Duramax7man7 506 #1 Posted January 13, 2017 Are There different lengths of down pressure bars for the plow/dozer blade? Share this post Link to post Share on other sites
stevasaurus 23,440 #2 Posted January 16, 2017 Yes...at least 2 different lengths...maybe 3. Share this post Link to post Share on other sites
elcamino/wheelhorse 9,362 #3 Posted January 17, 2017 I know there are 2 lengths short link 5 1/2" x 1 1/4 x 1/4 inch thick. 3/8 " diameter pins on 4 inch centers. long link 12 1/2 x 1 1/4 x 1/4inch thick 3/8 " diameter pins pn 11 1/2 " centers. I wonder if there is a 3rd length , I made the long link to above specs and it still does not lift the blade high enough. I have checked the attachment points 2 or 3 times to insure that I have the blade mounted correctly. The blade is mounted on a 416-8. 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #4 Posted January 17, 2017 Short link for float on the mower lift arm, long link for down pressure on rockshaft, then there's the mid grader blade links of different lengths, the the xi series has a floating and down pressure link that's different also,Jeff. 4 Share this post Link to post Share on other sites
Duramax7man7 506 #5 Posted January 17, 2017 Awesome! That's good enough for me. Thank you! 1 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,362 #6 Posted January 17, 2017 @WVHillbilly520HI have a question the long link goes in the hole for the mower trunnion ? It would seem to me that it would goes in the 3 rd hole ( the one closest the end)for maximum blade lift. Share this post Link to post Share on other sites
Duramax7man7 506 #7 Posted January 17, 2017 Yes. That is what it says. "For maximum blade lift height move the trunnion to end hole". It shows an arrow that points From the 1st hole To the 3rd hole. Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #8 Posted January 17, 2017 @elcamino/wheelhorse, just going by an older post as I use the floating link myself, but I my blade only raises 3-4" max before hitting the steering linkage that's the downside of this style blade mounting vs other brands, Jeff. Share this post Link to post Share on other sites
elcamino/wheelhorse 9,362 #9 Posted January 17, 2017 @WVHillbilly520HMine has go me puzzled it does not seem to be hitting anything , but only gets about 2 1/2" off the ground. I guess I need to take another wack at it to see if I can get it up higher. Tired of laying on wet cold ground checking things out. Share this post Link to post Share on other sites
Duramax7man7 506 #10 Posted January 27, 2017 Why does the oval hole have to be used for the down pressure bar??? Share this post Link to post Share on other sites
Sarge 3,470 #11 Posted January 28, 2017 Oval hole is intended to give the blade a bit of float and limit down pressure - helps avoid damaging parts . Just remember , any time you are forcing the blade to the ground be prepared for it to grab something , hard...I've seen people launched over the hood when being too aggressive and using too much speed . The trip springs will help , but the faster you go the less chance they can work to prevent a damaging sudden stop when hitting something solid , like concrete and such.. Sarge 3 Share this post Link to post Share on other sites
Duramax7man7 506 #12 Posted January 28, 2017 Gotcha. Okay thsnks for the reply. Looks like I better amke thst hole then on my extension kit. Share this post Link to post Share on other sites
Duramax7man7 506 #13 Posted March 8, 2017 (edited) I went ahead and made myself one of these... Couldn't find any 1/4" x 1.25". So I used 1/4" x 1.5" Put my plow on my 520h today. Will be giving this a test run tomorrow with the hydraulics. Edited March 8, 2017 by Mastiffman 2 Share this post Link to post Share on other sites
Duramax7man7 506 #14 Posted March 8, 2017 (edited) Installed the bar this morning. Found the lift assembly has a broken weld at the support pivot bar to the lift arm.. SMH... I'm sure I'll find more broken welds on this 2300hr beast. Here is the result. There's a 25# weight up front. I thought there wasn't anything. Edited March 8, 2017 by Mastiffman 5 Share this post Link to post Share on other sites
DTOM 124 #15 Posted March 12, 2017 Does anyone have an original " down pressure bracket" for the C-195? Looking to fab one up if i can find the measurements. Share this post Link to post Share on other sites
DTOM 124 #16 Posted March 14, 2017 Figured it out. Its the same part as a "D" series, just mounted upside down. Ready for some serious plowing tonight. 1 Share this post Link to post Share on other sites
Duramax7man7 506 #17 Posted March 14, 2017 Glad to hear. I might suggest keeping your plow angle as vertical as possible as this will help get a much down pressure as possible. I used mine on my 520h a bit last night to clear the drive way and neighbors driveway and I still had my plows vertical angle set to the high hole which keeps the top of the plow further back than the front. I wasn't able to put as much pressure to scrap the ice up as I wanted in forward motion. BUT, in reverse, pulling the snow, I noticed a big difference in comparison to no DPB... Share this post Link to post Share on other sites
