Texas Todd
Here Goes the 856
jimkemp
Eastwood sells a kit for repairing steering wheels , I have used it in the past and it works great , look it up at eastwood.com , I love the red on the muffler
Racinbob
OK, I'll chime in :) Here's my Suburban steering wheel:
I used Dupli Color on the blue can:
The also make one in a black can that I really don't care for in this application. The same goes for the Rustoleum coating. I didn't have a lot of chips but as Jim mentioned, some bondo would be in order if you do. I just had to fill a couple small areas. So far it's held up well but I expected that from a truck bed coating. The feel is great. :)
  • Like 5
Racinbob
Here's another one that I just now took a picture of. I wouldn't have had to refurb this had it not been for a stupid move. The grip and feel of the coating is great.
This is closer to your style of wheel but I think it's off a B-100. :)
  • Like 6
Texas Todd
Wow. Those look great! Thanks, I will do some research on the bondo/eastwood suggestions.
Texas Todd
1 hour ago, RandyLittrell said:
PC7 is what I have read about in the past for fixing cracked wheels. Here is a link.
Thanks, I browsed several car restoration forums and it appears the POR15 and PC7 are both popular.  It sounds like any of the 2 part epoxy's would work pretty well.  I will give it a go and see what happens. Thanks!
Sarge
Just fyi - after you've fixed the cracks/pits and such - if you want the original shiny look to the wheel I've used Eastwood's Diamond clear in several coats - with awesome results and the stuff seems to hold up really well .
Sarge
Texas Todd
Okay, thank you sir!
Texas Todd
Today I decided to attempt attaching the snow plow.  I have two plows and they are both for the long frames. I was figuring I would cut another 3/4" bar to put in the forward holes but when I put the plow frame under the tractor it wouldn't work. The hitch I have is the 2" receiver hitch with the plow brackets. The angle would prevent the bar from going up far enough to connect.
Then I had the wild idea to cut a slot in the frame that would allow the angle iron to go deep enough. If I ever needed to use it on a long frame, I could just weld up the slot. As I was digging through the scrap pile trying to find a suitable piece of rod, I happened on an old electric garage door lift mechanism. The light bulb came on.
If this will left a garage door, it should be stout enough to lift the plow. The forward arc of the arm just may give me enough reach to get to the lift attachment on the plow.
This is in the up position:
and in the down position:
It lifts the plow fine:
It sticks out in front, but I don't suppose that will make any difference.
Everything is complete with the exception of the trip lever to angle the plow left and right. I found one on ebay, but they want $34 for the little jewel. I am going to try to fab something up. If anyone has one laying around gathering dust, let me know.
Texas Todd
That was a lot easier than I thought. Back to the scrap pile. Dog bone from an 04 Suzuki that I no longer have...Not the prettiest thing I have ever seen, but its functional! I thought it was a 42" plow but its a 48. I guess we will see what this little 8 horse can push!
Edited by Texas Todd
Texas Todd
Well, a pause to this story. Fired er up Saturday to push some stuff around and she ran great, but smoked like a mosquito fogger. Was hoping that I had the crank vent in backwards but I didn't. After giving it plenty of time to burn off what was left from the build, I jerked the engine and pulled the head and actually measured the cylinder this time (should have done to begin with). Well its out of spec for sure, so off to get bored out....No happy ending to this story, for a while anyway....
WHX??
Ouch... :(... minor setback! :)
Texas Todd
Alright. Engine bored .010 over and reinstalled. @stevasaurus came through once again with some help and pictures. It's amazing how many pictures you take, you don't seem to have the one you need.
She fired right up and purrs like a kitten. Very pleased with the outcome. Considered swapping the drive pulley for the PTO pulley, but didn't have a belt that would work.  Not sure what a half inch would have got me anyway. Had to cant the pipe forward a bit. The lever to pivot the snow blade needs a tad bit more room. Hoping that will do it. The high heat red caliper paint didn't hold up at all, so repainted with the white high heat paint. Didn't refinish the steering wheel as I couldn't get the blasted thing off!!! May have to drape everything and try doing the best I can with it on.....
Very pleased. Now onto the next one!!! Already have a project in the works for my D-180..............
  • Like 6
DennisThornton
I like it!
What size rears?
Texas Todd
Dennis:
Got em from simpletire. 45 a piece. A little challenging to get on the stock rim but they are fatties!!
