Team70R
Bigger drive pulley.. now it's slower?!?
cschannuth
35 minutes ago, Team70R said:
I did the same with my predator swapped 606!! Love it!!
It is a lot of fun. I was worried about it robbing too much power but that thing is really good at low RPMs out of the hole too. To start out in high gear I have to throttle it down to almost idle or it will pop a massive wheelie.
Sorry. I didn't mean to hijack this thread.
Edited by cschannuth
Apology
daveoman1966
I wanna play too....   This is from somewhere...don't know
Clik it, then change pulley diameters and watct...
http://www.blocklayer.com/pulley-belteng.aspx
953 nut
13 hours ago, 953 nut said:
If you had a bike as  a kid you know the front sprocket was bigger to gear it DOWN   UP to the rear wheel so you could peddle it with ease; same deal here.
Seems like i didn't think very much prior to typing!   :text-imsorry:
  • Like 5
Team70R
I had to build a front weight bracket after I almost flipped it!!
Ed Kennell
We all been there and done that Richard.    Although I'm thinking you had a plan to start a really good discussion....and I worked.  :)
  • Like 6
953 nut
No, :text-blondmoment: !
  • Like 4
Team70R
Anyone know where to find a pulley with a metric keyway? The Honda shaft is a 1" diameter with a 7x7mm key!! :think: can only find 1/4" around here!
953 nut
NAPA should have them, with all the metric junk out there I'd be surprised if they didn't. Any dealer that sells and services Honda or other ATVs will have them.
Team70R
Well we determined the cause of the slow drive speed is from the gear reduction on the motor :unsure::think:  I never realized it had one.
Ed Kennell
So, if you know the real drive shaft RPM of the Honda, you can use daveoman's link to determine how large the drive pulley needs to be to achieve the same speed you had with the Techy.
Ed Kennell
On ‎1‎/‎9‎/‎2017 at 9:13 PM, Team70R said:
Ed,
 Looks like I'll be able to solve my problem easier than you will be able to solve your Elks problem haha. If I had any advice I'd certainly pass it on to you!
Thought this deserved an update...... Our ELKs lodge is now smoke free during Friday night dinner hours.  :happy-wavemulticolor:
SylvanLakeWH
Congrats on your victory!
953 nut
Congratulations;  :woohoo:  it should be all the time.
Image result for smoker coughing images
  • Similar Content
    • Fordiesel69
      By Fordiesel69
      I need the large metal pulley that houses the needle bearing and ball bearing with the two grooves.  The outer bearing seemingly wallowed out its hole and my welder guy cannot revive it.
      Shipping to Erie PA. 16509.
    • cJ_3D
      By cJ_3D
      Hey all!
      Replacing the drive belt on my 252-h. Anyone know the torque specification for the center screw when I put this pto clutch back on? I know it was on there tight it took a minute for the impact to break it loose. Thanks!
      CJ
    • razorback1995
      By razorback1995
      Hey all,
      This pully blew up on me yesterday. Having a hard time IDing the part # or replacements. the 308-8 schematics I've found don't list this part.  Its the pully in the front that runs from the motor to the mowing deck.
      Thanks in advance!
    • Bach-Ed
      By Bach-Ed
      I need a little part number help.   I'm looking for the part number of the idler pulley that tensions the drive belt on my 857.  The diagram shows the left side of the tractor.  And I can't seem to locate the pulley on the parts drawing.  The bearings have gone out on my tractor's idler.
    • Joe Warren
      By Joe Warren
      one NOS 106846 right drive pulley, mower deck, used on double D style shaft, replaces part 5877, $55 includes shipping within US lower 48
