Horse Newbie
Hooking up a tiller
Horse Newbie
Does anybody know what belt size I will need to use on rear tiller, 520 h?
wheelhorseman
Toro 110265. Length 141" 1/2" wide
Horse Newbie
Thanks wheelhorseman1000...did you see the comment where the guy said a 143 inch worked for him?
wheelhorseman
I did not, Toro calls for the 110265 for the newer style belt tighter then depending on if you have a single cylinder engine or twin cylinder engine will determine witch hole you use in the bracket- the reason? So you only need the 1 belt
Edited by wheelhorseman1000
Horse Newbie
When I went back to ladys barn where I got my 520h I found some brackets that looked like ones I had seen on the tiller pics I have looked at...sort of like the one at the mid mount attach-o-matic point. Does anybody have any pics showing the tiller where the belt comes to it? I'm pretty sure I have a 94 year 36 " tiller b cause my 520h is a 94 and I believe her husband bought them at them same time.
wheelhorseman
Horse Newbie
Thanks a million...I am learning so much on here. I have two Cubs, but they are newer models. I am excited about getting my 520h and am looking forward to figuring out where all the pieces go and hooking it up and putting it to work. I just want to make sure it is in good working order first,. Clean those fins, oil change, chassis lube, things like that. By the way I have the twin cylinder...that exploded view will really help.
wheelhorseman
If you are buying this from the original owner I'm sure all the correct brackets and parts are there and probably the belt as well - good luck and happy hunting!!
Horse Newbie
Am I allowed to mention other makes on here, or will I have to go sit in the corner? I have so much to learn, I can't see me slipping up too often
wheelhorseman
And as you might have heard it is very important to keep the Onan engine clean and free of debris to help keep it cool - there are many threads on this, maybe someone will post a link to one.
Horse Newbie
Thank you for your help !
wheelhorseman
Sorry about the Cubs :text-lol:  but seriously, I believe there is a (other brands) section if you wish to discuss them. Oh and by the way :text-welcomeconfetti: to :rs:and don't be afraid to ask for any help with your 520 it is a nice machine and there is lots of information and good people here on Redsquare to answer any questions you might have.
Walt
:WRS:
  • Similar Content
    • Rick3478
      By Rick3478
      - SOLD - Moderator may remove at will
      0736TL04 tiller and fitments needed to mount on many long frame, C series, 300/400/500 series tractors.
      Notable details:
      Gearbox and tines have low hours.  Tarp had blown off mid-mount idlers and got rusted up, probably need penetrating oil and new idlers.
      Axle mount is rusty/restorable/useable.  Lift cable has nylon worn through on one side (they tend to do that).  One rear jackshaft bushing
      has couple ears broke off, and jackshaft e-clips are lost (edit: found those).  Belt is original.
      Pick up in my back yard near Elida, Ohio.  Bring help to load, or ramps or something.
      I think it may be worth $100.
      - or -
      Would consider trade for a used car or truck hood that I can use for a sled to drag firewood and equipment around on, something kinda
      rounded without points or ridges to catch.  Have been using an S-10 hood for years, and it's wearing through becoming less useable.
      What 'cha got?
    • Epayne85
      By Epayne85
      Hello all, I have a what I believe is a 36” tiller.
      i can get a few pictures of it this afternoon, it rolls freely and appears in very good condition. It’s missing the rear hinge panel. I’m mainly interested in swapping for a box blade and other items depending what you’d have for the clevis or sleeve hitch or I’ll take best offer. Thank you. Also, I have a snow plow and the frame in which someone has modified for I believe an Atv or different tractor I’d be willing to let go for $50 or throw in towards the deal. The blade is in pretty decent shape and the angle mechanism works flawlessly. Again thank you.
      edit* I will be able to get pictures Labor Day weekend, sorry for the delay if anyone is interested
    • morePEdal
      By morePEdal
      1989 Wheel Horse 520H
      Selling my 1989 Wheel Horse 520H. It has hydro transmission and has hydraulic lift. I bought this tractor last November from the original owner with the intent to use it just in the winter. I have a 416-8 that I use for cutting grass, but also have a snow blade. I am selling this because I decided I want power steering so I bought a different garden tractor. I put in a new fuel filter, fuel lines, new spark plugs and oil was changed with a new filter put in. It has 115 compression on both cylinders. The carb needs work, but it does start and run. I no longer have room for it. 1790 hours.
      I am in Germantown, Wisconsin.
      Comes with:
      -42” Deck
      -Two- Single Stage Snowblowers, one is attached.
      -Tiller
      -Snow Plow
      -Hard Top, Soft Sided Cab, in good shape
      -Hubcaps
      -Cast Iron Weights
      -Chains
      -New Battery
      -New Snowblower Belt
      Price: $1100
      Cross Posted.