They are
Deestone D405 23/10.50-12 6ply
JC 1965
Congrats, tractor really looks great.    :thumbs2:
Elkskin's mower junkyard
zthats actually a shocker. the engine was painted gray. many people dont know this but if you buy a wheel horse or another brand of tractor and its got a old kohler K series thats painted gray. its a replacement engine. Kohler sold replacements that was just primed. The owner was supposed to paint them to match
Texas Todd
I sure didnt know that. Interesting!!
kudzu3
Beautiful work.
Aldon
Very nice!
oliver2-44
Looks Great!  You sure keep your projects moving along
Texas Todd
Thanks! I'm afraid if I let em sit too long I will forget where things go and where I put them....I struggle enough with that as it is!!!
you did good on the plow but this is what you should of done with the long frame plow. i overlooked it other day lol
this is my work horse 700 with a long frame plow on it.
Texas Todd
My rear hitch wouldnt allow that to work, but it all worked out fine.
Texas Todd
Wanted to add some light but didnt want to change the look. Found these LED running lights and they give off just enough light to not run into things. It gets dark in Texas, believe it or not!
  • Similar Content
    • CS-17
      By CS-17
      Sold!!!
      Used 1966 Wheel Horse 856. Includes Kholer K181 8hp engine and 32" deck. Runs and Drives Great!
        I received it in non working order, I have since done the following repairs:   To Engine/Transmission; New carburetor, fuel pump, fuel line, fuel filter, battery, throttle cable, head bolts, spark plug, regapped points changed oil in engine and transmission and cleaned air filter.   To Body; striped and repainted wheels, blades sharpened and primed hood and rear fenders (ready to be painted).    This mower is ready to add to a collection or used for every day tasks. Cash on pickup. $800 or best offer.   Please feel free to CALL me for details or any question!   THANKS for looking!
    • Retired Wrencher
      By Retired Wrencher
      This was at the big show this summer. This was going to be Sparky tractor but he found a better one. So he knows I am a big fan of these Sart/Gen tractors so I said yes. @Docwheelhorse Delivered it to me. So from then to now I have been working on it bringing  it back to a very useable condition. I did not like the vacuum pumps on these older K181 so I tried finding a mechanical one. It failed to many years sitting in box and forgotten about. So with the help of good members here they led me to electric fuel pump. Never had one. I have to say what a deference . It starts like BAMMMM or snap of your finger.  I am a fan of these now. Will buy more as time goes by. Hope you enjoy the picks.
    • WHX??
      By WHX??
      Portage show a couple of weeks ago I see this girl sitting all by it's lonesome on the auction block. I had first thought is was a bucket lister 855. Cardboard sign on it says consignment for auction so now have to patiently wait for auction tomorrow.
       Auction time comes and I see it's an 856... oh well I'm in love and committed and It's mine for 300 clams. I know Pullstart wanted to jump in just cause he's an auction junkie but didn't want to rain on my parade. Thanks Bro... I gave him the deck to ease his pain. Also had a blower and nice front blade with it but those were sold separate and I had no interest in it. Blower & blade heavy ya know...
      It sports a crude rattle can job but other wise complete & starts & runs great with no smoke.  Jacks boy @Coulter Caleb drove it back to camp for me.
      Appears this tractor has come full circle here at RS
      K181 Full Throttle - Engines - RedSquare Wheel Horse Forum
    • PineBushJohnny
      By PineBushJohnny
      I am new to anything mechanical and inherited a WH856 in pretty good condition when my Father in law passed. My daughter and I turned to this forum to learn all we can to get it in working condition. well low and behold you guys taught us so much and we cleaned the piston head, changed piston ring, cleaned valves, rewire, changed condensor, breaker point, spark plug, coil, ignition switch, fuel tank, fuel lines, throttle and choke cables and got that baby running. my wife was so happy as it is the only thing she has of his. Now we are in NY we get a major snow fall and I break out the WH856 with plow and am making short work off plowing but then wheels go cockeyed. the right hand ball joint assembly keeps coming off. how can I fix this? where can I get both left and right ones so I can make sure it doesn't happen again. while I am at it how do make sure there is enough lubrication in the transmission?
      I am going to post pictures of the 856 soon. It is named after y father in law .... "Dominick da Plumber"
    • Flatheadpete
      By Flatheadpete
      So I got bored Sat afternoon and decided to re-do the hood on grandpa's 856.  Started sanding and it was looking good.  All those layers of brush strokes helped preserve it.  Anyways....on with the pics.  Guess I'll have to do the rest now.
