel horse 702, the engine has changed the two valves and a new plane has been made at the cylinder head. The cylinder head gasket has also been changed. I've also fitted a new carburetor. I had to clean the gas pump and set up the same gasket again. Someone can tell me the type of thread and measurement of the pump inlet and outlet of the pump? The connections that I have are in poor condition The engine has been started and works very well, and only need to disassemble again and paint 2 Share this post Link to post Share on other sites
carlosking450 162 #25 Posted June 5, 2017 On 2017-2-21 at 5:34 AM, ACman said: Bob espero que no te importe, pero estos son algunos muy buenas fotos detalladas de esta bomba. He intentado hacer un enlace a su puesto, pero no podía entenderlo. @rmaynard Voy a esconder post si usted no aprueba o tienen mods quitarlo. No quiero romper ninguna regla. rmaynard El individuo guarnición de freno Usuario: 25 de de noviembre de, 2009 Seguidor 5802 9.769 mensajes Miembro Nº: 2221 Miembro Militar: Coast_Guard Localización: New Windsor, Maryland ID: 3 Publicado 27 de abril de, el año 2016 (editado) Lloviendo aquí hoy, así que tengo un montón de tiempo de inactividad. Tomó algunas fotos para usted. Aquí se hace funcionar el vacío (pulso) de la bomba montado Note las marcas IN y OUT en la parte superior Con los tornillos quitados, las divisiones Decolte abierto revelando el diafragma. Con el diafragma elimina, se ve el conjunto de válvula de una sola vía. Un tornillo se retira y se retira la cubierta de la válvula. Observe el lado de entrada (izquierda) tiene un muelle helicoidal bien, y el lado de salida (derecha) tiene un disco plano. Ahi esta también una junta para sellar la tapa. A la izquierda vemos el disco de admisión, ya la derecha vemos el muelle de salida. Así es como se supone que debe ser ensamblado. Espero que esto ayude. Editado 27 de de abril de, 2016 rmaynard 9 personas les gusta esto Hello friend this weekend, I repaired the suction gas pump, I have checked the diaphragm, I have cleaned the valves, I have stretched the springs to give them more force, but I have not put the gasket on the valves because they do not Was it very important I have to disassemble the pump again to paint the engine, open it and put the gasket to the top of the springs! 2 Share this post Link to post Share on other sites