    • oliver2-44
      By oliver2-44
      Anyone have any Troy Bilt  Pony Tiller Gear Box Experience?
      So about a year ago an older neighbor gave me this Troy Bilt Pony Rear Tine tiller.  Said he forgot he drained the engine oil and started it.  Bore diameter was actually good, but has a bunch of large vertical scars on cylinder walls.
      Fast forward, my wife has volunteered us to help a Youth Summer Camp that runs an  "Outdoor School" during the 9mth  school year.  They had a fairly large garden for several years, but it has been neglected & overgrown for a couple of years.  So she drives past this neglected garden daily!
      There's some scheme emerging where we have half the garden to ourselves and help with the other half where students will plant and weed and pick their produce.  I enjoy a garden, but not real keen on some of the aspects on this one...( a bunch of 6" high raised beds with paths to narrow for my big feet to turn sideways. But I've already been committed, O I mean volunteered.
      So engine is shot (aluminum block)  but I have a Predator or a K181 I could put on it.
      The wheel shaft seals looked shot and had a bunch of play so brass wheel bushings were shot. (the other 2 shafts have tapered roller bearings).
      No model number, but from the "Pxxxxx" serial number and Briggs engine I've dated it to a 1981.
      MTD now owns Troy Bilt and their "on-line manuals" go back to 2000.  Called their Tech Supports and got "Deer in the Headlite" comments regarding a 1981 Service Manual.
      Searched online and founds lots more info on the larger "Horse" model, and a 1991  Pony service manual.
      While they basically look the same, there's been several generations of re-engineering the internals to simplify manufacturing and eliminate castings it appears.
      I found this parts diagram to be the close's match to what I have.
      https://www.partstree.com/models/20462-troy-bilt-pony-i-rear-tine-tiller-sn-p001001-p101750/wheel-tiller-shaft-assemblies-7/
      I disassembled it and I think I marked everything as to what faced the front, back or R,L side.  Internals looked OK, but the wheel shaft seal area is not the greatest.
      Most parts are NLA but found bearing. seals & bushings on ebay. $130
      Reassembled everything and used the 1991 Service Manual as a "Guide" to shimming the 3 shafts end play.
      Everything turn freely in both directions when in neutral. But when I engage the Wheel Shaft "Clutch" it binds up. The clutch lets the wheels roll freely or engages them to power.  It uses belt idlers to reverse direction from a second shaft on the briggs (like a walk behind snow blower drive)
      photo from phone here
      This internal clutch actually works by using a pawl disc which is keyed to the shaft to engage the wheel
      shaft gear which is free wheeling on the shaft.
      I've loosened the bolt on the bearing end caps slightly and no change.
      This uses worm gears and I know "some" worm gears are designed where they must be "power driven"  in each direction (My boat lift is like this)
      So the rear tine gear shaft turn freely in each direction.
      The wheel shaft locks up when the clutch is engaged amd trying to turn it in what would be the forward direction.  But it will turn freely with the clutch engaged if going in the backwards direction.
      The wheel shaft gear cannot be turned backwards because of the clutch mechanism on the one side.
      The rear tine shaft bevel gear turn freely in both direction in neutral but is bound up when the clutch on the wheel shaft is engaged.??
      There is a Main Drive Shaft that has the Worm Gears on it to drive the Wheel Gear and a second worm to drive the Tines Gear.
      https://www.partstree.com/models/20462-troy-bilt-pony-i-rear-tine-tiller-sn-p001001-p101750/main-drive-shaft-gear-assemblies-4/
      This shaft is made up of a smooth shaft with the worms keyed to it and spacers in between them.  I disassembled it (and carefully laid out each piece in order) to wire brush everything clean on the grinder as there was some rust from water in the very bottom of the gearbox.
      I find it hard to believe that I could have one of the worms backwards because it seems it would not turn freely when the wheel clutch is not engaged??
      To remove it I have to disassemble everything and might ruin my seals as I have to drive them out. (dumb me, I tested everything to turn freely before I installed the seals, BUT I didn't engage the clutch)
      Just a note,, I didn't try to turn everything with the "clutch engaged" "Before" I disassembled it so I don't know how hard it should turn, but it had to turn via a belt drive verse's now totally locking up.
      Regrettable a nonworking tiller doesn't get me out being volunteered.
      Did I say I actually enjoy a garden!
      Thanks for any suggestions and listening to my rant.
      This is the input shaft from belt pulley
      Special woodruff key
      Tiller Tine Shaft
      Some one was in here before me. These are threaded holes with removable set screws to drive the bearing cone out. No set screws just filled with caulk or body putty.
    • wh315-8
      By wh315-8
      Anyone be able to measure out the Top Link Bar for the 50” D Series Tiller?
      Just finished rebuilding a tiller, have a adjustable type but would like to put a original type on like the manual has listed.
