Similar Content
By DeltaNu1142
I bought a 5xi package yesterday including some attachments I'm not going to need:
4' plow, model # 79355 - in great condition, very minor surface rust on crossmember and back side of blade. $250 48" mower deck with blower and bagger - in good condition, working when removed from tractor yesterday. Previous owner said it never clogged on him. Some surface rust on deck and one 2" hole near the center. $300.
I'm open to offers and interested in trades! I'm looking for a 2-stage snow thrower, p/n 79366. Maybe tools, etc.
Available for pickup--let me know if you have any questions. Thanks!
Here's a photo of the deck that's included. It's got some rust holes, but functions perfectly. Most of the price here is wrapped up in the blower & bagger:
By davidtmercer
Very good condition.
Gauge wheels will need replaced but are currently functional
No mule drive or PTO belt included
Firm on price due to availability and condition
By cJ_3D
Hey all!
Replacing the drive belt on my 252-h. Anyone know the torque specification for the center screw when I put this pto clutch back on? I know it was on there tight it took a minute for the impact to break it loose. Thanks!
CJ
By razorback1995
Hey all,
This pully blew up on me yesterday. Having a hard time IDing the part # or replacements. the 308-8 schematics I've found don't list this part. Its the pully in the front that runs from the motor to the mowing deck.
Thanks in advance!
By Berco
Hello all. My battery in my 520LXI was going out, the lights would come on but the engine would not turn over. I put a 1.5 amp truckle charger on the battery when i left for a 4 days trip. I come back and the same. I also noticed i left the key in the run position (the hour meter did not run). I swap out batteries and now the mower is completely dead. When i turn the key - nothing. I verify the battery it good (13.04v), negative is connected to the engine block, voltage is good on the solenoid side of the starter. I out the key to run and try to jump to see if i can start and nothing. Not even a spark. I have used this mover for years and has 500 hours. Could the ignition switch or brake switch be bad? The seat switch is jumped.What else could cause my mower to be dead? Thank you in advance.
