nmassey02
Faster hydrostatic rear ends
nmassey02
Hey guys, what rear ends were the higher geared ones? We have one 520 that had a rear end replaced and it is a lot faster than the other. As far as I have been informed, 520hc's and 417's. Where there any others? How many teeth are there on the high speed gears versus the regular gears?
Thanks!
varosd
others will chime in but correct on the short lived 88-89 520 HC with the faster Eaton 1100 read end and of course the newer 520's
also the GT 1848 Workhorse had a bigger gear in the rear.
other models probably
JackC
The faster 520 likely has a 520HC tranny. I believe the 418C and some of the C's as well as the newer 5xi series are also some of the faster horses in the herd. Not sure why ground speed was reduced for some of the later pre 5xi tractors but safety and liability concerns may have been a factor. The sales brochures for various years provide the ground speed numbers.
shallowwatersailor
Jack is correct as Toro developed the "Smart Steer" for the 5xi. It was needed with four of the five 5xi models equipped with cruise control. Imagine a typical owner clipping along mowing at 7.5 mph and then cranking the wheel over to turn! A ROPS bar was optional. Toro offers a bypass kit (Smart Steer control is through an additional cam and linkage) as they are slooow in Reverse when in "Lo" and turning. But I have found with three 5xi that it actually allows some finesse when backing into the garage.
One thing I wonder: If the kit was installed by a dealer, did they then disable the cruise control to protect liability?
Edited by shallowwatersailor
Jerry77
I read somewhere that the 418A had a faster rear end.....does anyone know for a fact?  :)
nmassey02
That's for the replys guys! Would any one know the exact tooth count difference on the drive gear on the eaton as well as the difference in the number of teeth in the rear end?
cleat
This should help.
Rear end.pdf
Cleat
nmassey02
2 hours ago, cleat said:
This should help.
Rear end.pdf
Cleat
Awesome thanks!
lynnmor
I've not played with it, but is there anything to gain by changing the cam profile?  Perhaps it does move as far as possible with the stock profile.
nmassey02
Would you happen to have the parts list for the gear from the hydraulic pump? Thanks!!
Thats a good question, I'm not sure. My original thinking was to spin the pump fast, but at some point the relief valve will kick in and more rpms will not help any more.
cleat
Here is the hydro gear parts.
hydro.pdf
Here is the exploded view of the entire hydro unit.
hydro parts.pdf
Cleat
Edited by cleat
nmassey02
hydro.pdf
hydro parts.pdf
Cleat
Thanks! So the 520 pump gear has 20 teeth and the 520 hc has 22 teeth, this is the opposite of what I thought it would have been.
nmassey02
hydro.pdf
hydro parts.pdf
Cleat
Would the same part number pdf's be available for the 8 speed rear end in a c100-8 & a 310-8? I found the repair manuals on this website, but I could not find a indepth part number break down for those rear ends. Thanks!
  • Similar Content
    • cheesegrader
      By cheesegrader
      About a decade ago, I bought a conversion kit here to remove the column drive lever and convert to a foot pedal for a 520h.
      I would like to convert a second tractor, and I need to replace one of the linkage bars on the first one that has cracked, but I can't find the vendor any more.
      Does anyone remember who made this awesome mod, and where I can find them?
    • giant_g2
      By giant_g2
    • Doug B
      By Doug B
      Hey guys,I have a dilemma I need some help with. I have a 1969 GT 14 that I replaced the transmission and pump on. For about 2 weeks afterward everything worked great, but while mowing at a pretty good pace I noticed a shudder and the tractor slowed a little but not bad. The more I rode it the slower it got until it barely moves. What stumps me is the hydraulics are still very strong,as in I can back the 3 point under the bumper of my truck and if you lift the arms all the way up the front wheels of the tractor will clear the ground. Have checked the tow valve and checked the internal filter,but no luck. I have also checked and replaced the forward and reverse bypass springs and the lever is moving the cam to full travel, forward and reverse. Any help would be appreciated.
    • mattd860
      By mattd860
      I have developed a kit that allows a Wheel Horse / Toro hydrostatic tractor to be operated by a pedal on the right side of the tractor. The original forward/reverse lever can be retained or removed. The kit includes everything needed to install the pedal kit and installation is simple with the help of a downloadable installation manual. Additionally, only one (1) 1/4" hole will need to be drilled which can be done by a hand drill. No other drilling or cutting will be necessary. Any tractor with this kit can be converted back to stock without any visible evidence that kit was installed. However, you'll never want to do that
      The kit operates very simply and similar to modern tractors. When the pedal is pushed forwards the tractor will move forwards. When the reverse pedal is pressed downwards, the tractor will moved in reverse. If the operator takes his foot of the pedal at any time, the pedal will automatically center itself and the hydrostatic transmission will return to neutral (stop). This enables the operator to use both hands on the steering wheel or one hand on the wheel and the other operating an attachment like a snow blower, plow, etc.
      The foot pedal is custom cast in Aluminum, uses brass bushings to minimize wear, and it closely matches the OEM Wheel Horse BRAKE pedal commonly found on 8-speed manual transmission tractors. Modifications were done to the pedal to add the reverse pedal and adapt the pedal to the rest of the kit. For the most part, the pedal looks like it was designed and manufactured by Wheel Horse / Toro. Additionally, a grease fitting has been adapted to the pedal to further minimize wear and tear and if the brass bushings ever wear out they are fully replaceable without having to buy a whole new pedal.
      The pedal kit fits the following series tractors with Eaton hydrostatic transmissions: C-1X5, 300, 400, 500.
      My kit can be adapted to older hydrostatic tractors with the Sundstrand transmission, however, you will need to find an updated hydro cam commonly found on ebay. Message me for more information.
      Here is a link where you can download the installation manual: CLICK HERE
      I am selling these kits for $330 shipped to anywhere in the United States. I offer multi order discounts as well. I will also sell to other countries for additional shipping charges to be determined.
      If anyone has any questions please feel free to PM me or post your question here and I will be glad to help. Or you can email me at mattdarling02@hotmail.com.
      Thanks!
      Below are pictures of the complete kit and the pedal installed on the tractor. Some modifications have been made since these pictures were taken. For example, the reverse pedal is now cast in aluminum instead of the steel pedal shown below.
    • Dylan2342
      By Dylan2342
      New here! hello everyone! In a bit of a pickle here. My father owns a 1993 (I think that is the right year) 520H Wheel Horse. I don't commonly work on tractors but it seemed simple enough. the axle snapped on the left side, so it needed a new transmission. My dad bought a used transmission and I went to work changing everything out. The hydraulic pump that the engine's drive belt attaches to went to a different model/year of tractor, so I had to remove that part and swap it in from the old transmission. In the process I lost all of the oil in the pump (I mention this because I wonder if it has to do with my problem I'm having). When I reassembled everything I started the slow process of filling the transmission. I filled it up and started the engine. When moving the lever forward or backward, it had a tiny bit of power for a little bit and then lost power. The transmission wasn't doing anything, anymore. I though maybe that hydraulic pump needed to be primed, so we took the top hydraulic line off of the hydraulic pump right above the drive belt and used a transfer pump to pump some oil into the pump case. This still didn't work. I don't have enough experience with these hydrostatic transmissions to know if we got a bad transmission or if there is something obvious that I am missing when it comes to a transmission swap. I ask for any insight and help please. If you need pictures or any other info, then let me know what you need. Thank you!
