Thegearhead0324 1,824 #26 Posted January 18, 2017 Not sure if it helps ya or not, but when my Dad got the wheelhorse I inherited back in 09, the guy he got it from had a 51 series battery in it along with top post terminals. Guess he got sick of the tiny lawn mower batteries moving around in the tray. I put a new battery in it last year, same size (51 group). It fits in pretty decent. I made my own plate recently that bolts on the side which squeezes the battery in place perfectly. 1 Share this post Link to post Share on other sites
Solze1267 202 #27 Posted January 18, 2017 Huge thank you to 953nut for helping out with the drive belt cover. Thank you for being a part of my build! 3 Share this post Link to post Share on other sites
Solze1267 202 #28 Posted January 26, 2017 UPDATE got my decal kit from redoyourhorse.com in today and cant believe the quality and detail these decals have. Very very impressed with them. Now i need to buckle down and get the frame painted. 4 Share this post Link to post Share on other sites
Solze1267 202 #29 Posted January 26, 2017 UPDATE recieved my parts from a-ztractor today. Thanks again for the amazing service 3 Share this post Link to post Share on other sites
Solze1267 202 #30 Posted January 27, 2017 Finally had a free minute to get rhw transmission cleaned up and primed in Eastwood Red Rust Encapsulator. On to the rest of the frame then a few healthy coats of red. Come on Spring! 2 Share this post Link to post Share on other sites
Solze1267 202 #31 Posted January 30, 2017 UPDATE TIME...have the frame minus the front arm primed and painted as well as the rear body section primed ready for paint. Next step is to go to our semi local surplus store and see if i cant find the tires i want for it 2 Share this post Link to post Share on other sites
squonk 48,056 #32 Posted January 30, 2017 (edited) Although not the correct size, for summer cruising I like 6 X 12 Ag's on the back and 4.00 X 8 tri rib on my 1267. Edited January 31, 2017 by squonk 1 Share this post Link to post Share on other sites
Solze1267 202 #33 Posted January 30, 2017 Im gonna run ag tires on the back and a smoother rib tire up front. What brand are you running Share this post Link to post Share on other sites
squonk 48,056 #34 Posted January 31, 2017 I've got Carlisle ag's and Deestone tri ribs Share this post Link to post Share on other sites
Solze1267 202 #35 Posted February 4, 2017 Glad to be starting the assembly phase. Next purchase is new tires and it will be back rolling on its own. 2 Share this post Link to post Share on other sites
Solze1267 202 #36 Posted April 7, 2017 Due to work being hectic i wasnt able to post progress in a while but here is where it sits as of today. Got new tires mounted on the front, the kohler bolted back in, and started re assembly on the pt6 and other parts 2 Share this post Link to post Share on other sites
Solze1267 202 #37 Posted April 27, 2017 Update time again..got the rear tires on and decided to push it outback for some pics. Gonna spend saturday getting some more painted and making a few touchups i seen i missed. 4 Share this post Link to post Share on other sites
Solze1267 202 #38 Posted April 29, 2017 Took advantage of the rainy day and got some primer and paint on the seat pan and belt gaurd. Again a big thank you to @953 nut for the belt gaurd. Got anxious and when they got tacky enough they didnt leave fingerprints i put them on. 5 Share this post Link to post Share on other sites
953 nut 69,100 #39 Posted April 29, 2017 2 minutes ago, Solze1267 said: thank you to @953 nut for the belt gaurd. You are very welcome, it looks a lot better on your than it did hanging on the wall of my barn. 2 Share this post Link to post Share on other sites
Solze1267 202 #40 Posted May 7, 2017 Finally got my home built drag bar built, painted, and installed. It is set to push or pull both straight or at 45 degrees left or right. Made it from scrap metal laying around the shop. 3 Share this post Link to post Share on other sites
Solze1267 202 #41 Posted May 29, 2017 Had a great work day on the 1267. Got the battery box made and the rough idle fixed. Also got the hood painted and installed. Its not perfect but then again i didnt build it to look pretty, i built it to work. All i have left is the headlights and decals for the hood then its on to the mower deck 4 Share this post Link to post Share on other sites
Kavint76 57 #42 Posted May 30, 2017 Looks awesome i wish my 1277 looked like that but i like the patina on it to. It shows how hard she worked all her life. Share this post Link to post Share on other sites
