robert pelton
bob
robert pelton
im new at computers, not sure this is right place to ask questions. I HAVE 1978 C141 AUTOMATIC TRACTOR ONCE IN WHILE STASRTER LOCKS UP I PUT WRECH AND STURN  FLY WHEEL AND IST STASRTS FOR AWHILE THEN LOCKS UP. QUESTION CAN I DO PARTS REPLACEMENT ON EXISTING STARTER OR HAVE TO BUY A NEEW ONE?. IF I NEED TO BUY NEW ONE WHERE DO I GET IT? AND ABOUT HOW MUCH. LOOKS LIKE I CAN REMOVE STARTER WITHOUT TAKING COWL OFF. ANY HELP APPRECIATED FEEL FREE TO SEND ME INFO ON MY E MAIL CAUSE IM NOT USED TO THIS FORUM   BOB  RPELTON51140@ATT.NET
THANKS
953 nut
:WRS:  Could be the Bendix drive on the starter is in need of a little lubrication. Get some dry Graphite spray and give it a try.
Ed Kennell
You are doing fine on the computer Bob.   We like to solve any problems here on the forum so everyone can take advantage of the advice. We are all learning with every post.
:text-welcomeconfetti:to the :rs:
  • Like 4
oliver2-44
I chatted with you briefly but had to leave before we got very far.  As I mentioned it could be a worn front bushing, or as noted asbove could just need lubrication.  i recently had one sticking that I removed from the motor, cleaned the bendix and lubed with graphite. The spiral bendix shaft was very dirty.  I didn't even disassemble the started. Also if you think you need to disassemble it for a full cleaning, aybe someone on here can point you to a Kohler manual that has instructions for that.
Welcomw and Good Luck, you have a great tractor!
Edited by oliver2-44
  • Similar Content
    • 87 416-8 horse
      By 87 416-8 horse
      I’m looking for wheel horse tractors for sale or for parts in the Eastern Nebraska or western Iowa area. Preferably 8 speed manuals. Pm me or comment with what you have. The worst I could say is it’s out of my price or distance range. Edit: engine is not important, it’s going to get a big diesel swap.
      Thanks,
      John
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
      1984 C-105 8-Speed model 11-10K802
      1984 C-125 8-Speed model 11-12K802
      1984 C-145 Automatic model 11-14KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-165 8-Speed model 11-16K801
      1984 C-175 Twin Automatic model 11-17KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-195 Twin Automatic model 01-19KE02
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
      92DB561C-FF95-4868-A52B-5725D4D3B9DE.mp4
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
