Team70R
Wheel horse single bottom plow
Team70R
Going to pick this thing up Monday! Is $150 a decent price??
JAinVA
Edited by JAinVA
Team70R
55 minutes ago, JAinVA said:
I figured the price would go up come spring!!
JimmyJam
Decent plow at a decent price. Jump on it!
Team70R
Just finished finish my Clevis hitch adapter!! Just need spring to come!
JimmyJam
Can you show us the clevis hitch adapter you made? Pics?? Please!
Team70R
I know I'll have to modify it once I get the plow home but it's a good start! Planning on making a gusset for it.. No measuring as usual!! Just let the sparks fly!
  • Like 7
squonk
Rule of thumb: Measure it with a Ruler.  Mark it with chalk. Cut it with a Torch! :banana-linedance:
Check your under ware for small brush fires after your done! :)
Edited by squonk
  • Like 5
JimmyJam
Squonk (Mike): I am guessing you know first hand experience with torch fires! LOL!   :scared-ghostface:
T-Mo
I wouldn't pay more than $150 and I've seen those type plows go for $125 in good shape.
wrmhaste
I picked up one of these over the summer.  However mine is white and brown.  Brinley brand.  Is yours a wheel horse brand?  Mine appears to have a bigger disc.  I paid $25
Team70R
Wow that's awesome! Mine is a wheel horse brand. Looks to be barn kept!
wrmhaste
Yours does look longer than mine.  Mine was barn kept too. Still has all the stickers on it.  Looks like it maybe hit dirt once.  I wasn't sure if it was like most other attachments where other companies made them as well as wheel horse.  For example I never knew wheel horse made a lawn sweeper till I bought one at a garage sale last summer.
stevasaurus
I'm with T-Mo on the price...no more then $150.  :)
Team70R
Got it home!! Already plowed the garden!! A little muddy but I had to test it out!
Team70R
wrmhaste
Very nice! I can't wait to test mine.  Unfortunately it will have to wait till spring when there isn't 2 feet of snow.  How did the clevis do?  Need any modifications?
Team70R
Luckily it's somewhat warm here!! Had to grind the nuts down and bit but other than that it held up!! Still need to add some gussets though. The main bar was flexing  :blink:
wrmhaste
I'd say that's a success. I need to build one for mine.  I don't plant a garden but it will be useful for several other things. Is yours utilizing the rock shaft cable lift?  I see you have it hooked to what looks like an 8hp tractor.
Team70R
It's gonna come in handy! Yes I'm using the rock shaft cable lift! It's actually a 7 horse Honda with a gear reduction! Not fast at all but I can plow in 3rd gear at an idle
  • Similar Content
    • DeltaNu1142
      By DeltaNu1142
      I bought a 5xi package yesterday including some attachments I'm not going to need:
      4' plow, model # 79355 - in great condition, very minor surface rust on crossmember and back side of blade. $250 48" mower deck with blower and bagger - in good condition, working when removed from tractor yesterday. Previous owner said it never clogged on him. Some surface rust on deck and one 2" hole near the center. $300.
      I'm open to offers and interested in trades! I'm looking for a 2-stage snow thrower, p/n 79366. Maybe tools, etc.
      Available for pickup--let me know if you have any questions. Thanks!
      Here's a photo of the deck that's included. It's got some rust holes, but functions perfectly. Most of the price here is wrapped up in the blower & bagger:
    • Bbo44
      By Bbo44
      SOLD SOLD 520xi with air cooled 20hp Kohler - tractor in great shape and solid. Everything works. Engine was removed a few years ago and cleaned of grass buildup. New head gaskets and PTO seal a few years ago. Engine showed a decent amount of wear but runs strong and fires right up. Didn’t like the wear and needed a zero turn for my property. Would not hesitate to mow with it right now. 1200 hours. Have original paperwork. New air filter, fuel filter, fresh oil & filter. It’s been mowing 3+ acres for 20 years.
      52” side discharge deck complete. Currently mounted on the 520xi- solid, welded/patched cracks and holes. Front roller broken and patched, newer belt. Was just removed and cleaned. Welded chips in blades, but never finished sharpening. Solid deck, decent life left.
      48” wheel horse complete plow for 520xi 79355. Was used for snow. In great shape.
      48” wheel horse plow incomplete for 300 series garden tractor. Was used for parts. Not sure what it is missing but what’s there is very solid.
      MUST TAKE ALL. WILL NOT SEPERATE. Won’t answer if you ask. $750 CASH for everything. Only thing I’d consider selling separate is the 48” incomplete plow for 300 series. Will not deliver.
    • Donavon
      By Donavon
      Need ideas to convert my 1054 A Frame plow into a snow blower
      Any idea's?
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
    • Nuzmuz
      By Nuzmuz
      Just wanted to show a modification I did to my 1990 310-8. I recently picked up a 36” tiller for my horse and I tried it out on my new garden area. After hitting a rock, it knocked one of the axle brackets open dropping the right side of the tiller. On a manual I viewed, it had clevis pins to hold the lever in, but my bracket did not have them. I drilled a 1/4” hole through on each lever and mounted a 1/4” clevis pin and hairpin cotter to reinforce the lever. I read on another post to just tighten the bolts on the levers, but I think this will work a little better. Hope this helps someone!
