Team70R
Deck lift handle lock release
Team70R
Anyone know how to replace the spring at the bottom of the manual lift deck handle that puts pressure on the lock to hold up the deck in its highest position? I've already removed the rubber grip at the top.
Wes
gwest_ca
What model of tractor?
Garry
Team70R
Sorry, knew I was forgetting something!! It's a 655
Ed Kennell
Go to the operators manual for your tractor. You will find the detailed parts dwg for the lift arm assembly.    I tried to paste the link, but it failed.
There is a block and roll pin at the bottom, but I can not remember if you have to remove the entire rock shaft / lift lever to get to it.
Edited by Ed Kennell
KC9KAS
I have fixed a couple, but can't remember/explain it....seems there was a roll pin I had to drive out of a block at the bottom, disassemble, replace the spring and reassemble.
Team70R
Thanks! That atleast gives me somewhere to start!
gwest_ca
The parts manual may help
Garry
Ed Kennell
Thanks Garry,  some days I am smart enough to copy and paste and other days.......:confusion-helpsos:
Team70R
Got it!! Thanks for link to the manual. Definitely a life saver!!
  • Similar Content
    • cJ_3D
      By cJ_3D
      Hello helpful Wheel Horse enthusiasts!
      Maybe you all could help me figure something out. I don't think I am installing the mower deck properly on my 1989 252-H and I don't know if the PTO clutch is adjusted right.
      So referencing this image here from the service manual for the mower deck (37"):
      What exactly am I doing with this adjustment knob and how does it fit into this piece?
      Also for the PTO clutch where am I sticking the feeler gauge exactly and do I need to do all 3 springs? Or does adjusting the one in the manual adjust all three?
      Much obliged for the help!
      CJ
    • lsc1257
      By lsc1257
      I have a 1996 520H Wheel Horse for sale.  The tractor has just over 800 hours on it.  It comes with a 48 inch deck.  The deck is a 1995 and has over 1,500 hours on it, as it came brand new with my 312-8 that I sold several years ago.  This 520-H has the swept front axle so it can handle a 60 inch deck.  I just replaced the battery and the deck belt this summer.  The engine is a 20HP Onan and it starts right up but requires the full choke.  The transmission is an Eaton 1100-062, hydrostatic.  The deck is in rough shape but the spindles appear to be in good working order.  The right rear tire has some cracking.  The original operator's manual for the 520H is included, as is the original operating and maintenance instructions for the deck, plus the installation instructions for the deck.  Also included is a new PTO belt and several miscellaneous deck wheels and rollers.  Additional pictures available upon request.  Asking $500.
    • BrianKoch
      By BrianKoch
      Gentlemen,
      I’m having trouble with getting my deck to raise up and lock and I think it might have to do with the deck being incorrectly set up.
      Based on the picture, does my mower deck look incorrectly positioned? That is, should the pivoting support bar be positioned above or below the wheel support pin?
      Brian
    • davem1111
      By davem1111
      I thought I'd circle back and see if I can fix a 42" deck (05-42MS05) that came off of one of my previous tractor purchases. I got the blades off and the bottoms of the spindles look good, and it needs some metal welded on where the wheel height adustment bracket bolts on. No big deal.
      The problem I'm having now on this deck is that I can't get this one spindle off. I haven't gotten the others off either, but they seem to be fine. This pulley is flopping around and obviously needs help. I've tried heating it with a torch after spraying it with penetrating spray numerous times, and it won't budge.  At this point, I'm thinking that I'll just need to grind it off, right through the spindle shaft, unless I can successfully cut through the thick ring without damaging the spindle shaft. If I have to grind through the pulley, it probably doesn't matter because I think it's shot already. Anyone have any other ideas?
      One question:  Is that thick ring supposed to be part of the pulley? This one is detached and the pulley spins freely (and sloppily).  Assuming I'll need to buy a new pulley, but was hoping not to have to buy another spindle shaft also. I did take the grease zirk off and have hammered on the top some, but only with a block of brass in between. It could already be damaged there.
      The picture doesn't help much, but here it is:
    • firstimpauto@gmail.com
      By firstimpauto@gmail.com
      1977 C160 Automatic Tractor.  This has been my go to tractor for over 30 years.  Not a show tractor by any means. Could definitely use a tune up but still runs and mows.  Included are original manuals, 2 mowing decks, cab ( which needs all the windows replaced) including the doors and tire chains.  Someone modified the plow so it doesn't really fit this tractor.  I purchased a larger machine so do not have a need for this.  Hydraulic lift is not working.  One front tire has a slow leak.  Open to offers.  Thought I had this sold but it was someone trying to scam me with a phony cashiers check.  Please be careful.  This is the only site I have this listed so the scammer must be monitoring these ads.  Sold the rototiller. So adjusted the price.
