		95' 312-8 Forward Swept Front End Upgrade thread! [Photos]
					By
Duramax7man7,   in Restorations, Modifications, & Customizations
Similar Content-
			 By SethL1984 By SethL1984
 312-8 - Runs, new carb, ignition doesn't work. Was bought for parts, ended up being mower. Rear Attach-a-matic bracket
 417-8 - Runs well, electric lift, ignition may need cleaned (or started solenoid going). Rear Attach-a-matic bracket
 (1) 42" RD with mule drive. Cuts well!
 (1) 48" SD with mule drive.
 (1) 37" SD.
 (1) 48" snow plow. 5 way blade position I believe.
 Several other parts/WH odds/ends. One tractor does include the weights and chains.
 Parents are moving and, unfortunately, need to thin the herd!
			 By MainelyWheelhorse By MainelyWheelhorse
 Hi All, the gas cylinder that assists my clutch in my 92 is spent. I’ve heard of people replacing the cylinder with a spring. I searched here and didn’t find a direct answer. What size, and number at a hardware store etc… is it? Thanks!
			 By sjoemie himself By sjoemie himself
 Besides working in my workshop I sometimes have, or want, to make improvements to it and I figured in this topic I would take you along for the ride.
 First off today was installing a new door and doorframe. The old one was rotted and starting to fall to pieces, literally.
 My dad made a sweet doorframe out of stainless steel and I repurposed a hardwood door that came out of our home when we renovated the place. Still needs paint but should be good for a few decades I'd say.
 Old door with flaky paint and rotten underside.
 New stainless steel doorframe and repurposed hardwood door.
 Next up was lighting. Few years ago I got some freebie fluorescent lamps but they were old and dying one by one. Having to replace the tubes and/or starters regurarly got kinda lame.
 Since Black Friday is now also a thing around here I snatched a good deal one some LED units which can be daisy chained up to 20 units.
 I ordered six of these lamps for about $80,-
 As a test I installed one.. can you spot it?
 What can I say? Bright as day!
 Greetings from the Netherlands, Mark
			 By Tinman1962 By Tinman1962
 Could someone point me into the right direction for the removal and replacement of the tension pulley on my 1054a thank you
			 By 1990520H By 1990520H
 What is a good replacement rim for the fronts since you can no longer get the stuff from Toro. Been looking. Not much luck. Any help would be greatly appreciated.
