WheelE
Wheel Horse Newbie -- with a few questions
SylvanLakeWH
:text-welcomeconfetti:
DougC
Hello and   :text-welcomeconfetti:   to    :rs:   Enjoy the forum,   :)
gwest_ca
Welcome to the forum
The drive belt and it's dimensions have been added to this page
Garry
Walt
Welcome to Red Square.
AMC RULES
:WRS:
Ed Kennell
SAMWISE looks like he can handle any job.     :text-welcomeconfetti:
DennisThornton
3 hours ago, WheelE said:
Hi All, (what's the proper term for Wheel Horse aficionados?  Wheelies?  Horsers?  Whiskey Hotels?),
Just became proud owner of a 1970 Charger 12 Auto with tiller and hydraulic loader.  We've decided to call it Samwise because it's small but mighty and (we hope) dependable.
I'm still figuring things out and have one issue:  the parking brake lever keeps popping up on its own.  That doesn't stop the tractor, so I assume the pawl has been ground down / busted.  And, the transmission continues to get power with the lever up, which makes me think someone has installed a drive belt that is too short.  Does that seem likely?  What is the proper size belt?
Thanks!  I'm sure I'll have many more questions.  I've already learned a ton perusing the archives.
Wow!  Look at that bucket!  OK!  I've got to know more about that FEL!
  • Like 4
Tankman
Great Horse! WHA (Wheel Horse Addiction) will be yours too! :ROTF:
SylvanLakeWH
:text-yeahthat: But, not really an addiction as much as a need to keep it even - Little Sister needs one for her and her dolly...:wh::wh:
Adams94
Would love to have a loader on one someday!  :text-welcomeconfetti::WRS::text-goodpost::wh:
WheelE
It says it's a "Work Horse Model 10" by Johnson Hydraulic.  Looks about as old as the tractor.  It's definitely a beast for this size tractor.
Garry
Thanks so much!  Extremely helpful info.....
DennisThornton
"It says it's a "Work Horse Model 10" by Johnson Hydraulic.  Looks about as old as the tractor.  It's definitely a beast for this size tractor."
Great info but I have to think that bucket is not original.  Fine if I'm wrong but I'd like some opinions.
smoreau
Looks like a snow bucket. Full scoop of dirt may be too much for stability. I have a smaller bucket and 400+ pounds on that back am mine get tippy over 3 feet in the air.
Edited by smoreau
WheelE
Good point -- definitely going to have to watch out for that.
Probably not.  I'm just going off the 70's era font on the decals
smoreau
It does look like the Johnson loaders, same design that I've seen before. Buckets I thought were smaller then the one you have, but I could be wrong. There is nothing wrong with a Johnson loader in any way. Tested and proven design! Using a tiller is good counter weight but does the belt for the tiller interfier with the sub frame?
jellyghost
That is a beast!  I would love a wheel horse with a front loader.  I hope it has good stability for you.
roadapples
        :WRS:
jay bee
Samwise looks like a wise choice.
Jim
Bttatro
That is one impressive machine you have there.   :text-welcomeconfetti: to :rs:and enjoy your :wh:!
Retired Wrencher
WheelE     :WRS: Good looking worker Enjoy.
AMC RULES
Careful...not to overload those front spindles...
a full bucket of heavy, wet snow can do that.
For all intents and purposes...
those loader were intended for light duty only...i.e., mulch movers.
JC 1965
Great lookin tractor. FEL should be very useful for you. Great photo thanks for sharing and       :WRS:
TDF5G
:WRS:
You have a great looking "worker" there and an operator too!
bmsgaffer
You can upgrade that front axle and spindle to one from a 1991 or later 520H and it will have gear reduction steering, heavier duty 1" spindles, and a swept forward design. They are a bit hard to come by and can be expensive, but well worth it if you have a loader! You only need to drill two holes in the frame.
Also check the transmission mounting plate. Look for stress cracks, weld them up and reinforce it!
Welcome!
  • Similar Content
    • Rick3478
      By Rick3478
      - SOLD - Moderator may remove at will
      0736TL04 tiller and fitments needed to mount on many long frame, C series, 300/400/500 series tractors.
      Notable details:
      Gearbox and tines have low hours.  Tarp had blown off mid-mount idlers and got rusted up, probably need penetrating oil and new idlers.
      Axle mount is rusty/restorable/useable.  Lift cable has nylon worn through on one side (they tend to do that).  One rear jackshaft bushing
      has couple ears broke off, and jackshaft e-clips are lost (edit: found those).  Belt is original.
      Pick up in my back yard near Elida, Ohio.  Bring help to load, or ramps or something.
      I think it may be worth $100.
      - or -
      Would consider trade for a used car or truck hood that I can use for a sled to drag firewood and equipment around on, something kinda
      rounded without points or ridges to catch.  Have been using an S-10 hood for years, and it's wearing through becoming less useable.
      What 'cha got?
    • rustyedge1
      By rustyedge1
      Belt in photo is K Force brand A 102742 which is what my local parts place is pushing at 30 bucks plus.
      This one was bought two seasons ago counting this mowing season and it’s not going to make it looks like..
      Any info on better made belts appreciated..
    • River Rat
      By River Rat
      I am looking for the Wheel Horse part number for the Mule Drive belt on my 1984 C145A 11-14KE01. I believe it is 102742. The old one is stretched quite a bit and not sure the outside length. possibly 1/2 by 103 in? 48 inch mower.
      Any help is appreciated!
    • Epayne85
      By Epayne85
      Hello all, I have a what I believe is a 36” tiller.
      i can get a few pictures of it this afternoon, it rolls freely and appears in very good condition. It’s missing the rear hinge panel. I’m mainly interested in swapping for a box blade and other items depending what you’d have for the clevis or sleeve hitch or I’ll take best offer. Thank you. Also, I have a snow plow and the frame in which someone has modified for I believe an Atv or different tractor I’d be willing to let go for $50 or throw in towards the deal. The blade is in pretty decent shape and the angle mechanism works flawlessly. Again thank you.
      edit* I will be able to get pictures Labor Day weekend, sorry for the delay if anyone is interested
    • morePEdal
      By morePEdal
      1989 Wheel Horse 520H
      Selling my 1989 Wheel Horse 520H. It has hydro transmission and has hydraulic lift. I bought this tractor last November from the original owner with the intent to use it just in the winter. I have a 416-8 that I use for cutting grass, but also have a snow blade. I am selling this because I decided I want power steering so I bought a different garden tractor. I put in a new fuel filter, fuel lines, new spark plugs and oil was changed with a new filter put in. It has 115 compression on both cylinders. The carb needs work, but it does start and run. I no longer have room for it. 1790 hours.
      I am in Germantown, Wisconsin.
      Comes with:
      -42” Deck
      -Two- Single Stage Snowblowers, one is attached.
      -Tiller
      -Snow Plow
      -Hard Top, Soft Sided Cab, in good shape
      -Hubcaps
      -Cast Iron Weights
      -Chains
      -New Battery
      -New Snowblower Belt
      Price: $1100
      Cross Posted.
