benji756 342 #1 Posted October 25, 2016 Here they are! 14 Share this post Link to post Share on other sites
DennisThornton 4,773 #2 Posted October 25, 2016 At least in my environment, near the Canadian border, both blade AND blower are required for snow removal! Blade will handle light storms and blade will cleanup after the blower moves the heavy snows. Point is that I most always use the blade for final cleanup! Wouldn't be without it! Otherwise the little bit that the blower leaves builds up, partially melts and refreezes and later turns into ice and causes me to fall and brake my ankle... really! So up here I like to try to scrape the drive clean and hope some sun comes through to "burn" off the remainder so I can start with a completely bare driveway again! I'm so serious about this (broken ankle!) that I also intend to add a Sweepster! But blower and blade is a very nice combo until then! Thanks for sharing! 4 Share this post Link to post Share on other sites
Wishin4a416 2,610 #3 Posted October 25, 2016 Nice crew. You will be getting the white stuff before me at your latitude. Looks good. 1 Share this post Link to post Share on other sites
pfrederi 21,136 #4 Posted October 25, 2016 (edited) 9 hours ago, DennisThornton said: At least in my environment, near the Canadian border, both blade AND blower are required for snow removal! Blade will handle light storms and blade will cleanup after the blower moves the heavy snows. Point is that I most always use the blade for final cleanup! Wouldn't be without it! Otherwise the little bit that the blower leaves builds up, partially melts and refreezes and later turns into ice and causes me to fall and brake my ankle... really! So up here I like to try to scrape the drive clean and hope some sun comes through to "burn" off the remainder so I can start with a completely bare driveway again! I'm so serious about this (broken ankle!) that I also intend to add a Sweepster! But blower and blade is a very nice combo until then! Thanks for sharing! If you have any wind at all you might want to think twice about a sweepster. You can't change the angle so you sort of have to wait until there is no wind (very rare here) or coming from the right direction. It takes me several days to sweep the stones back into the driveway and back on to the road in the spring as I have to wait for optimal wind conditions to do one side then wait again to do the other. Also you will want a dedicated tractor...they are the most difficult to mount implement I have ever seen. They are also incredibly nose heavy so you will need a lot of weights and chains especially on slippery surfaces. Edited October 25, 2016 by pfrederi Share this post Link to post Share on other sites
DougC 2,644 #5 Posted October 25, 2016 That combination should be able to kick old man winters a$$ for sure! 1 Share this post Link to post Share on other sites
Pollack Pete 2,273 #6 Posted October 25, 2016 VERY nice snow team.Supposed to get flurries here on Thursday. Share this post Link to post Share on other sites
AMC RULES 37,259 #7 Posted October 25, 2016 ...with overnight temps dipping down into the 20's. 1 Share this post Link to post Share on other sites
DennisThornton 4,773 #8 Posted October 25, 2016 9 hours ago, pfrederi said: If you have any wind at all you might want to think twice about a sweepster. You can't change the angle so you sort of have to wait until there is no wind (very rare here) or coming from the right direction. It takes me several days to sweep the stones back into the driveway and back on to the road in the spring as I have to wait for optimal wind conditions to do one side then wait again to do the other. Also you will want a dedicated tractor...they are the most difficult to mount implement I have ever seen. They are also incredibly nose heavy so you will need a lot of weights and chains especially on slippery surfaces. I'm slowly telling myself that I already have a walk-behind BCS with a rotary brush that is much more maneuverable and I think it swings both ways. And yes indeed, it would go on and STAY on a tractor. I'm pretty much done swapping attachments! Thanks for the comments! One of the things that makes this group so great! 1 Share this post Link to post Share on other sites
shallowwatersailor 3,222 #9 Posted October 25, 2016 30 minutes ago, DennisThornton said: I'm slowly telling myself that I already have a walk-behind BCS with a rotary brush that is much more maneuverable and I think it swings both ways. And yes indeed, it would go on and STAY on a tractor. I'm pretty much done swapping attachments! Thanks for the comments! One of the things that makes this group so great! Dennis, the BCS is two bolts and nuts to attach the brush! Wish I had one. Share this post Link to post Share on other sites
DennisThornton 4,773 #10 Posted October 25, 2016 1 minute ago, shallowwatersailor said: Dennis, the BCS is two bolts and nuts to attach the brush! Wish I had one. Yeah, I've been silly looking elsewhere when I could fix what little is wrong with the BCS rotary brush. But, that 10 hp ACME is miserable about starting in the cold! Just about have to keep it warm, start it and THEN take it outside! Then again if BCS had this kind of forum, with this group of guys to help... 1 Share this post Link to post Share on other sites
shallowwatersailor 3,222 #11 Posted October 25, 2016 3 minutes ago, DennisThornton said: Yeah, I've been silly looking elsewhere when I could fix what little is wrong with the BCS rotary brush. But, that 10 hp ACME is miserable about starting in the cold! Just about have to keep it warm, start it and THEN take it outside! Then again if BCS had this kind of forum, with this group of guys to help... Try this company for options for your BCS. http://www.earthtoolsbcs.com/html/replacement_engines.html Share this post Link to post Share on other sites
DennisThornton 4,773 #12 Posted October 25, 2016 5 minutes ago, shallowwatersailor said: Try this company for options for your BCS. http://www.earthtoolsbcs.com/html/replacement_engines.html Oh my goodness yes! They have been a BIG boon for BCS for a long time! But if only there was a forum like this for BCS.... You know, BCS is a largely overlooked and underappreciated brand or 2 wheeled tractors and attachments! Share this post Link to post Share on other sites
Retired Wrencher 6,974 #13 Posted October 27, 2016 benji756 Look like you are ready for what ever comes your way. Hope fully it not to bad of a winter just enough to get some seat time. 2 Share this post Link to post Share on other sites
ClassicTractorProfessor 5,455 #14 Posted October 28, 2016 Good looking snow crew...keep that white stuff up north lol. Haven't got my tractor put back together yet so if we get any it's gonna be my back and a shovel lol Share this post Link to post Share on other sites
