Dan693
Tecumseh ID Help
Dan693
Hey,
Picked up 2 Lawn Rangers....106 and 157. The 106 came with the black engine which I know isn't correct and the 157 came with red engine.
Anyone know how to ID these. Factory stickers but no mdl or s/n........maybe a block stamping????
Pics attached......
Thx
Edited by Dan693
pfrederi
l157 should be H60-75117F  Not sure about he two threaded holes above the recoil
Should be a data plate on the front of the shroud
picture is from the original engine on my L107 Decal painted over
Black one is newer as there is no Lawson Power products on the decal.  I would guess late 80s???
Edited by pfrederi
Dan693
Thanks!
There are 4 other holes around the recoil just like the 2 above. They appear to be factory but who knows.......
Terry M
The two holes above the recoil usually are the front gas tank mounting holes from a Troy-Built Tiller  which used an HH60 cast iron block tecumseh (for the 6hp version)..   I have disassembled  many of them.   Just FYI...due to the angle that these engines are mounted to the tiller, the oil dip stick were marked slightly higher due to those engines (on the tillers) ran with a slightly different oil level.
Dan693
Thanks for the Troy-Bilt info.....I'm sure that's it. The red engine has a 7 H.P. sticker on it so could it still be an HH-60?
Terry M
Yes , it  could be a 7 HP....but I know 6 HP  was very commonly used.   Did you find the any model # on the shroud.    Usually a plate was riveted on the shroud like Pfrederi showed.   sometimes a decal was used (which could be gone or painted over)....and I've seen on some with the engine model stamped on the top of the flywheel shroud , next to the cylinder head.
pfrederi
If the block is cast iron it is an HH series (non magnetic non rusty = H series)
Bore for a 60 series is 2.625
Bore for a 70                2.75
Edited by pfrederi
  • Similar Content
    • Matt_8
      By Matt_8
      I was wondering if anyone knew what wheel weights i would use for my lawn ranger on stock wheels three lug pattern
    • Matt_8
      By Matt_8
      I just bought a 1967 WH lawn ranger and i was wondering the best place to find a rear fender pan
    • D_Mac
      By D_Mac
      So.... I just got home with this. I been wanting to fix one up for my 9 yr old nephew. I need to do it in a hurry as I will be going in hospitol soon for my 3rd battle with cancer. You know the story. Was told it ran about a month or so ago. Not running now. I just got home with it so I haven't checked it out yet. Have never owned a Lawn Ranger before, and know nothing about them. Maybe you guys can tell me what I have here and any advice would be helpful as well. Seems to be complete with the exception of the seat. Going to need to pick one up somewhere.
    • CeeBee
      By CeeBee
      Good shape. Electric Start. Kept in a shed. Need the space now. Includes Manual. Pickup only.
    • jp_vikings
      By jp_vikings
      I have what I believe is a 1964 Lawn Ranger.
      I'm wondering how rare they are and wondering what it is worth in the original condition it is in now.
      May possibly restore it when I catch up on all my other projects.
      Thank you!
